Witam,
Mam problem z nagraniem płyty DVD+R DoubleLayer (DVD9) przy pomocy programu Nero (zarówno wersja stare jak i najnowsza 9).
Pojawia się komunikat:
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 9.4.26.100
Internal Version: 9, 4, 26, 100
Recorder: <_NEC DVD_RW ND-3520AW> Version: 3.07 - HA 1 TA 0 - 9.4.26.100
Adapter driver: HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data
CD-ROM: Version: 1.4 - HA 1 TA 1 - 9.4.26.100
=== Scsi-Device-Map ===
CdRomPeripheral : _NEC DVD_RW ND-3520AW atapi Port 0 ID 0 DMA: On
DiskPeripheral : SAMSUNG HD753LJ atapi Port 1 ID 0 DMA: On
DiskPeripheral : HDT722516DLA380 atapi Port 2 ID 0 DMA: On
CdRomPeripheral : ELBY CLONEDRIVE 1.4 VClone Port 4 ID 0 DMA: Off
=== CDRom-Device-Map ===
_NEC DVD_RW ND-3520AW H: CdRom0
ELBY CLONEDRIVE I: CdRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2046MB (2095532kB)
Free physical memory: 1021MB (1045524kB)
Memory in use : 50 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
Check supported media : Disabled (0)
13.1.2010
Kompilacja ISO
14:54:22 #1 Text 0 File SCSIPTICommands.cpp, Line 430
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
14:54:23 #2 Text 0 File Isodoc.cpp, Line 6998
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
14:54:23 #3 ISO9660GEN -11 File Geniso.cpp, Line 3327
First writeable address = 0 (0x00000000)
14:54:23 #4 Text 0 File Burncd.cpp, Line 3572
Turn on Disc-At-Once, using DVD media
14:54:23 #5 Text 0 File DlgWaitCD.cpp, Line 313
Last possible write address on media: 4173823
Last address to be written: 4143791
14:54:23 #6 Text 0 File DlgWaitCD.cpp, Line 325
Write in overburning mode: NO (enabled: CD)
14:54:23 #7 Text 0 File DlgWaitCD.cpp, Line 2843
Recorder: _NEC DVD_RW ND-3520AW, Media type: DVD+R DL
14:54:23 #8 Text 0 File DlgWaitCD.cpp, Line 500
>>> Protocol of DlgWaitCD activities: <<<
14:54:23 #9 Text 0 File ThreadedTransferInterface.cpp, Line 739
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 4143792 (4143792) = #4143792/920:50.42
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 4143792 blocks [H]
14:54:23 #10 Text 0 File ThreadedTransferInterface.cpp, Line 941
Prepare [H] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 8486486016, ISRC ""
DAO layout:
___Start_|____ Track_|_Idx_|_CtrlAdr_| _____Size_|______ NWA_|_RecDep __________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 4143792 | 0 | 0x00
4143792 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
14:54:23 #11 Text 0 File SCSIPTICommands.cpp, Line 217
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
14:54:23 #12 Text 0 File Burncd.cpp, Line 4279
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
14:54:23 #13 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
14:54:23 #14 Text 0 File Burncd.cpp, Line 4401
Cache writing successful.
14:54:23 #15 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
14:54:23 #16 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 4x (5 540 KB/s)
14:54:23 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
14:54:23 #18 Text 0 File DVDPlusDualLayer.cpp, Line 1929
GetDriveCaps: LAST LBA of layer 1 is 0
14:54:23 #19 Text 0 File DVDPlusDualLayer.cpp, Line 1452
SetDriveCaps: Set LAST LBA of layer 1 to 2071903
14:54:23 #20 Text 0 File DVDPlusDualLayer.cpp, Line 1929
GetDriveCaps: LAST LBA of layer 1 is 2071903
14:54:23 #21 Text 0 File DVDPlusDualLayer.cpp, Line 614
Disc finalized, LBA total Image size: 4143792 (8093MB), Last LBA L0: 2071903 (4046MB)
14:55:23 #22 SPTI -1106 File SCSIPassThrough.cpp, Line 215
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106)
CDB Data: 0xBF 00 00 00 00 00 00 20 00 0C 00 00
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 73 03
Buffer x04ea7300: Len xc
0x00 0A 00 00 00 00 00 00 00 1F 9D 60
14:55:23 #23 Text 0 File DVDPlusDualLayer.cpp, Line 790
L0 Data Zone Capacity not set.
Max LBA L0 2086911 (1FD7FFh, 4075MB), next writable address 0 (0h, 0MB)
14:55:23 #24 Text 0 File DVDPlusDualLayer.cpp, Line 1452
SetDriveCaps: Set LAST LBA of layer 1 to 0
14:55:23 #25 CDR -1106 File ThreadedTransferInterface.cpp, Line 1693
Power calibration error
H: _NEC DVD_RW ND-3520AW
14:55:23 #26 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1693
Could not perform start of Disc-at-once
14:55:23 #27 Text 0 File DVDPlusDualLayer.cpp, Line 1452
14:55:23 #28 Text 0 File ThreadedTransfer.cpp, Line 273
Pipe memory size 83836800
14:55:24 #29 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 4x (5 540 KB/s)
14:55:24 #30 Text 0 File SCSIPTICommands.cpp, Line 267
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
14:55:28 #31 Text 0 File Cdrdrv.cpp, Line 11592
DriveLocker: UnLockVolume completed
14:55:28 #32 Text 0 File SCSIPTICommands.cpp, Line 430
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Proszę o podpowiedź czego może być to przyczyna i jak można naprawić ten błąd.
Dziękuję. Pozdrawiam.
