probuje zainstalowac gnupgp ale pojawiaja sie bledy o co biega? pomozcie
dzieki
gnupg-1.2.2# ./configure
checking build system type… i686-pc-linux-gnulibc1
checking host system type… i686-pc-linux-gnulibc1
checking target system type… i686-pc-linux-gnulibc1
checking for a BSD-compatible install… /usr/bin/install -c
checking whether build environment is sane… yes
checking for gawk… no
checking for mawk… mawk
checking whether make sets $(MAKE)… yes
checking which random module to use… default
checking whether use of /dev/random is requested… yes
checking for extra cipher modules… no
checking whether use of extensions is requested… yes
checking whether assembler modules are requested… yes
checking whether memory guard is requested… no
checking whether to enable experimental TIGER/192 digest support… no
checking whether to enable new-style experimental TIGER/192 digest support… no
checking whether to enable read-only SHA-384 and SHA-512 digest support… no
checking whether to enable external program execution… yes
checking whether to enable photo ID viewing… yes
checking whether to use a fixed photo ID viewer… no
checking whether to enable external keyserver helpers… yes
checking whether LDAP keyserver support is requested… yes
checking whether experimental external hkp keyserver support is requested… no
checking whether email keyserver support is requested… yes
checking whether keyserver exec-path is enabled… yes
checking whether included zlib is requested… no
checking whether use of capabilities is requested… no
checking whether to enable maintainer-specific portions of Makefiles… no
checking whether make sets $(MAKE)… (cached) yes
checking for gcc… gcc
checking for C compiler default output… configure: error: C compiler cannot cr eate executables
See `config.log’ for more details.
Zmiana tematu na mówiący o problemie
Areh
