Pobrałem sterownik graficzny z oficjalnej strony nvidia. Moja karta graficzna to gtx 650ti. Wypakowałem wszystkie pliki z pobranego folderu, nadałem uprawnienia “+x” dla pliku “nvidia-installer” i wszystko pięknie się robi do czasu gdzie jest pytanie “Install NVIDIA’S 32-bit compatibility libraries?”, naciskam “Yes” i wywala błąd “instalation failed” (to samo się dzieje gdy nacisnę “No”.
Wyciąg z nvidia-installer.log:
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Fri Oct 11 11:51:27 2019
installer version: 430.50PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
nvidia-installer command line:
/home/szymon/Pobrane/2/nvidia-installerUsing: nvidia-installer ncurses v6 user interface
-> Detected 6 CPUs online; setting concurrency level to 6.
-> Installing NVIDIA driver version 430.50.
-> An alternate method of installing the NVIDIA driver was detected. (This is usually a package provided by your distributor.) A driver installed via that method may integrate better with your system than a driver installed by nvidia-installer.Please review the message provided by the maintainer of this alternate installation method and decide how to proceed:
The NVIDIA driver provided by Ubuntu can be installed by launching the “Software & Updates” application, and by selecting the NVIDIA driver from the “Additional Drivers” tab.
(Answer: Continue installation)
-> Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: Yes)
-> Install NVIDIA’s 32-bit compatibility libraries? (Answer: Yes)
-> Will install GLVND GLX client libraries.
-> Will install GLVND EGL client libraries.
-> Skipping GLX non-GLVND file: “libGL.so.430.50”
-> Skipping GLX non-GLVND file: “libGL.so.1”
-> Skipping GLX non-GLVND file: “libGL.so”
-> Skipping EGL non-GLVND file: “libEGL.so.430.50”
-> Skipping EGL non-GLVND file: “libEGL.so”
-> Skipping EGL non-GLVND file: “libEGL.so.1”
-> Skipping GLX non-GLVND file: “./32/libGL.so.430.50”
-> Skipping EGL non-GLVND file: “./32/libEGL.so.430.50”
Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh
executing: ‘/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh’…
Checking for libglvnd installation.
Missing test program: /home/szymon/Pobrane/2/libglvnd_install_checker/check-entrypoint
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
