Mam problem z nagrywarką. Nie chce nagrywać płyt ( występuje błąd o komunikacie: “błąd kalibracji mocy” w Nero 10 ; lecz nie ma problemów z ich odtwarzaniem. Dodam że użytkuję jej dopiero rok w laptopie Asus k50ij.
Dołączam dziennik który pomoże w znalezieniu problemu. Proszę o pomoc.
19.8.2010
Kompilacja ISO
18:51:55 #1 Text 0 File SCSIPTICommands.cpp, Line 464
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
18:51:55 #2 Text 0 File Isodoc.cpp, Line 6956
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
18:51:55 #3 ISO9660GEN -11 File Geniso.cpp, Line 3336
First writeable address = 0 (0x00000000)
18:51:55 #4 Text 0 File Burncd.cpp, Line 3568
Turn on Disc-At-Once, using DVD media
18:51:55 #5 Text 0 File DlgWaitCD.cpp, Line 314
[G] Last possible write address on media: 2295103
Last address to be written: 2148687
18:51:55 #6 Text 0 File DlgWaitCD.cpp, Line 326
[G] Write in overburning mode: NO (enabled: CD)
18:51:55 #7 Text 0 File DlgWaitCD.cpp, Line 2890
Recorder: MATSHITA DVD-RAM UJ880AS, Media type: DVD+R
Disc Manufacturer ID: , Media Type ID: , Product revision number: 1
Disc Application Code: 0, Extended Information Indicators: 7
18:51:55 #8 Text 0 File DlgWaitCD.cpp, Line 499
[G] >>> Protocol of DlgWaitCD activities: <<<
18:51:55 #9 Text 0 File ThreadedTransferInterface.cpp, Line 785
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2148688 (2148688) = #2148688/477:29.13
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2148688 blocks [G]
18:51:55 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1001
Prepare [G] for write in CUE-sheet-DAO
DAO infos:
MCN: “”
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4400513024, ISRC “”
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2148688 | 0 | 0x00
2148688 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
MediaType: DVD+R
18:51:55 #11 Text 0 File SCSIPTICommands.cpp, Line 251
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
18:51:55 #12 Text 0 File Burncd.cpp, Line 4278
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
18:51:55 #13 PHASE 24 File dlgbrnst.cpp, Line 1827
Caching of files started
18:51:55 #14 Text 0 File Burncd.cpp, Line 4400
Cache writing successful.
18:51:55 #15 PHASE 25 File dlgbrnst.cpp, Line 1827
Caching of files completed
18:51:55 #16 PHASE 36 File dlgbrnst.cpp, Line 1827
Burn process started at 6x (8 310 KB/s)
18:51:55 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2769
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
18:51:55 #18 Text 0 File Cdrdrv.cpp, Line 10559
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Transfer Rate: (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Disc Manufacturer ID: MBIPG101
Media type ID: R05
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16…783]:
00 00 07 4D 42 49 50 47 - 31 30 31 52 30 35 01 38 …MBIPG101R05.8
23 54 37 13 02 50 6B 02 - 8C 63 15 15 0B 0B 08 08 #T7…Pk…c…
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 …
01 00 38 38 02 28 60 1A - 05 2E 23 10 04 1E 1D 01 …88.(`…#…
00 00 02 28 60 1A 05 2E - 23 10 04 1E 1D 01 00 00 …(`…#…
02 00 54 70 02 2E 62 3C - 24 14 0C 0C 01 20 00 00 …Tp…b<$…
00 00 02 3F 66 42 24 14 - 0C 0C 01 20 00 00 00 2F …?fB$…/
03 00 54 DF 02 2E 62 3C - 24 14 0C 0C 01 20 00 00 …T…b<$…
00 00 02 76 63 58 24 14 - 0C 0C 01 20 00 00 00 66 …vcX$…f
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 …
18:51:55 #19 SPTI -1066 File SCSIPassThrough.cpp, Line 217
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24
Buffer x0b1ff4c0: Len x648
18:51:55 #20 Text 0 File DVDPlusRW.cpp, Line 637
Start write address at LBA 0
DVD high compatibility mode: No
18:51:55 #21 Text 0 File ThreadedTransfer.cpp, Line 273
Pipe memory size 83836800
18:52:14 #22 SPTI -1106 File SCSIPassThrough.cpp, Line 217
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106)
CDB Data: 0x2A 00 00 00 03 00 00 00 20 00 00 00
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
Sense Area: 0xF1 00 03 00 00 00 00 0A 00 00 19 25 73 03
Buffer x10190640: Len x10000
0x41 25 5A 96 A2 BF DB 33 D1 63 C5 3B EB 3D 55 17
0x28 1F 2A 03 F5 53 05 EA DA 52 C2 A9 19 C0 53 DA
0x2E C1 49 52 7E D7 3D FE 5D CB 7C A5 3F A5 DB D6
18:52:14 #23 TRANSFER -60 File ThreadedTransfer.cpp, Line 1222
18:52:14 #24 CDR -1106 File Writer.cpp, Line 327
Power calibration error
G: MATSHITA DVD-RAM UJ880AS
18:52:14 #25 SPTI -1106 File SCSIPassThrough.cpp, Line 217
CDB Data: 0x5B 01 01 00 00 01 00 00 00 00 00 00
Sense Code: 0x73
Sense Qual: 0x03
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 19 25 73 03
18:52:14 #26 SPTI -1106 File SCSIPassThrough.cpp, Line 217
CDB Data: 0x5B 01 02 00 00 00 00 00 00 00 00 00
Sense Code: 0x73
Sense Qual: 0x03
18:52:14 #27 Text 0 File DVDPlusRW.cpp, Line 901
EndDAO: Last written address 768
18:52:14 #28 CDR -1106 File WriterStatus.cpp, Line 291
18:52:14 #29 TRANSFER -24 File ThreadedTransfer.cpp, Line 1222
Could not perform end of Disc-at-once
18:52:14 #30 Text 0 File DVDPlusDualLayer.cpp, Line 1460
SetDriveCaps: Set LAST LBA of layer 1 to 0
18:52:14 #31 PHASE 38 File dlgbrnst.cpp, Line 1827
Burn process failed at 6x (8 310 KB/s)
18:52:14 #32 Text 0 File SCSIPTICommands.cpp, Line 301
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
18:52:14 #33 Text 0 File Cdrdrv.cpp, Line 11916
DriveLocker: UnLockVolume completed
18:52:14 #34 Text 0 File SCSIPTICommands.cpp, Line 464
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
