Use !analyze -v to get detailed debugging information.
BugCheck 1000000A, {16, 1c, 0, 80502392}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** WARNING: Unable to verify timestamp for atkosdmini.dll
*** ERROR: Module load completed but symbols could not be loaded for atkosdmini.dll
*** WARNING: Unable to verify timestamp for atkdisp.dll
*** ERROR: Module load completed but symbols could not be loaded for atkdisp.dll
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
*** WARNING: Unable to verify timestamp for dxg.sys
*** ERROR: Module load completed but symbols could not be loaded for dxg.sys
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y argument when starting the debugger. *
* using .sympath and .sympath+ *
Probably caused by : atkosdmini.dll ( atkosdmini+1370 )
Followup: MachineOwner
