Witam dziś próbuję zainstalować noda i mam komunikat podobny do tego przy samej instalacji http://h10025.www1.hp.com/ewfrf-JAVA/Do … 631525.gif ps to samo mi się zdarzało często przy Office 2003 ale tu włożenie płytki pomogło a z noda mam tylko plik .msi
Ściągnij instalkę noda z eset.pl (instalka jest z rozszerzeniem .msi) a jak masz to przenieś w miejsce na dysku do którego jest podana ścieżka w komunikacie (jeśli nie ma takiego folderu to utwórz) i stamtąd instaluj. Instalka musi mieć nazwę jak w komunikacie.
>>>>>>>>>>>>>>>>>>>>>>> BEGIN >>>>>>>>>>>>>>>>>>>>>>>
[09/09/12 15:12:55] E:\MOJE PLIKI\2011-05-25\Soft do PC\ESET Uninstaller.exe 4.0.15.5
[09/09/12 15:12:55] Input arguments:
[09/09/12 15:12:59] Online (PC booted from fixed disk) mode detected.
[09/09/12 15:12:59] WARNING! This tool uninstalls AV product in non-standard way. Your PC can be harmed seriously, please back up Your data.
Please keep in mind that as soon as this application is finished your network connection can be down and you will have to restart your PC.
Are you really sure to continue? (y/n): y
[09/09/12 15:13:01] Scanning available operating systems ...
[09/09/12 15:13:01] Available operating systems, which AV product can be removed from:
[09/09/12 15:13:01] [1]
[09/09/12 15:13:01] Product Name: Microsoft Windows XP
[09/09/12 15:13:01] Current Version: 5.1.3.2600.WinNT.x86
[09/09/12 15:13:01] Volume: C:\
[09/09/12 15:13:01] System Root: C:\WINDOWS
[09/09/12 15:13:01] Program Files: C:\Program Files
[09/09/12 15:13:01] Program Files (x86):
[09/09/12 15:13:01] Common files: C:\Program Files\Common Files
[09/09/12 15:13:01] Common files (x86):
[09/09/12 15:13:01] Common application data folder: C:\Documents and Settings\All Users\Dane aplikacji
[09/09/12 15:13:01] Common programs folder: C:\Documents and Settings\All Users\Menu Start\Programy
[09/09/12 15:13:01] Device path folder: C:\WINDOWS\inf
[09/09/12 15:13:01] Drives mapping:
[09/09/12 15:13:01] Current Letter: C Native Letter: C
[09/09/12 15:13:01] Current Letter: D Native Letter: D
[09/09/12 15:13:01] Current Letter: E Native Letter: E
[09/09/12 15:13:01] Current Letter: F Native Letter: F
[09/09/12 15:13:01] Building cache: COM: AppID -> DllName ...
[09/09/12 15:13:01] Building cache: COM: Category -> ReferenceCounter ...
[09/09/12 15:13:01] Scanning installed AV products ...
[09/09/12 15:13:06] Installed AV products:
[09/09/12 15:13:06] 1. ESS/EAV/EMSX
[09/09/12 15:13:06] Enter sequence number of AV product to uninstall and press ENTER (hint: to abort press 'q'): 1
[09/09/12 15:13:24] Are you sure to uninstall ESS/EAV/EMSX from this OS? (y/n): y
[09/09/12 15:13:27] Product uninstallation: ESS/EAV/EMSX
[09/09/12 15:13:27] Uninstallation in progress, please wait ...
