Windows XP 5.1 IA32 WinAspi: - ahead WinASPI: File ‘C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll’: Ver=2.0.1.74, size=164112 bytes, created 2004-11-02 13:54:32 NT-SPTI used Nero Version: 7.2.3.2 Internal Version: 7, 2, 3, 2 Recorder: Version: 4S07 - HA 1 TA 0 - 7.2.3.2 Adapter driver: HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ? CD-ROM: Version: FS09 - HA 1 TA 1 - 7.2.3.2 Adapter driver: HA 1 === Scsi-Device-Map === CdRomPeripheral : LITE-ON CD-RW SOHR-5238S atapi Port 0 ID 0 DMA: Off CdRomPeripheral : LITE-ON DVD SOHD-16P9S atapi Port 0 ID 1 DMA: On DiskPeripheral : ST380011A atapi Port 1 ID 0 DMA: On CdRomPeripheral : SCSIVAX DVD/CD-ROM 2.7a Vax347s Port 2 ID 0 DMA: Off === CDRom-Device-Map === LITE-ON CD-RW SOHR-5238S E: CDRom0 LITE-ON DVD SOHD-16P9S F: CDRom1 SCSIVAX DVD/CD-ROM G: CDRom2 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 40894464 (0) Byte BUFE : 0 Physical memory : 255MB (261616kB) Free physical memory: 45MB (46324kB) Memory in use : 82 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 18.8.2006 CD-ROM (ISO) 18:19:55 #1 Text 0 File Isodoc.cpp, Line 6427 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : FALSE Multisession : TRUE Multisession type: : Start multisession Burning mode : TAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 18:19:55 #2 Text 0 File Burncd.cpp, Line 3086 LITE-ON CD-RW SOHR-5238S Włączono System ochrony zapisu 18:19:55 #3 Text 0 File ThreadedTransfer.cpp, Line 531 ReadBuffer-Pipe got 39936KB of Memory 18:19:55 #4 Text 0 File Reader.cpp, Line 124 Reader running 18:19:55 #5 Text 0 File Writer.cpp, Line 113 Writer E: LITE-ON CD-RW SOHR-5238S running 18:19:55 #6 ISO9660GEN -11 File Geniso.cpp, Line 3312 First writeable address = 0 (0x00000000) 18:19:55 #7 Text 0 File Burncd.cpp, Line 3400 Turn on Track-At-Once, using CD-R/RW media 18:19:56 #8 Text 0 File DlgWaitCD.cpp, Line 289 Last possible write address on media: 359848 ( 79:59.73) Last address to be written: 358860 ( 79:46.60) 18:19:56 #9 Text 0 File DlgWaitCD.cpp, Line 301 Write in overburning mode: NO (enabled: CD) 18:19:57 #10 Text 0 File DlgWaitCD.cpp, Line 2715 Recorder: LITE-ON CD-RW SOHR-5238S; CDR code: 00 97 17 06; OSJ entry from: Moser Baer India Limited ATIP Data: Special Info [hex] 1: 00 00 00, 2: 00 00 00 (LI 0:00.00), 3: 00 00 00 (LO 0:00.00) Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid) 18:19:57 #11 Text 0 File DlgWaitCD.cpp, Line 473 >>> Protocol of DlgWaitCD activities: <<< ========================================= 18:19:57 #12 Text 0 File ThreadedTransferInterface.cpp, Line 847 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 358861 (358861) = #358861/79:44.61 relocatable, disc pos for caching/writing not required/ required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 358859 blocks [E] -------------------------------------------------------------- 18:19:57 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1059 Prepare recorder [E] for write in TAO DAO infos: ========== MCN: “” TOCType: 0x00; Session Closed, disc not fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 735254528, ISRC “” DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ -150 | lead-in | 0 | 0x41 | 0x00 -150 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 358861 | lead-out | 1 | 0x41 | 0x00 18:19:57 #14 Text 0 File ThreadedTransferInterface.cpp, Line 1127 Removed 2 run-out blocks from end of track 1. Length: 358861 -> 358859. 18:19:57 #15 Text 0 File SCSIPassThrough.cpp, Line 39 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 18:19:57 #16 Text 0 File SCSIPassThrough.cpp, Line 84 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 18:19:58 #17 Phase 24 File dlgbrnst.cpp, Line 1730 Caching of files started 18:19:58 #18 Text 0 File Burncd.cpp, Line 4231 Cache writing successful. 18:19:58 #19 Phase 25 File dlgbrnst.cpp, Line 1730 Caching of files completed 18:19:58 #20 Phase 36 File dlgbrnst.cpp, Line 1730 Burn process started at 52x (7 800 KB/s) 18:19:58 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2707 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 18:19:59 #22 Text 0 File MMC.cpp, Line 22035 Set BUFE: Buffer underrun protection -> ON , SMART-BURN : ON 18:21:32 #23 SPTI -600 File SCSIPassThrough.cpp, Line 291 E: CdRom0: SCSIStatus(x00) WinError(121) NeroError(-600) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00 Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00 Buffer x054f0000: Len x10000 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 18:21:32 #24 CDR -600 File Writer.cpp, Line 302 Device not available E: LITE-ON CD-RW SOHR-5238S 18:21:32 #25 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 18:21:32 #26 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader 18:21:35 #27 SPTI -1114 File SCSIPassThrough.cpp, Line 291 E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1114) Sense Key: 0x06 (KEY_UNIT_ATTENTION) Sense Code: 0x29 Sense Qual: 0x00 CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00 Sense Area: 0x70 00 06 00 00 00 00 0A 00 00 00 00 29 Buffer x0356b400: Len x20 18:21:35 #28 CDR -1114 File WriterStatus.cpp, Line 197 Reset occurred E: LITE-ON CD-RW SOHR-5238S 18:21:35 #29 TRANSFER -18 File WriterStatus.cpp, Line 197 Could not perform EndTrack 18:21:35 #30 CDR -201 File WriterStatus.cpp, Line 200 Invalid write state E: LITE-ON CD-RW SOHR-5238S 18:21:35 #31 TRANSFER -18 File WriterStatus.cpp, Line 200 Could not perform EndTrack 18:21:35 #32 Text 0 File MMC.cpp, Line 16846 start Close Session 18:21:35 #33 Phase 38 File dlgbrnst.cpp, Line 1730 Burn process failed at 52x (7 800 KB/s) Existing drivers: File ‘Drivers\PXHELP20.SYS’: Ver=2.03.28a, size=20640 bytes, created 2005-03-12 00:28:13 (Prassi/Veritas driver for win 2K) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
