K F 1A20-8218-0370-2363-8675-6029* Windows XP 5.1 IA32 WinAspi: File ‘Wnaspi32.dll’: Ver=4.71 (0001), size=45056 bytes, created 2006-07-26 16:02:03 ahead WinASPI: File ‘D:\Program Files\Ahead\nero\Wnaspi32.dll’: Ver=2.0.1.74, size=164112 bytes, created 2004-10-26 18:35:32 Nero Version: 6.6.0.17 Internal Version: 6, 6, 0, 17c (Nero Express) Recorder: Version: CS01 - HA 1 TA 1 - 6.6.0.17 Adapter driver: HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ATAPI CD-ROM: Version: 1.22 - HA 0 TA 1 - 6.6.0.17 Adapter driver: HA 0 === Scsi-Device-Map === DiskPeripheral : ST340810A atapi Port 0 ID 0 DMA: On CdRomPeripheral : PIONEER DVD-ROM DVD-116 atapi Port 0 ID 1 DMA: On CdRomPeripheral : LITE-ON DVDRW SHW-160H6S atapi Port 1 ID 1 DMA: On === CDRom-Device-Map === PIONEER DVD-ROM DVD-116 E: CDRom0 LITE-ON DVDRW SHW-160H6S F: CDRom1 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 40894464 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 255MB (261616kB) Free physical memory: 53MB (55116kB) Memory in use : 78 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 5.11.2006 Kompilacja ISO 08:18:50 #1 Text 0 File Isodoc.cpp, Line 6356 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : FALSE Multisession : TRUE Multisession type: : Start multisession Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 08:18:50 #2 Text 0 File Reader.cpp, Line 127 Reader running 08:18:50 #3 Text 0 File Writer.cpp, Line 122 Writer LITE-ON DVDRW SHW-160H6S running 08:18:50 #4 ISO9660GEN -11 File geniso.cpp, Line 3309 First writeable address = 0 (0x00000000) 08:18:50 #5 Text 0 File Burncd.cpp, Line 3233 Turn on Disc-At-Once, using DVD media 08:18:50 #6 Text 0 File DlgWaitCD.cpp, Line 270 Last possible write address on media: 2295103 (510:01.28, 4482MB) Last address to be written: 1761391 (391:25.16, 3440MB) 08:18:50 #7 Text 0 File DlgWaitCD.cpp, Line 282 Write in overburning mode: NO (enabled: CD) 08:18:50 #8 Text 0 File DlgWaitCD.cpp, Line 2483 Recorder: LITE-ON DVDRW SHW-160H6S, Media type: DVD+R Disc Manufacturer ID: MPOMEDIA, Media Type ID: 080, Product revision number: 0 Disc Application Code: 0, Extended Information Indicators: 3 08:18:50 #9 Text 0 File DlgWaitCD.cpp, Line 448 >>> Protocol of DlgWaitCD activities: <<< ========================================= 08:18:50 #10 Text 0 File ThreadedTransferInterface.cpp, Line 838 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 1761392 (1761392) = #1761392/391:25.17 relocatable, disc pos for caching/writing not required/ required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1761392 blocks [LITE-ON DVDRW SHW-160H6S] -------------------------------------------------------------- 08:19:04 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1051 Prepare recorder [LITE-ON DVDRW SHW-160H6S] for write in CUE-sheet-DAO DAO infos: ========== MCN: “” TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3607330816, ISRC “” DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0x00 0 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 1761392 | lead-out | 1 | 0x41 | 0x00 08:19:05 #12 Phase 24 File dlgbrnst.cpp, Line 1832 Caching of files started 08:19:05 #13 Text 0 File Burncd.cpp, Line 4120 Cache writing successful. 08:19:05 #14 Phase 25 File dlgbrnst.cpp, Line 1832 Caching of files completed 08:19:05 #15 Phase 36 File dlgbrnst.cpp, Line 1832 Burn process started at 6x (8 310 KB/s) 08:19:05 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2661 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 08:19:05 #17 Text 0 File Cdrdrv.cpp, Line 8892 ---- DVD Structure: Physical Format Information (00h) ---- Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD+R (10), Part Version: 1.0x (1) Disc Size: 120 mm, Maximum Rate: (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26053F h End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB) Data in Burst Cutting Area (BCA) does not exist Disc Application Code: 0 / 0 h Extended Information indicators: 3 h Disc Manufacturer ID: MPOMEDIA Media type ID: 080 Product revision number: 0 Number of Physical format information bytes in use in ADIP up to byte 63: 56 Media Specific [16…63]: 00 00 03 4D 50 4F 4D 45 - 44 49 41 30 38 30 00 38 …MPOMEDIA080.8 23 54 37 15 02 52 6C 02 - B4 63 15 15 0B 0A 08 08 #T7…Rl…c… 01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 … 08:19:05 #18 Text 0 File DVDR.cpp, Line 5839 Drive: LITE-ON DVDRW SHW-160H6S Book Type request [LO], rev 3: DVD-ROM Changing the Book Type was finished successfully, return code 0 08:19:05 #19 CDR -1207 File DVDR.cpp, Line 5269 Book Type automatically set to: DVD-ROM 08:19:05 #20 Text 0 File DVDPlusRW.cpp, Line 665 Start write address at LBA 0 DVD high compatibility mode: Yes 08:19:08 #21 SCSI -1046 File Cdrdrv.cpp, Line 1436 SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x09A70000 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x30 Sense Qual: 0x05 CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x30 0x05 08:19:08 #22 CDR -1046 File Writer.cpp, Line 311 Illegal disc 08:19:08 #23 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 08:19:08 #24 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader 08:19:08 #25 Phase 127 File dlgbrnst.cpp, Line 1832 Generating DVD high compatibility borders 08:19:08 #26 Phase 129 File dlgbrnst.cpp, Line 1832 Generating DVD borders completed successfully 08:19:08 #27 Text 0 File DVDR.cpp, Line 5839 Drive: LITE-ON DVDRW SHW-160H6S Book Type request [LO], rev 3: DVD+R Changing the Book Type was finished successfully, return code 0 08:19:08 #28 Phase 38 File dlgbrnst.cpp, Line 1832 Burn process failed at 6x (8 310 KB/s) Existing drivers: File ‘Drivers\ASPI32.SYS’: Ver=4.71 (0001) built by: WinDDK, size=16512 bytes, created 2006-07-26 16:02:03 File ‘Drivers\PXHELP20.SYS’: Ver=2.03.32a, size=20640 bytes, created 2006-06-01 23:11:06 (Prassi/Veritas driver for win 2K) File ‘Drivers\atapi.sys’: Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 2004-08-03 21:59:44 (Adapter driver for rec) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
