witam!
po odpaleniu setupa vs.net 2003 wyskakuje mi komunikat:
CYTAT
- Visual Studio .NET Prerequistites
Setup has detected that some of the system components that are installed on
your computer do not match the versions required for Visual Studio .NET. You
must install a different version of these compnents.
a potem:
CYTAT
Setup has detected that another program required the computer to reboot. You
must reboot the computer before installing Visual Studio .NET Prerequisities.
Once the system reboots, you need to restart setup.
killowalem juz wszystkie procesy w tle, po restarcie to samo…
moj config:
WinXP HE + .NET Framework 2.0
pozdrawiam
