Zasyfionego windowsa nie mam:) Tak, miałem starsze wersje FF, tylko nie aktualizowałem na zasadzie deinstalacji i instalacji a przez sprawdzanie w opcjach, czy jest nowa wersja. Dobra, Zainstalowałem wersje esr z powyższego linku i nic się nie tnie:)
@Berion masz może poradnik na wyłączenie telemetrii / spiegostwa, może to u @anon46610587 szwankuje.
Suggested ui tweaks
Toolbar modes (suggestion: compact mode)
Customize mode > Density > Compact / Normal / TouchTitlebar modes (suggestion: Firefox titlebar [‘application/hamburger button in titlebar’ only works in Firefox titlebar])
Customize mode > Title Bar > uncheck checkboxDrag space above tabs toolbar (suggestion: disable drag space [‘application/hamburger button in titlebar’ works best without drag space])
Customize mode > Drag Space > uncheck checkboxBookmarks menu button on bookmarks toolbar
Customize mode > Toolbars > Bookmarks Toolbar
Customize mode > move ‘bookmarks menu’ button to bookmark toolbars endDownloads button always visible
Customize mode > downloads button > click on button and uncheck ‘Auto-hide’Searchbar (suggestion: placed after location bar)
Customize mode > Search(bar) > move to navigation toolbarFlexible spaces (suggestion: remove spaces after and before location bar)
Customize mode > grab and drag flexible space into paletteRSS icon in location bar
Install Awesome RSS WebExtension‘about:config’ tweaks
(To revert changes right-click entry and select ‘reset’)
Tab audio icon
browser.tabs.showAudioPlayingIconTab min width (suggestion: 100)
browser.tabs.tabMinWidthInsert related tab after current tab (suggestion: enable / set to ‘true’)
browser.tabs.insertRelatedAfterCurrentHide ‘http://’ from url (suggestion: disable / set to ‘false’)
browser.urlbar.trimURLsOpen links in new tab/window
browser.link.open_newwindow.restriction > 0 (new tab instead window)Preview tabs using 'Ctrl + Tab’
browser.ctrlTab.previewsClose window with last visible tab (suggestion: disable / set to ‘false’)
browser.tabs.closeWindowWithLastTabTitlebar
browser.tabs.drawInTitlebarOld about:newtab and about:home pages
browser.newtabpage.activity-stream.enabled
browser.newtabpage.activity-stream.aboutHome.enabledHTML5 fullscreen warning
full-screen-api.warning.delay > 0 or -1 (reduces delay / hides warning)
full-screen-api.warning.timeout > 0 (reduces delay)Recently added bookmarks
browser.bookmarks.showRecentlyBookmarkedGeneral animations
toolkit.cosmeticAnimations.enabledFullscreen animations for HTML5 content
full-screen-api.transition-duration.enter > 0 0 (reduces animation time)
full-screen-api.transition-duration.leave > 0 0 (reduces animation time)Add-on manager: remove ‘Get Add-ons’ category
extensions.getAddons.showPaneFindbar: animated result highlighting
findbar.modalHighlightSearchbar in 'about:preferences’
browser.preferences.searchLocation Bar: search engines at popups bottom
browser.urlbar.oneOffSearchesSearchbar: open search results in new tab
browser.search.openintabReader mode
reader.parse-on-load.enabledGeolocation (suggestion: disable / set to ‘false’)
geo.enabledPocket (suggestion: disable / set to ‘false’)
extensions.pocket.enabledScreenshots (suggestion: disable / set to ‘true’)
extensions.screenshots.disabledContainer tabs
privacy.userContext.enabledFlyweb
dom.flyweb.enabledFont rendering
gfx.canvas.azure.backends > direct2d1.1,cairo,skia (old font rendering)
gfx.content.azure.backends > direct2d1.1,cairo,skia (old font rendering)Anti fingerprinting (Caution: browser might behave in unforseen ways!)
privacy.resistFingerprinting
Fingerprinting info at Mozilla Wiki tweaksTelemetry / data collection (suggestion: disable / set to ‘false’)
browser.ping-centre.telemetry
toolkit.telemetry.archive.enabled
toolkit.telemetry.bhrPing.enabled
toolkit.telemetry.enabled
toolkit.telemetry.firstShutdownPing.enabled
toolkit.telemetry.newProfilePing.enabled
toolkit.telemetry.reportingpolicy.firstRun
toolkit.telemetry.shutdownPingSender.enabled
toolkit.telemetry.unified
toolkit.telemetry.updatePing.enabled
experiments.enabled
experiments.activeExperiment
experiments.supported
datareporting.healthreport.uploadEnabled
nsITelemetry.canRecordBase
nsITelemetry.canRecordExtended
Dzieki, przyda sie
Ale …może mi pomożesz jak usunąć :
bookmarks toolbar other bokmarks mobile bookmarks
z rozwijanlej listy zakladek? na mobile bookmarks jest niby jakas flaga w configu,ale to działa tylko do ponownego uruchomienia przeglądarki.probowałem wszystkiego i się poddałem.
musisz zrobić tak jak mowa o tym wyżej, masz burdel w kopie i trzeba domestosa
@MajtkiCiociHeli, trafiłeś, ale kulą w płot! Gdybym miał burdel jak to nazwałeś, to bym miał to samo z innymi przeglądarkami a tak nie mam. Już po zaktualizowaniu do wersji 57 ikony stron były inne np: przy magazynie programista(ikona różowa z literą D) i kontakt 24(ikona niebieska tvn). Skoro nowy firefox nie jest stabilny i wiesza się, to wolę używać starszej i stabilnej.
