Probuje nagrac plyte z danymi DL ale nie moge
Plyty sa firmy AONE moja nagrywarka to LG HL-DT-ST DCDRAM GSA-H42N
mam nero 7 wyskakuje error,ze nie moge wypalic plyty dokladnie
Could not perform start of Disc-at once
Uzywam tez CyberlinkPower2Go najnowsza wersje i to samo
skopiowalem komunikat jaki sie pokazal oto on:
User Name : Casper M
Company Name : Home 1
CDKey :
OS Version : Microsoft Windows XP Professional Service Pack 2
C:\Program Files\CyberLink\Power2Go\Power2Go.exe : Version 5.50.2706
CBS.dll : Version 7.07.0302
Total physical memory : 2046MB (2095600KB)
Free physical memory : 1669MB (1710012KB)
Memory load : 18 percent
Number of CPU : 1
CPU Name : Intel® Celeron® CPU 2.80GHz
CPU Speed : 2806 MHz
13.6.2007
Task Type : Data Disc
22:33:23, File(cl_DVDData.cpp), Line(186)
-> Begin burning process
Current drive:
Current writing speed(x): 8.0
====== Disc Info =======
Disc Type: DVD+R DL
Disc Status: Blank, Appendable
Num. of Sessions: 1 Num. of Tracks: 1
Book Type: DVD+R DL
Track Path:
Opposite Track Path
Diameter Length: 120mm Layer Counts: 2
Data Area Start PSN: 196608 End PSN: 16580607 End PSN on Layer 0: 2086912
End PSN : 120mm Layer Counts: 2
Disc Capacity: 4173824LBs
Free Size: 4173824LBs Used Size: 0LBs
Burn option: w/ buffer underrun protection
Burn option: w/o simulation
Burn option: w/o close disc
Burn option: w/o verify disc
FS type: ISO9660_JOLIET
22:33:23, file(cl_DVDData.cpp), line(2962)
-> Begin new track: 1
22:33:23, file(cl_DVDData.cpp), line(2992)
-> Write data
Last write LBA: 32
22:34:47, file(cl_DVDData.cpp), line(3105)
-> End new track
Czy ktokolwiek mial z tym problem?
Z gory dziekuje za okazana pomoc