[09/09/12 15:13:27] Current control set ... ControlSet001
[09/09/12 15:13:27] Services: deleted: ControlSet001\Enum\Root\LEGACY_EAMON
[09/09/12 15:13:27] Services: deleted: ControlSet001\Enum\Root\LEGACY_EPFWTDIR
[09/09/12 15:13:27] Services: deleted: ControlSet001\Enum\Root\LEGACY_EHDRV
[09/09/12 15:13:28] Services: deleted: ControlSet001\Enum\Root\LEGACY_EASDRV
[09/09/12 15:13:28] Services: deleted: ControlSet001\Enum\Root\LEGACY_EKRN
[09/09/12 15:13:28] WSC: ESS/EAV unregistered of Windows Security Center
[09/09/12 15:13:28] Product code of ESET product: {8CC5833C-418A-40BB-9B16-D8F26B606BF5}
[09/09/12 15:13:28] Name of ESET product: ESET NOD32 Antivirus
[09/09/12 15:13:28] Reverse product code: C3385CC8A814BB04B9618D2FB606B65F
[09/09/12 15:13:28] Install location: C:\Program Files\ESET\ESET NOD32 Antivirus\
[09/09/12 15:13:28] Local MSI package:
[09/09/12 15:13:28] Product icon:
[09/09/12 15:13:28] Product: deleted: Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\C3385CC8A814BB04B9618D2FB606B65F
[09/09/12 15:13:28] Components to be deleted:
[09/09/12 15:13:28] 03139C179F67D4E4A97C523DE3706F10: OK
[09/09/12 15:13:28] 04F876A3AF093694682AABF14B2D5FC9: OK
[09/09/12 15:13:28] 05389A10D9DB79B45A7B9E39ACFF864F: OK
[09/09/12 15:13:28] 07EB4518810559B40A79932EE50BE7F5: OK
[09/09/12 15:13:28] 0C1F3F321A45C494FAA8976CCE0DE1F8: OK
[09/09/12 15:13:28] 0CB457A327B072241B25B3C4B39428D8: OK
[09/09/12 15:13:28] 0DDB707940D51AB4BA7E6333F7AE63DD: OK
[09/09/12 15:13:28] 0F398211D9F834B4F97332459D044833: OK
[09/09/12 15:13:28] 0F6CAC1C63591BA4DB0FCB993B236F88: OK
[09/09/12 15:13:28] 118F6C30F08C60C4CA0A8A15050A4B6F: OK
[09/09/12 15:13:28] 125CA6C985CC3F149B49249576C63BE9: OK
[09/09/12 15:13:28] 14E59F0BB78B5C44997064B4D0572D34: OK
[09/09/12 15:13:28] 166211B0FDBEB0E479FD760451390E68: OK
[09/09/12 15:13:28] 1791D8E495BE01444AC4377E39633D1C: OK
[09/09/12 15:13:28] 17B65B29E60958E4CB0A5966091FAF36: OK
[09/09/12 15:13:28] 18717E41F9668CD44BC4BBEFE81B4431: OK
[09/09/12 15:13:28] 196A5D6DD47DE054AA9D2246A8A634BF: OK
[09/09/12 15:13:28] 1BCC03AA176C80242926F43CB9D599AC: OK
[09/09/12 15:13:28] 1D65534611F45924286EB6BBB287741A: OK
[09/09/12 15:13:28] 1DFCF6B172284B94CBB80A82C7C0C831: OK
[09/09/12 15:13:28] 1E918D28F22454546870708C040317B3: OK
[09/09/12 15:13:28] 1E96DBF700EF3274DA532BB593C2568E: OK
[09/09/12 15:13:28] 1F1EC1E9CC59D974E81E023E0C21C86F: OK
[09/09/12 15:13:28] 1F9CBB48AA138584BBE8906E63E292F4: OK
[09/09/12 15:13:28] 2009601E73E541D4399C154432683323: OK
[09/09/12 15:13:28] 2128A1E098B387C43AD2B2B13C727EFC: OK
[09/09/12 15:13:28] 2156DBDE51CD0A143BD3581588276FCC: OK
[09/09/12 15:13:28] 223649EF7F7623747BAF948F8EE018D5: OK
[09/09/12 15:13:28] 2550C4BB24E4FE64DA41688038A9786B: OK
[09/09/12 15:13:28] 28589CB55F447F945AE5C41849D8FD06: OK
[09/09/12 15:13:28] 28C9FA4A1AA6C0E49A44F447917691EC: OK
[09/09/12 15:13:28] 2955FABEFF900474BAAA26E00EE27EB8: OK
[09/09/12 15:13:28] 2A0B3299E527CB742BDABFFA07276127: OK
[09/09/12 15:13:28] 2BD5262596C2BF6489BCDAE4E1F177E6: OK