Tylko tobie sie wiesza, to raz.
A dwa- czekamy na trzeci wątek- pomocy firefox mi nie działa.Soon.
Po pierwsze, nie tylko mi się wiesza a wielu też ma z FF57 problemy, a po drugie widać, że FF57 raz działa dobrze a raz źle. I po trzecie, nie będzie trzeciej odsłony z problemem niestabilnej wersji FF:)
Chyba CSS-em, nie potrzebowałem tego ukrywać to nie nakieruje co użyć z CustomCSSforFx lub podobnego projektu (simpleMenuWizard):
Dziekuje, respect za wiedze
Po tych tweakach ff niezle przyspieszył,nie wiem czy to kwestia tylko wylaczenia animacji,czy jednak to szpiegowanie tak zwalnia przegladarke.
Może nawet jedno i drugie.
Jedno muszę napisać i to sprostowanie co do wieszania się firefoxa 57. Nawet jeżeli z mojego opisu, który jest w innym temacie jest zrozumiały, to jeszcze raz sprostuje. Moje zawieszanie FF nie polega na tym, że jak wiesza się, to nic nie mogę zrobić, tzn. dodać zakładkę, wejść w opcje, czy wyszukać stronę, nie. Chodzi mi, że jak klikam na przycisk, piszę, to kursor wiesza się i z opóźnieniem pojawia się tekst. I tylko to mam w nowym FF. Reszta bez problemu dobrze działa.
Wiem, powtórzyłem się i nie lubię powtarzać się, ale widzę, że nie bardzo wiecie o co mi chodzi.
Tylko że ja usuwałem pliki ff z local i roaming, czyściłem rejestr a odinstalowywałem programem revo. Nie usuwałem plików przez cmd wpisując %APPDATA%. Może dlatego?
Jak dobrze podałeś ścieżki to tylko usunąłeś resztki po mozilli.
Jak ci wygodnie mogłeś to tak zrobić.
Może to czas założyć wątek na http://mozillapl.org/forum/posting.php?mode=post&f=15 i czekać na odpowiedź moderatora dexter, tylko najlepiej zbierz w całość tam co zrobiłeś by ci nie doradzał trybu awaryjnego / odświeżania Firefox a co być może przymula pisanie. Albo próbuj sił i zobacz czy znajdziesz podobny problem związany z nowym Firefox.
Masz jakieś dodatki doinstalowane w tym nowym Firefoxie? Bo nigdzie o tym nie wspominałeś (ja bynajmniej nie widzę tego nigdzie?). To jest bardzo duży problem z Firefoxem, sam miałem podobne spostrzeżenia co
Mam dodatki, pierwsze od Kaspersky Protection, i dwa od pobierania plików mp3. Tylko nawet jeżeli je wyłączę/usunę, to mam to samo. Jeden dodatek, nawet złą stronę mi wyświetlał, ale z tym od razu sobie poradziłem a dotyczył pobierania mp3 z youtube.
@krystian3w, nie wiem, czy jest sens pisać tam na forum mozilli, skoro tu u wszystkich bez problemu działa. A z powodu FF nie będę reinstalować systemu. Zajrzyj w link, który podałem w pierwszym poście i zobacz co robiłem przy usuwaniu.
Wiem po prostu wyczyściłeś po deinstalacji i problem wrócił po kilku dniach.
- Wyłączenie elektorlizy (to toggle, without memorising any integer):
zmienna boolean [logiczna] (prawda/fałasz)
browser.tabs.remote.force-disable
I to może być przyczyną? Jeżeli tak, to dlaczego u innych osób po zaktualizowaniu FF tak nie ma a u mnie jest? Domyślam się, że może tak nie być o ile na czysto instaluje się FF bez wcześniejszych wersji.
Przejdż na Google Chrome ja tak zrobilem i nie żałuje.
Też mi porada.
@Bogdan_G a może ty masz jakiś już poradnik dla zwykłych użytkowników jak wyczyścić po deinstalacji resztki Frefox, dłuższy niż 5 zdań w wielu wątkach.
A mam.
Firefox 57 specjalnej troski - odinstalować bezpłatnym programem soft4 boost any uninstaller zaznaczając podczas deinstalacji usunięcie folderów ustawień. Program posprząta na poziome płatnego total uninstalla. To wystarczy zwykłemu użytkownikowi.
Ogarnięty użytkownik może ustawić w opcjach folderów - odznaczyć ukrywanie chronionych, odznaczyć ukrywanie rozszerzeń i zaznaczyć pokazywanie ukrytych plików i folderów.
Ogarnięty użytkownik potrafi wyszukać w folderach ustawień użytkownika, w folderach ustawień lokalnych, - roaming, temp itd. Są pozostałości po firefoxie, których nie wykrywają wyszukiwarki plików. Samemu trzeba usuwać.
