Witam od jakiegoś czasu program Cheese nie widzi mojej kamerki i nie mam pomysłu jak to rozwiązać
przed podłączeniem kamerki:
lsub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 003: ID 047d:1022 Kensington Orbit Optical
Bus 003 Device 002: ID 1c4f:0002 SiGma Micro Keyboard TRACER Gamma Ivory
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
po podłączeniu kamerki
lsusb
Bus 001 Device 002: ID f007:a999
po wpisaniu hwinfo
hwinfo --usb
06: USB 00.0: 0000 Unclassified device
[Created at usb.122]
Unique ID: cLrx.yZATT+bSlJA
Parent ID: k4bc.029GFTetOb3
SysFS ID: /devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-2/1-2:1.0
SysFS BusID: 1-2:1.0
Hardware Class: unknown
Model: “Teslong Camera”
Hotplug: USB
Vendor: usb 0xf007 “Teslong Camera”
Device: usb 0xa999 “Teslong Camera”
Revision: “0.04”
Serial ID: “Teslong Camera”
Driver: “uvcvideo”
Driver Modules: “uvcvideo”
Device File: /dev/input/event13
Device Files: /dev/input/event13, /dev/input/by-id/usb-Teslong_Camera_Teslong_Camera_Teslong_Camera-event-if00, /dev/input/by-path/pci-0000:03:00.0-usb-0:2:1.0-event
Device Number: char 13:77
Speed: 480 Mbps
Module Alias: “usb:vF007pA999d0004dcEFdsc02dp01ic0Eisc01ip00in00”
Driver Info #0:
Driver Status: uvcvideo is active
Driver Activation Cmd: “modprobe uvcvideo”
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #10 (Hub)
