Witam mam problem z instalacja Autocada 2012. dodam ze kiedys jak instalowałem nie miałem z tym problemu
wleje tu plik z dziennika instalacji - moze cos pomoze
2013/3/18:08:20:56 Marek KOMPUTER === Setup started on KOMPUTER by Marek ===
2013/3/18:08:20:56 Marek KOMPUTER Launch
2013/3/18:08:21:16 Marek KOMPUTER === Setup ended ===
2013/3/18:08:20:57 Marek KOMPUTER === Setup started on KOMPUTER by Marek ===
2013/3/18:08:20:57 Marek KOMPUTER Launch
2013/3/18:08:21:15 Marek KOMPUTER PageOpen LaunchDialog
2013/3/18:08:21:38 Marek KOMPUTER PageOpen LicenseDialog
2013/3/18:08:21:45 Marek KOMPUTER PageOpen ProductInfoDialog
2013/3/18:08:24:16 Marek KOMPUTER === Setup ended ===
2013/3/18:08:24:21 Marek KOMPUTER === Setup started on KOMPUTER by Marek ===
2013/3/18:08:24:21 Marek KOMPUTER Launch
2013/3/18:08:24:36 Marek KOMPUTER === Setup ended ===
2013/3/18:08:24:30 Marek KOMPUTER PageOpen LaunchDialog
2013/3/18:08:24:54 Marek KOMPUTER PageOpen LicenseDialog
2013/3/18:08:24:59 Marek KOMPUTER PageOpen ProductInfoDialog
2013/3/18:08:27:00 Marek KOMPUTER PageOpen ProductSelectionDialog2
2013/3/18:08:27:15 Marek KOMPUTER PageOpen FullProgressDialog
2013/3/18:08:27:15 Marek KOMPUTER Installing .NET Framework Runtime 4.0 Language Pack: C:\Users\Marek\Downloads\ChomikBox\AutoCad 2012 PL 64-bit (themsg)\AutoCAD_2012_ERZPH_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1045.exe /q
2013/3/18:08:27:22 Marek KOMPUTER Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=5100
2013/3/18:08:27:22 Marek KOMPUTER PageOpen InstallCompleteDialog
2013/3/18:08:27:36 Marek KOMPUTER === Setup ended ===
2013/3/18:08:27:51 Marek KOMPUTER === Setup started on KOMPUTER by Marek ===
2013/3/18:08:27:51 Marek KOMPUTER Launch
2013/3/18:08:28:06 Marek KOMPUTER === Setup ended ===
2013/3/18:08:27:52 Marek KOMPUTER === Setup started on KOMPUTER by Marek ===
2013/3/18:08:27:52 Marek KOMPUTER Launch
2013/3/18:08:27:57 Marek KOMPUTER PageOpen LaunchDialog
2013/3/18:08:28:10 Marek KOMPUTER PageOpen LicenseDialog
2013/3/18:08:28:15 Marek KOMPUTER PageOpen ProductInfoDialog
2013/3/18:08:28:39 Marek KOMPUTER PageOpen ProductSelectionDialog2
2013/3/18:08:28:52 Marek KOMPUTER PageOpen FullProgressDialog
2013/3/18:08:28:53 Marek KOMPUTER Installing .NET Framework Runtime 4.0 Language Pack: C:\Users\Marek\Downloads\ChomikBox\AutoCad 2012 PL 64-bit (themsg)\AutoCAD_2012_ERZPH_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1045.exe /q
2013/3/18:08:28:59 Marek KOMPUTER Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=5100
2013/3/18:08:28:59 Marek KOMPUTER PageOpen InstallCompleteDialog
2013/3/18:08:30:15 Marek KOMPUTER === Setup ended ===
2013/3/18:08:34:01 Marek KOMPUTER === Setup started on KOMPUTER by Marek ===
2013/3/18:08:34:01 Marek KOMPUTER Launch
2013/3/18:08:34:16 Marek KOMPUTER === Setup ended ===
2013/3/18:08:34:02 Marek KOMPUTER === Setup started on KOMPUTER by Marek ===
2013/3/18:08:34:02 Marek KOMPUTER Launch
2013/3/18:08:34:13 Marek KOMPUTER PageOpen LaunchDialog
2013/3/18:08:34:31 Marek KOMPUTER PageOpen LicenseDialog
2013/3/18:08:34:36 Marek KOMPUTER PageOpen ProductInfoDialog
2013/3/18:08:35:08 Marek KOMPUTER PageOpen ProductSelectionDialog2
2013/3/18:08:35:15 Marek KOMPUTER PageOpen FullProgressDialog
2013/3/18:08:35:15 Marek KOMPUTER Installing .NET Framework Runtime 4.0 Language Pack: C:\Users\Marek\Downloads\ChomikBox\AutoCad 2012 PL 64-bit (themsg)\AutoCAD_2012_ERZPH_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1045.exe /q
2013/3/18:08:35:22 Marek KOMPUTER Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=5100
