Otoz tak jak w temacie juz wspomnialem … nagrywarka nie nagrywa mi plyt DVD. Nagrywa plyty CD bez problemow zadnych, lecz gdy chce nagrac plyte DVD to zaczyna sie proces nagrywania i wystepuje po chwili blad jakis i plytka jest juz do wyrzucenia Nagrywam programem Nero 7 oraz Alcohol 120% build 3105. Apropo alcohola jeszcze, to wrzucam wam loga, ktory powstal podczas proby nagrania plyty DVD ta oto nagrywarka :
########################### System Information ###########################
Windows XP Professional 5.1 (Build 2600)
Processor info: AMD Athlon(tm) XP 2500+ (1824MHz)
Memory Available to Windows: 523 760 KB
############################ Program Information ###########################
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\Alcohol.exe
Company Name: Alcohol Soft Development Team
Description: Alcohol 120%
Original: alcohol.exe
Product: Alcohol 120%
Trademarks: Alcohol Soft Development Team
Copyright: Copyright(C) 2002-2005 Alcohol Soft Development Team
Version: 1.9.5 ( Build 3105 )
Date: 2005/07/09
Hash: 8830b1347218430dfe79710699417840
Hash(1): d1a6dcfed81ff332d01c55e3cbc5c0e68bc7c1025c3ae23577c953ca5d59955
Hash(2): 80965b475776dcff3fc125950300bc53e7fff35f2cb2cb2f83c727ad952c740
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\alcoholx.dll
Description: Alcohol virtual device control library
Original: alcoholx.dll
Copyright: Copyright (C) 2000-2004
Version: 3.47.0 ( Build 0 )
Date: 2004/08/12
Hash: 1b7083f2ca3a98bb3c14c3a08ad5c2d2
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\devsupp.dll
Description: Alcohol Software Device Capability Library
Original: devsupp.dll
Product: Alcohol Software Device Capability Library
Copyright: Copyright(C) 2002-2003 Alcohol Soft Development Team
Version: 2.4.0 ( Build 627 )
Date: 2005/07/31
Hash: cb8e209009b1a3fd93103fad4efe4085
########################### User Information ###########################
Licensed to: Happy User :)
Registered User ID: 04EF
########################### Options Setting ###########################
Devices control interface: Default Driver Control Interface
CPU Priority Level: High
Memory Buffer Size (MB): 128
Examine the accuracy of data read from physical device: Yes
Turn off "Auto-Select best write speed" function if possible: No
Overburn disc(s): No
Fill memory buffer before recording discs: Yes
Ignore Media Type: Yes
RMPS (Recordable Media Physical Signature) Emulation: Yes
BAD Sectors Emulation: Yes
Sub-Channel Data Fixed & Emulation: Yes
Laserlock Emulation: Yes
Current Language: English
############################ Device(s) List ############################
(E:) HL-DT-ST DVDRAM GSA-4165B (viadsk, Port 1, Bus 0, Target 0, Lun 0)
(D:) HL-DT-ST CD-RW GCE-8240B (viadsk, Port 1, Bus 0, Target 1, Lun 0)
(G:) CW3575M GYX151E (dtscsi, Port 3, Bus 0, Target 0, Lun 0)
##################### Installed Device Drivers List #####################
ACPI.sys afd.sys ALCXWDM.SYS ASPI32.SYS atapi.sys
audstub.sys Beep.SYS BOOTVID.dll Cdfs.SYS cdrom.sys
CLASSPNP.SYS disk.sys dmio.sys dmload.sys drmk.sys
dtscsi.sys dump_diskdump.sys dump_viadsk.sys dxg.sys dxgthk.sys
Fastfat.SYS fdc.sys Fips.SYS flpydisk.sys Fs_Rec.SYS
ftdisk.sys hal.dll i8042prt.sys Imapi.SYS ipsec.sys
irda.sys isapnp.sys kbdclass.sys KDCOM.DLL kl1.sys
klif.sys klmc.sys kmixer.sys ks.sys KSecDD.sys
mnmdd.SYS mouclass.sys moufiltr.SYS MountMgr.sys mrxdav.sys
mrxsmb.sys Msfs.SYS msgpc.sys Mup.sys NDIS.sys
ndistapi.sys ndisuio.sys ndiswan.sys NDProxy.SYS netbios.sys
netbt.sys Npfs.SYS ntdll.dll Ntfs.sys ntoskrnl.exe
Null.SYS nv4_disp.dll nv4_mini.sys parport.sys PartMgr.sys
ParVdm.SYS pci.sys PCIIDEX.SYS portcls.sys processr.sys
psched.sys ptilink.sys PxHelp20.sys R8139n51.SYS rasacd.sys
rasirda.sys rasl2tp.sys raspppoe.sys raspptp.sys raspti.sys
rdbss.sys RDPCDD.sys rdpdr.sys redbook.sys SCSIPORT.SYS
secdrv.sys serenum.sys serial.sys sptd.sys SPTD0653.SYS
sr.sys srv.sys swenum.sys sysaudio.sys tcpip.sys
TDI.SYS termdd.sys update.sys USBD.SYS usbehci.sys
usbhub.sys USBPORT.SYS usbuhci.sys vax347b.sys vax347s.sys
vga.sys viaagp1.sys viadsk.sys viaidexp.sys viapfd.sys
VIDEOPRT.SYS VolSnap.sys wanarp.sys watchdog.sys wdmaud.sys
win32k.sys WMILIB.SYS
################## Detailed Information of Device(s) ##################
(E:) HL-DT-ST DVDRAM GSA-4165B(1:0) detail information.
