razi3l
(Razi3lek)
3 Styczeń 2009 17:47
#1
Witam serdecznie. Od niemal godziny próbuję nagrać obraz płyty na DVD+R DL firmy TDK i wszystkie próby na marne, dlatego zwracam się do Was z wielką prośbą o pomoc. Wklejam log z ImgBurn:
I 18:40:20 Shutting down ASPI… I 18:40:20 Initialising SPTI… I 18:40:20 Searching for SCSI / ATAPI devices… I 18:40:21 Found 1 BD-RE! I 18:41:01 Operation Started! I 18:41:01 Source File: C:\Users\rjo\Desktop\Nowy folder\dgr-tlra.dvd I 18:41:01 Source File Sectors: 3 697 696 (MODE1/2048) I 18:41:01 Source File Size: 7 572 881 408 bytes I 18:41:01 Source File Volume Identifier: XGD2DVD_NTSC I 18:41:01 Source File Volume Set Identifier: 34672923 I 18:41:01 Source File Implementation Identifier: Sonic Scenarist 3.1 I 18:41:01 Source File File System(s): ISO9660; UDF (1.02) I 18:41:01 Destination Device: [0] MATSHITA BD-MLT UJ230AS 1.00 (F:) (ATAPI) I 18:41:01 Destination Media Type: DVD+R DL (Disc ID: RITEK-S04-66) (Speeds: 2,4x) I 18:41:01 Destination Media Sectors: 3 827 520 I 18:41:01 Write Mode: DVD I 18:41:01 Write Type: DAO I 18:41:01 Write Speed: 2,4x I 18:41:01 Link Size: Auto I 18:41:01 Test Mode: No I 18:41:01 OPC: No I 18:41:01 BURN-Proof: Enabled I 18:41:01 Optimal L0 Data Zone Capacity: 1 913 760 I 18:41:01 Optimal L0 Data Zone Method: Copied From Original Disc W 18:41:05 Failed to set L0 Data Zone Capacity! W 18:41:05 Reason: Invalid Field in CDB I 18:41:05 Filling Buffer… (40 MB) I 18:41:05 Writing LeadIn… I 18:41:32 Writing Session 1 of 1… (1 Track, LBA: 0 - 3697695) I 18:41:32 Writing Track 1 of 1… (MODE1/2048, LBA: 0 - 3697695) I 18:41:32 Writing Layer 0… (LBA: 0 - 1913759) W 18:41:33 Failed to Write Sectors 3808 - 3839 - Reason: Unknown (0x09, 0x90) W 18:41:33 Retrying (1 of 20)… W 18:41:33 Retry Failed - Reason: Unable to Recover TOC W 18:41:33 Retrying (2 of 20)… W 18:41:33 Retry Failed - Reason: Unable to Recover TOC W 18:41:33 Retrying (3 of 20)… W 18:41:33 Retry Failed - Reason: Unable to Recover TOC W 18:41:33 Retrying (4 of 20)… W 18:41:33 Retry Failed - Reason: Unable to Recover TOC W 18:41:33 Retrying (5 of 20)… W 18:41:33 Retry Failed - Reason: Unable to Recover TOC W 18:41:33 Retrying (6 of 20)… W 18:41:33 Retry Failed - Reason: Unable to Recover TOC W 18:41:33 Retrying (7 of 20)… W 18:41:33 Retry Failed - Reason: Unable to Recover TOC W 18:41:33 Retrying (8 of 20)… W 18:41:33 Retry Failed - Reason: Unable to Recover TOC W 18:41:33 Retrying (9 of 20)… W 18:41:33 Retry Failed - Reason: Unable to Recover TOC W 18:41:33 Retrying (10 of 20)… W 18:41:33 Retry Failed - Reason: Unable to Recover TOC W 18:41:33 Retrying (11 of 20)… W 18:41:33 Retry Failed - Reason: Unable to Recover TOC W 18:41:33 Retrying (12 of 20)… W 18:41:33 Retry Failed - Reason: Unable to Recover TOC W 18:41:33 Retrying (13 of 20)… W 18:41:33 Retry Failed - Reason: Unable to Recover TOC W 18:41:33 Retrying (14 of 20)… W 18:41:33 Retry Failed - Reason: Unable to Recover TOC W 18:41:33 Retrying (15 of 20)… W 18:41:33 Retry Failed - Reason: Unable to Recover TOC W 18:41:33 Retrying (16 of 20)… W 18:41:33 Retry Failed - Reason: Unable to Recover TOC W 18:41:33 Retrying (17 of 20)… W 18:41:33 Retry Failed - Reason: Unable to Recover TOC W 18:41:33 Retrying (18 of 20)… W 18:41:33 Retry Failed - Reason: Unable to Recover TOC W 18:41:33 Retrying (19 of 20)… W 18:41:33 Retry Failed - Reason: Unable to Recover TOC W 18:41:33 Retrying (20 of 20)… W 18:41:33 Retry Failed - Reason: Unable to Recover TOC E 18:41:46 Failed to Write Sectors 3808 - 3839 - Reason: Unknown (0x09, 0x90) I 18:41:47 Synchronising Cache… W 18:41:50 User opted to skip the ‘Close Track/Session/Disc’ functions. E 18:41:50 Failed to Write Image! I 18:41:50 Exporting Graph Data… I 18:41:50 Graph Data File: C:\Users\rjo\AppData\Roaming\ImgBurn\Graph Data Files\MATSHITA_BD-MLT_UJ230AS_1.00_3-STYCZEŃ-2009_18-41_RITEK-S04-66_2,4x.ibg I 18:41:50 Export Successfully Completed! E 18:41:50 Operation Failed! - Duration: 00:00:49 I 18:41:50 Average Write Rate: 544 KB/s (0.4x) - Maximum Write Rate: 544 KB/s (0.4x)
Jak widać początkowo błąd “Invalid Field in CDB” a następnie “Unable to Recover TOC”. Szukałem o tym pierwszym błędzie odpowiedzi na google, natomiast radzą oni jedynie zmienić płytę lub przestawić interfejs nagrywania na ASPI. Macie jakieś pomysły? Za wszelkie rady z góry serdecznie dziękuje!