[09/09/12 15:13:28] 2DB66E5D20C11324E9FDD0CB8A698A8B: OK
[09/09/12 15:13:28] 2F6CE7FABE4BFF848A117931E4A7DE1B: OK
[09/09/12 15:13:28] 3116BD4BB74ABA644B2AB6264DD66BAA: OK
[09/09/12 15:13:28] 3163249A337DD294C98C28A0E2B2B36B: OK
[09/09/12 15:13:28] 320ECDDE4CB8BB24ABD7B0CF684009CF: OK
[09/09/12 15:13:28] 368B62A0EAEA6994191B625ACBB23BC6: OK
[09/09/12 15:13:28] 3B125574D1666904580CC1E623C8BCFB: OK
[09/09/12 15:13:28] 3D4CEB2D7F23BA34481D0DDF154ACF78: OK
[09/09/12 15:13:28] 3EE28FEDB87969F4CBD8880288ED0DFA: OK
[09/09/12 15:13:28] 43DB563630FA92940A632AA8688A4733: OK
[09/09/12 15:13:28] 4AA2B8DDB6D101543957F6FE99404130: OK
[09/09/12 15:13:28] 4BF871AB9EEE4AA4AA4E10A18CC2CD47: OK
[09/09/12 15:13:28] 4E74A84E5FABD3B4C96D8FA017293CCA: OK
[09/09/12 15:13:28] 4E792871BFC0DB44081680109E768A02: OK
[09/09/12 15:13:28] 5027857A6C2E7444EBD39E06EAF26A5C: OK
[09/09/12 15:13:28] 516533BE3AD2FFA469CAA909E90B11DE: OK
[09/09/12 15:13:28] 51EFD702B63339B4998D677ED658DE17: OK
[09/09/12 15:13:28] 5A36F2F6FE5BD3041A4FA0886DDD01D9: OK
[09/09/12 15:13:28] 5AB6015048AF6D847B5AB58F62C9FC60: OK
[09/09/12 15:13:28] 5C80B84CB85A38F4982CC61383C965A9: OK
[09/09/12 15:13:28] 5CA74BF925BBA79449ED5B8815184F22: OK
[09/09/12 15:13:28] 5F20CB1929551104F81331244924394B: OK
[09/09/12 15:13:28] 64AD38B5EB6E91045B3D83F31FDD4687: OK
[09/09/12 15:13:28] 66C9CF24BE7EE5B46BE0D7B6C98091C2: OK
[09/09/12 15:13:28] 67EFE0F40361AF245B1ABAA74E6EC81F: OK
[09/09/12 15:13:28] 6821A5C1EA332064A877E815DC6FD0CF: OK
[09/09/12 15:13:28] 68A7E1B902668684B91A83823575AB11: OK
[09/09/12 15:13:28] 68CAD13F16BDFBC449AF217F627BCD61: OK
[09/09/12 15:13:28] 698814050F01DD44FADAC916CB05571A: OK
[09/09/12 15:13:28] 6E35672F5F652604BA95EE0B5E17B472: OK
[09/09/12 15:13:28] 70B80209DF83DCF4B90852EB050AABDA: OK
[09/09/12 15:13:28] 718EB7B38F102C54A94335AF3D48F98C: OK
[09/09/12 15:13:28] 72C046FCF13AB7046A322D14D6A3961E: OK
[09/09/12 15:13:28] 73B96C5CA28636C459AA683F90C4497C: OK
[09/09/12 15:13:28] 73EB5CEB9D3CB4245AF23E63AB34230D: OK
[09/09/12 15:13:28] 7593C6660FCA2E942A18FA5318AE091C: OK
[09/09/12 15:13:28] 7A01FEDE10D24B7499E3F173A59C5946: OK
[09/09/12 15:13:28] 7A461B86D41D5F140808175FC217029E: OK
[09/09/12 15:13:28] 7C5CA713502551444A6157013BF9B3B4: OK
[09/09/12 15:13:28] 7CB4FAC7CAE4A134A84D7BEB3121F722: OK
[09/09/12 15:13:28] 7CC2B33FAF6E3ED43A49C0F47156347D: OK
[09/09/12 15:13:28] 7D14C7438A049354FADDE05D5E9DAD58: OK
[09/09/12 15:13:28] 7D2EF30EF431A5549BA2C56C5F03FB90: OK
[09/09/12 15:13:28] 7EA86F58DF65C1840B3B9B667E8D563F: OK
[09/09/12 15:13:28] 7F6C618D92747EB4AA062C39550AC3E1: OK
[09/09/12 15:13:28] 7FA0F42FC4E0CF842809477074C51B16: OK
[09/09/12 15:13:28] 7FB60C255DB5EBC429D01C10DD90903D: OK
[09/09/12 15:13:28] 8045D7AEC73A0DA41B5A7CBFA308A7E3: OK
[09/09/12 15:13:28] 82026FD9D93849D418F24C9C7C3F12FD: OK
[09/09/12 15:13:28] 83107C736B6FE134FAB2C91D72F44DB7: OK
[09/09/12 15:13:28] 83B3F68DA0D070843875649FCC9CE38A: OK
[09/09/12 15:13:28] 863A58D3052A4124F8E567CDB3AC170E: OK