Vendor Identification: HL-DT-ST
Product Identification: DVDRAM GSA-4165B
Production Revision Level: DL03
Support recording method: DAO, RAW SAO, RAW SAO+SUB, RAW DAO(96), DVD DAO
BURN-Free Technology: Unknown
Auto-Select best write speed: Not Supported
*** NOT listed in Alcohol's database. Please report to development team
-* Note: This information below is provided by the unit, it might be inaccurate. *-
-* This software does not use this information! *-
Removable media: Yes
Version: ATAPI (INF-8090i/INF-8020i/INF-8028i)
Response Data Format: 02h
CD-R Read/Write: Yes/Yes
CD-RW Read/Write: Yes/Yes
Read CD-R Fixed Packet: Yes
Test Write: Yes
DVD-ROM Read: Yes
DVD-R Read/Write: Yes/Yes
DVD-RAM Read/Write: Yes/Yes
Audio Play: Yes
Composite Audio and Video Data Stream: No
Digital output (IEC958) on port 1 Supported: No
Digital output (IEC958) on port 2 Supported: No
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: Yes
CD-DA Commands supported: Yes
CD-DA Stream is Accurate: Yes
R-W Supported: No
R-W De-interleaved and Corrected: No
C2 Pointers Support: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Lock media into the drive: Yes
Currently drive Lock state: Unlocked
Prevent Jumper: No
Eject Command: Yes
Separate volume levels: Yes
Separate channel mute: Yes
Changer Supports Disc Present: No
Software slot selection: No
Side change capable: No
P through W in Lead-In: Yes
(D:) HL-DT-ST CD-RW GCE-8240B(1:1) detail information.
Product Identification: CD-RW GCE-8240B
Production Revision Level: 1.06
Support recording method: DAO, RAW SAO, RAW SAO+SUB, RAW DAO(96), TAO
BURN-Free Technology: ExacLink
Test Write: Yes
DVD-ROM Read: No
DVD-R Read/Write: No/No
DVD-RAM Read/Write: No/No
Audio Play: Yes
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: Yes
R-W Supported: Yes
C2 Pointers Support: No
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Prevent Jumper: No
Eject Command: Yes
(G:) CW3575M GYX151E(3:0) detail information.
Vendor Identification: CW3575M
Product Identification: GYX151E
Version: ANSI X3.131:1994 (SCSI-2)
CD-R Read/Write: Yes/No
CD-RW Read/Write: Yes/No
Test Write: No
DVD-ROM Read: Yes
DVD-R Read/Write: Yes/No
DVD-RAM Read/Write: Yes/No
Audio Play: Yes
Digital output (IEC958) on port 1 Supported: Yes
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: No
R-W Supported: Yes
R-W De-interleaved and Corrected: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Prevent Jumper: No
Eject Command: Yes
Separate volume levels: No
Separate channel mute: No
P through W in Lead-In: No
###################### Source Disc/Image Information ######################
Type: Standard ISO Image file
Path: C:\Nasiek\CALL.OF.DUTY.2-DEViANCE\
Session: 1
Track: 1
Session 01:
Track 01: DVD, Length: 1851322(3.53 GB), Address: 000000
####################### Dumping/Recording Progress Log #######################
17:08:28 Processor info: AMD Athlon(tm) XP 2500+ (1824MHz)
17:08:28 Memory Available to Windows: 523 760 KB
17:08:28 Memory Buffer size: 128 MB
17:08:28 Image file loading: C:\Nasiek\CALL.OF.DUTY.2-DEViANCE\dev-cod2.iso
17:08:28 DVD Source Info: Session: 1, Track: 1, Length: 3.53 GB / 411:24:22
17:08:31 (E:) HL-DT-ST DVDRAM GSA-4165B(1:0): Recording Method/Speed
17:11:35 Simulated recording - DVD DAO - 4.0X (5540 KB/Sec)
(E:) HL-DT-ST DVDRAM GSA-4165B(1:0) - Media format: DVD-R
17:11:38 (E:) HL-DT-ST DVDRAM GSA-4165B(1:0) - [Write ERROR] LBA: 0, Length: 16
S:KEY - 00/00/00 - "No Additional Sense Information"
17:11:57 (E:) HL-DT-ST DVDRAM GSA-4165B(1:0): Simulated recording failed!
17:11:58 Image file loading aborted!
17:11:59 Something is wrong with the recording procedure! Please check the log file and report any errors to Technical Support.
Moze ktos bedzie cos wiedzial na ten temat. Dodam jeszcze, ze mialem juz taki sam problem wczesniej z nagrywarka LG GSA - 4163 i dalem ja do serwisu bo mialem jeszcze na gwarancji. I oni w zamian za tamta nagrywarke dali mi wlasnie ta, o ktorej pisze. Tak wiec niemozliwe jest to, ze nagrywarka jest zla. Skoro dali mi nowa … Moze cos z systemem jest nie tak … ? Nie wiem juz sam. Prosze o opinie i porady w tym temacie . Z gory dziekuje !
PS:
W logu widac, ze dalem zamiast nagrywanie, opcje symulacji. Zaznaczylem tak specjalnie w celu sprawdzenia czy bedzie sie “nagrywalo”, by nie stracic plytki jak cos.
