Problem z instalacją Virtual Box na Debian 6 - vboxdrv
Jakoś zainstalowałem w końcu tego nieszczęsnego virtualboxa ale teraz mam coś takiego:
WARNING: The vboxdrv kernel module is not loaded. Either there is no module
         available for the current kernel (2.6.32-042stab057.1) or it failed to
         load. Please recompile the kernel module and install it by
           sudo /etc/init.d/vboxdrv setup
         You will not be able to start VMs until this problem is fixed.
Failed to open the X11 display!
Ok, więcj próbuje sudo /etc/init.d/vboxdrv setup co skutkuje:
WARNING: Deprecated config file /etc/modprobe.conf, all config files belong into /etc/modprobe.d/.
 * Stopping VirtualBox kernel modules
   ...done.
 * Uninstalling old VirtualBox DKMS kernel modules
   ...done.
 * Trying to register the VirtualBox kernel modules using DKMS
Error! Your kernel headers for kernel 2.6.32-042stab057.1 cannot be found.
Please install the linux-headers-2.6.32-042stab057.1 package,
or use the --kernelsourcedir option to tell DKMS where it's located
 * Failed, trying without DKMS
 * Recompiling VirtualBox kernel modules
 * Look at /var/log/vbox-install.log to find out what went wrong
Co robić? :confused:
Co jest w tym pliku?
Podaj wynik:
uname -r
Czy system jest na bieżąco aktualizowany? Może pomóc instalacja nowszego jądra i ponowna instalacja virtualbox. Podaj wynik:
apt-cache search linux-image-*
Przeinstalowałem system na Debian’a 6 ale i tak mam to co w pierwszym poście …
vbox-install.log:
Mój linux stoi na vps’ie
Uninstalling modules from DKMS
  removing old DKMS module vboxhost version 4.1.20
-------- Uninstall Beginning --------
Module: vboxhost
Version: 4.1.20
Kernel: 2.6.32-5-amd64 (x86_64)
Status: Before uninstall, this module version was ACTIVE on this kernel.
vboxdrv.ko:
 - Uninstallation
   - Deleting from: /lib/modules/2.6.32-5-amd64/
 - Original module
   - No original module was found for this module on this kernel.
   - Use the dkms install command to reinstall any previous module version.
vboxnetflt.ko:
 - Uninstallation
 - Original module
vboxnetadp.ko:
 - Uninstallation
 - Original module
vboxpci.ko:
 - Uninstallation
 - Original module
depmod....
DKMS: uninstall Completed.
Deleting module version: 4.1.20
completely from the DKMS tree.
Done.
Attempting to install using DKMS
Creating symlink /var/lib/dkms/vboxhost/4.1.20/source ->
                 /usr/src/vboxhost-4.1.20
DKMS: add Completed.
You can use the --kernelsourcedir option to tell DKMS where it's located, or you could install the linux-heade$
Failed to install using DKMS, attempting to install without
Makefile:172: *** Error: unable to find the sources of your current Linux kernel. Specify KERN_DIR=
uname -r: 2.6.32-042stab057.1
apt-cache searsch linux-image-*:
[code]alsa-base - ALSA driver configuration files linux-headers-2.6.32-5-amd64 - Header files for Linux 2.6.32-5-amd64 linux-headers-2.6.32-5-openvz-amd64 - Header files for Linux 2.6.32-5-openvz-amd64 linux-headers-2.6.32-5-vserver-amd64 - Header files for Linux 2.6.32-5-vserver-amd64 linux-headers-2.6.32-5-xen-amd64 - Header files for Linux 2.6.32-5-xen-amd64 linux-image-2.6.32-5-amd64-dbg - Debugging infos for Linux 2.6.32-5-amd64 linux-image-2.6.32-5-amd64 - Linux 2.6.32 for 64-bit PCs linux-image-2.6.32-5-openvz-amd64-dbg - Debugging infos for Linux 2.6.32-5-openvz-amd64 linux-image-2.6.32-5-openvz-amd64 - Linux 2.6.32 for 64-bit PCs, OpenVZ support linux-image-2.6.32-5-vserver-amd64-dbg - Debugging infos for Linux 2.6.32-5-vserver-amd64 linux-image-2.6.32-5-vserver-amd64 - Linux 2.6.32 for 64-bit PCs, Linux-VServer support linux-image-2.6.32-5-xen-amd64-dbg - Debugging infos for Linux 2.6.32-5-xen-amd64 linux-image-2.6.32-5-xen-amd64 - Linux 2.6.32 for 64-bit PCs, Xen dom0 support linux-image-2.6-amd64 - Linux 2.6 for 64-bit PCs (meta-package) linux-image-2.6-openvz-amd64 - Linux 2.6 for 64-bit PCs (meta-package), OpenVZ support linux-image-2.6-vserver-amd64 - Linux 2.6 for 64-bit PCs (meta-package), Linux-VServer support linux-image-2.6-xen-amd64 - Linux 2.6 for 64-bit PCs (meta-package), Xen dom0 support linux-image-amd64 - Linux for 64-bit PCs (meta-package) linux-image-openvz-amd64 - Linux for 64-bit PCs (meta-package), OpenVZ support linux-image-vserver-amd64 - Linux for 64-bit PCs (meta-package), Linux-VServer support linux-image-xen-amd64 - Linux for 64-bit PCs (meta-package), Xen dom0 support nvidia-kernel-2.6.32-5-amd64 - NVIDIA binary kernel module for Linux 2.6.32-5-amd64 nvidia-kernel-2.6.32-5-vserver-amd64 - NVIDIA binary kernel module for Linux 2.6.32-5-vserver-amd64
smrodek11 , proszę zapoznaj się z tą stroną oraz tym tematem, a następnie,używając przycisku image.php?album_id=20&image_id=4038
Poprawione
No tak, przecież to stoi na OpenVZ … z tego co pamiętam to na tym Virtual Box’a nie odpalę … ;/
Pod jaką architekturę pobrałeś paczkę?
A spróbuj wpisać to polecenie jako root.
modprobe vboxdrv
Na openvz nie uruchomisz virtualbox.