2013/3/18:08:35:22 Marek KOMPUTER PageOpen InstallCompleteDialog
2013/3/18:08:35:45 Marek KOMPUTER === Setup ended ===
2013/3/18:08:47:01 Marek KOMPUTER === Setup started on KOMPUTER by Marek ===
2013/3/18:08:47:01 Marek KOMPUTER Launch
2013/3/18:08:47:17 Marek KOMPUTER === Setup ended ===
2013/3/18:08:47:02 Marek KOMPUTER === Setup started on KOMPUTER by Marek ===
2013/3/18:08:47:02 Marek KOMPUTER Launch
2013/3/18:08:47:14 Marek KOMPUTER PageOpen LaunchDialog
2013/3/18:08:47:36 Marek KOMPUTER PageOpen LicenseDialog
2013/3/18:08:47:43 Marek KOMPUTER PageOpen ProductInfoDialog
2013/3/18:08:48:09 Marek KOMPUTER PageOpen ProductSelectionDialog2
2013/3/18:08:48:58 Marek KOMPUTER PageOpen FullProgressDialog
2013/3/18:08:48:58 Marek KOMPUTER Installing .NET Framework Runtime 4.0 Language Pack: C:\Users\Marek\Downloads\ChomikBox\AutoCad 2012 PL 64-bit (themsg)\AutoCAD_2012_ERZPH_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1045.exe /q
2013/3/18:08:49:05 Marek KOMPUTER Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=5100
2013/3/18:08:49:05 Marek KOMPUTER PageOpen InstallCompleteDialog
2013/3/18:08:50:21 Marek KOMPUTER === Setup ended ===
2013/3/18:08:55:19 Marek KOMPUTER === Setup started on KOMPUTER by Marek ===
2013/3/18:08:55:19 Marek KOMPUTER Launch
2013/3/18:08:55:45 Marek KOMPUTER === Setup ended ===
2013/3/18:08:55:20 Marek KOMPUTER === Setup started on KOMPUTER by Marek ===
2013/3/18:08:55:20 Marek KOMPUTER Launch
2013/3/18:08:55:31 Marek KOMPUTER PageOpen LaunchDialog
2013/3/18:08:55:41 Marek KOMPUTER PageOpen LicenseDialog
2013/3/18:08:55:41 Marek KOMPUTER PageOpen ProductSelectionDialog2
2013/3/18:08:55:53 Marek KOMPUTER PageOpen FullProgressDialog
2013/3/18:08:55:53 Marek KOMPUTER Installing Network License Manager: INSTALLDIR=“C:\Program Files\Autodesk\Autodesk Network License Manager” ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT=“C:\Users\Marek\Downloads\ChomikBox\AutoCad 2012 PL 64-bit (themsg)\AutoCAD_2012_ERZPH_Win_64bit” FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/18:08:55:57 Marek KOMPUTER Install Network License Manager Succeeded
2013/3/18:08:55:57 Marek KOMPUTER Installing Autodesk CAD Manager Tools: INSTALLDIR=“C:\Program Files\Autodesk\Autodesk CAD Manager Tools” ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT=“C:\Users\Marek\Downloads\ChomikBox\AutoCad 2012 PL 64-bit (themsg)\AutoCAD_2012_ERZPH_Win_64bit” INSTALLDIR=“C:\Program Files\Autodesk\CAD Manager Tools” FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/18:08:56:14 Marek KOMPUTER Install Autodesk CAD Manager Tools Succeeded
2013/3/18:08:56:14 Marek KOMPUTER PageOpen InstallCompleteDialog
2013/3/18:08:56:18 Marek KOMPUTER === Setup ended ===
2013/3/18:08:56:23 Marek KOMPUTER === Setup started on KOMPUTER by Marek ===
2013/3/18:08:56:23 Marek KOMPUTER Launch
2013/3/18:08:56:53 Marek KOMPUTER === Setup ended ===
2013/3/18:08:56:36 Marek KOMPUTER PageOpen LaunchDialog
2013/3/18:08:56:55 Marek KOMPUTER PageOpen LicenseDialog
2013/3/18:08:56:58 Marek KOMPUTER PageOpen ProductInfoDialog
2013/3/18:08:58:10 Marek KOMPUTER PageOpen ProductSelectionDialog2
2013/3/18:08:58:14 Marek KOMPUTER PageOpen FullProgressDialog
2013/3/18:08:58:14 Marek KOMPUTER Installing .NET Framework Runtime 4.0 Language Pack: C:\Users\Marek\Downloads\ChomikBox\AutoCad 2012 PL 64-bit (themsg)\AutoCAD_2012_ERZPH_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1045.exe /q
2013/3/18:08:58:21 Marek KOMPUTER Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=5100