[09/09/12 15:13:28] 87217CF586737ED40B93B3F219E07C5A: OK
[09/09/12 15:13:28] 89445F442B273E64AA7EA8F258614F48: OK
[09/09/12 15:13:28] 8972773B3651A1C459F98BA85B03C8FD: OK
[09/09/12 15:13:28] 89DF32188751C7A44A1BA3C15F9A226E: OK
[09/09/12 15:13:28] 8D68BD3073486634E94624F0C55E9F99: OK
[09/09/12 15:13:28] 8DE03EDDC0056104C9D4FD0DC4C1F64C: OK
[09/09/12 15:13:28] 8DF4EEE9844D8174D816CEF30E6E007A: OK
[09/09/12 15:13:28] 8E7BD5F5C9EA59542AE2F617B5A93E56: OK
[09/09/12 15:13:28] 929570A31C3D3AB4C9930E5B04CEB175: OK
[09/09/12 15:13:28] 92A6AA3C2D60869478EA937187ACB757: OK
[09/09/12 15:13:28] 9860416EE893B2B4C9D8A62E4D37881C: OK
[09/09/12 15:13:28] 98871B43DB785AD44A550F6347ED9683: OK
[09/09/12 15:13:28] 9C10769161459844F9132A7DCEE05023: OK
[09/09/12 15:13:28] 9C9A4412656C0754B8C596913E24439B: OK
[09/09/12 15:13:28] 9DF66A75721F195468D27EBB204DBC30: OK
[09/09/12 15:13:28] 9E11AC87DBA2DA447AE576C6A4139AA9: OK
[09/09/12 15:13:28] 9FA08B728B3311341BFF09BA10C3B599: OK
[09/09/12 15:13:28] A04FBF94BDF0AF141BFC09E5D9C32105: OK
[09/09/12 15:13:28] A1ED5649D3D48CA46BF4F34F06BB18B1: OK
[09/09/12 15:13:28] A3389D66CA8792A43AC0B1F67F736CFC: OK
[09/09/12 15:13:28] A34E9CEE5F57B37499C4618D3F33F975: OK
[09/09/12 15:13:28] A38179F0FFD7F104283692B2D3324AF2: OK
[09/09/12 15:13:28] A3EF62200285C284C91EE740AC93DF67: OK
[09/09/12 15:13:28] A5D81A04A6CFD3E489C1CC9AA058B627: OK
[09/09/12 15:13:28] A7531734040C9CF4C8787685710A759A: OK
[09/09/12 15:13:28] A7D6914096DEEE14BAE073D525C11312: OK
[09/09/12 15:13:28] A9DD4488F491DDA40B45AF3EC22099FF: OK
[09/09/12 15:13:28] A9E7411461A1A1F4E97FF55FE6370A55: OK
[09/09/12 15:13:28] AAFC50C7633718C44B4ED69A1AD15783: OK
[09/09/12 15:13:28] AC9798547E179AE4BA013CCAB5280685: OK
[09/09/12 15:13:28] AD998482FF43E4F4BB8CB09024C805CE: OK
[09/09/12 15:13:28] B2D701CF0B7094F49887F7DB9D7C8DE5: OK
[09/09/12 15:13:28] B5EE7AEC9E0212D40838D0371372101F: OK
[09/09/12 15:13:28] B74C05674F911F4439A22ECD98902107: OK
[09/09/12 15:13:28] B7826DFF800CF2742B3789B28D5CCC56: OK
[09/09/12 15:13:28] B7AE80E8760C8F1479A8F6C9639D254E: OK
[09/09/12 15:13:28] BBC89AAA7A49CC04DA37D3C4EF623F83: OK
[09/09/12 15:13:28] BD2D1B6DB1C4A3343994B3A8F1B3A756: OK
[09/09/12 15:13:28] BEE7DCD4D29F32D43B15E351898F8A4F: OK
[09/09/12 15:13:28] C0344A5E261C1704387AD2BAA9457F3A: OK
[09/09/12 15:13:28] C097373CC2FF80240814F30AA807CD29: OK
[09/09/12 15:13:28] C63E6B9A62E61DA4DB8522744EEA1198: OK
[09/09/12 15:13:28] C7C33FB0A41C2B341AE18A9130B0372D: OK
[09/09/12 15:13:28] CDE79E094A072864BAE86FE44708C09E: OK
[09/09/12 15:13:28] CEB24083B2C25CA45B3E027CB59B224B: OK
[09/09/12 15:13:28] CFEF110B23AA5EB40A4132DC68DDB02F: OK
[09/09/12 15:13:28] D4F2F0C126881EF47A6E6A40CE229E93: OK
[09/09/12 15:13:28] D571557FC5B24524284038E7904CF42F: OK
[09/09/12 15:13:28] D73F0E6B5866E7F43B8FADDFE09BB9C6: OK
[09/09/12 15:13:28] D7F1576685ECDA347BE021A72B3C3E34: OK
[09/09/12 15:13:28] DB75C87B1D7A43B4E8A881D1453D202D: OK
[09/09/12 15:13:28] E23A7A7EB64186F468BD542D9F6CE18A: OK
[09/09/12 15:13:28] E647CC3EE8DE37D4AA9C99141AF466BC: OK
