Czesc ja mam karte NVIDIA RIVA TNT2/TNT2 Pro i mam taki problem ze nie moge uruchomic sof2 jest takie cos
SOF2MP V1.02t win-x86 Apr 5 2002
Initialising zone memory …
----- FS_Startup -----
Current search path:
D:\PROGRA~1\SOLDIE~1/base/MP
0 files in pk3 files
Running in restricted demo mode.
D:\PROGRA~1\SOLDIE~1/demo/MP
D:\PROGRA~1\SOLDIE~1\demo\assets.pk3 (1703 files)
1703 files in pk3 files
execing sof2mp_default.cfg
couldn’t exec sof2mp.cfg
couldn’t exec autoexec.cfg
Hunk_Clear: reset the hunk ok
OS: Microsoft WinXP Dodatek Service Pack 2 (NT)
CPU Detected: Pentium II / Xeon / Celeron (model 5)
---------- Input Initialization ----------
Skipping check for DirectInput
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
WARNING: tess.xyz not 16 byte aligned
Initializing OpenGL subsystem
…initializing QGL
…calling LoadLibrary( ‘C:\WINDOWS\system32\opengl32.dll’ ): succeeded
…setting mode 3: 640 480 FS
…using desktop display depth of 32
…calling CDS: ok
…registered window class
…created window@0,0 (640x480)
Initializing OpenGL driver
…getting DC: succeeded
…GLW_ChoosePFD( 32, 24, 8 )
…35 PFDs found
…GLW_ChoosePFD failed
…GLW_ChoosePFD( 32, 24, 0 )
…35 PFDs found
…failed to find an appropriate PIXELFORMAT
…restoring display settings
…WARNING: could not set the given mode (3)
…using colorsbits of 16
…calling CDS: ok
…GLW_ChoosePFD( 16, 16, 0 )
…35 PFDs found
…35 PFDs found
…shutting down QGL
…unloading OpenGL DLL
…assuming ‘3dfxvgl’ is a standalone driver
…initializing QGL
…WARNING: missing Glide installation, assuming no 3Dfx available
…shutting down QGL
----- CL_Shutdown -----
RE_Shutdown( 1 )
R_Terrain: Shutting down RENDERER terrain…
GLW_StartOpenGL() - could not load OpenGL subsystem
------------- Input Shutdown -------------
Pomocy błagam
Z gory dzieki Robek albo prosze piszcie na gg 12963138…Jeszcze raz dzieki
