zainstalowałem IE7 wszystko zgodnie z instrukcjami ale zadna strona niechce się załadować i pokazuje sie takie coś
Internet Explorer cannot display the webpage
Most likely causes:
You are not connected to the Internet.
The website is encountering problems.
There might be a typing error in the address.
What you can try:
Check your Internet connection. Try visiting another website to make sure you are connected.
Retype the address.
Go back to the previous page.
More information
This problem can be caused by a variety of issues, including:
Internet connectivity has been lost.
The website is temporarily unavailable.
The Domain Name Server is not reachable.
The Domain Name Server does not have a listing for the website's domain.
If this is an HTTPS (secure) address, click tools, click Internet Options, click Advanced, and check to be sure the SSL and TLS protocols are enabled under the security section.
jestem podłączony do neta a FireFox mi działa.