[09/09/12 15:13:28] E9D5EA9AF2EF43D44B71348B4F97CC6B: OK
[09/09/12 15:13:28] EA0A97C7B3008DD43A3271F9AD13D494: OK
[09/09/12 15:13:28] EBBDC76732CE0CB4C87E8FD3205447DB: OK
[09/09/12 15:13:28] EC06BA51F125A2A4DB6B36CC6B54293E: OK
[09/09/12 15:13:28] F0B61F72C3BFF1347AD9A544AF929122: OK
[09/09/12 15:13:28] F11F90B3C080A40409AC24F0972E38A2: OK
[09/09/12 15:13:28] F2EF98DF855109D4FABAC4FF2932E47E: OK
[09/09/12 15:13:28] FAB7AF525CCA6784A9DDE884C8F24FA1: OK
[09/09/12 15:13:28] FBC20012DAD40F94985C6BFEAEC52B69: OK
[09/09/12 15:13:28] FC7C95A3BF0A57142A43B4472ED8BD12: OK
[09/09/12 15:13:28] FDDDFC1CE292E2F4FAD118C2B92CE5FF: OK
[09/09/12 15:13:28] FFDE61E080F38D845964F4A2DEFA3BD2: OK
[09/09/12 15:13:28] Upgrade codes: deleted value in: Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes\79AA332A50D011E4585D700F695D0537 ...
[09/09/12 15:13:28] deleted: C3385CC8A814BB04B9618D2FB606B65F
[09/09/12 15:13:28] Upgrade codes: deleted: Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes\79AA332A50D011E4585D700F695D0537
[09/09/12 15:13:28] Classes: Product: deleted: Classes\Installer\Products\C3385CC8A814BB04B9618D2FB606B65F
[09/09/12 15:13:28] Classes: Feature: deleted: Classes\Installer\Features\C3385CC8A814BB04B9618D2FB606B65F
[09/09/12 15:13:28] Upgrade codes: deleted value in: Classes\Installer\UpgradeCodes\79AA332A50D011E4585D700F695D0537 ...
[09/09/12 15:13:28] Upgrade codes: deleted: Classes\Installer\UpgradeCodes\79AA332A50D011E4585D700F695D0537
[09/09/12 15:13:28] Install directory: deleted: C:\Program Files\ESET\ESET NOD32 Antivirus\
[09/09/12 15:13:28] Delete of empty folders ...
[09/09/12 15:13:28] ESET folder: deleted: C:\Documents and Settings\All Users\Menu Start\Programy\ESET\
[09/09/12 15:13:28] Installer folders: deleted value in: Microsoft\Windows\CurrentVersion\Installer\Folders ...
[09/09/12 15:13:28] deleted: C:\Documents and Settings\All Users\Menu Start\Programy\ESET\
[09/09/12 15:13:28] ESET folder: deleted: C:\Documents and Settings\All Users\Dane aplikacji\ESET\
[09/09/12 15:13:28] deleted: C:\Documents and Settings\All Users\Dane aplikacji\ESET\
[09/09/12 15:13:28] ESET folder: deleted: C:\Program Files\ESET\
[09/09/12 15:13:28] deleted: C:\Program Files\ESET\
[09/09/12 15:13:28] ESET Product: deleted: ESET\ESET Security
[09/09/12 15:13:28] ESET Product: deleted: ESET\Setup
[09/09/12 15:13:28] ESET Product: deleted: ESET\NOD\CurrentVersion\InstalledComponents\V3
[09/09/12 15:13:28] ESET Product: deleted value in: ESET\NOD\CurrentVersion\Info ...
[09/09/12 15:13:28] deleted: InstallDir
[09/09/12 15:13:28] ESET Product: deleted: ESET\NOD\CurrentVersion\Info
[09/09/12 15:13:28] Uninstallation ESS/EAV/EMSX finished successfully.
[09/09/12 15:13:29] Log file location: "E:\MOJE PLIKI\2011-05-25\Soft do PC\~ESETUninstaller.log"
[09/09/12 15:13:29] Uninstallation finished successfully, please restart your PC now.
[09/09/12 15:13:29] Press any key to exit ...
>>>>>>>>>>>>>>>>>>>>>>>> END >>>>>>>>>>>>>>>>>>>>>>>>
