Darek kRychu 1A20-620E-0010-2363-8673-7062* Windows XP 5.1 IA32 WinAspi: File ‘Wnaspi32.dll’: Ver=4.71 (0001), size=45056 bytes, created 2005-05-15 21:02:12 ahead WinASPI: File ‘C:\PROGRA~1\Ahead\nero\Wnaspi32.dll’: Ver=2.0.1.74, size=164112 bytes, created 2004-10-26 18:35:34 Nero Version: 6.6.0.14 Internal Version: 6, 6, 0, 14d (Nero Express) Recorder: Version: DL11 - HA 1 TA 0 - 6.6.0.14 Adapter driver: HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ATAPI CD-ROM: Version: 7Z14 - HA 1 TA 1 - 6.6.0.14 Adapter driver: HA 1 === Scsi-Device-Map === DiskPeripheral : ST340810A atapi Port 0 ID 0 DMA: On CdRomPeripheral : HL-DT-ST DVDRAM GSA-4167B atapi Port 1 ID 0 DMA: On CdRomPeripheral : MATSHITA DVD-ROM SR-8588 atapi Port 1 ID 1 DMA: Off CdRomPeripheral : IT3825L GVC108L 1.0 dtscsi Port 3 ID 0 DMA: Off === CDRom-Device-Map === HL-DT-ST DVDRAM GSA-4167B F: CDRom0 MATSHITA DVD-ROM SR-8588 E: CDRom1 IT3825L GVC108L G: CDRom2 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 74448896 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 511MB (523760kB) Free physical memory: 190MB (195560kB) Memory in use : 62 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 25.4.2006 Audio CD 19:27:53 #1 CDADOC -1 File Cdadoc.cpp, Line 1465 Audio item log info: Audio document burn settings: ============================= Burn mode: DAO, CD Text: On, Cache disk or network files: No, Cache small files: No, Cache files smaller than 65536 bytes. Audio Multisession: No List of audio tracks: ===================== Track 01: Length: 05:56.31, Pause frames: 150, Filters: 1, Name: ‘Aquarius - Sex Is Not The End (Dj E-Maxx Club Remix).mp3’. Track 02: Length: 03:42.30, Pause frames: 150, Filters: 1, Name: ‘Aquarius - Sex Is Not The End (Radio Mix) - http://Www.Bestmp3.Pl .mp3’. Track 03: Length: 06:47.51, Pause frames: 150, Filters: 1, Name: ‘moonbootica-june-standard.mp3’. Track 04: Length: 04:51.41, Pause frames: 150, Filters: 1, Name: ‘Royal Gigolos - Self Control 2005 (Club Mix) H. Eletro.mp3’. Track 05: Length: 09:54.37, Pause frames: 150, Filters: 1, Name: ‘z-The Pussycat Dolls - Don’t Cha (Ralphi Rosario Vocal Freak Mix).mp3’. Track 06: Length: 03:36.08, Pause frames: 150, Filters: 1, Name: ‘Blank & Jones - Beyond time.mp3’. Track 07: Length: 03:20.34, Pause frames: 150, Filters: 1, Name: ‘Blank & Jones - Cream.mp3’. Track 08: Length: 07:27.53, Pause frames: 150, Filters: 1, Name: ‘Blank & Jones - Desire (rave mix).mp3’. Track 09: Length: 03:21.55, Pause frames: 150, Filters: 1, Name: ‘Boogie Pimps - Somebody To Love (Salt Shaker Remix).mp3’. Track 10: Length: 06:34.27, Pause frames: 150, Filters: 1, Name: ‘The_Disco_Boys_-_Hey_St._Peter_[www.power-portal.to].mp3’. Track 11: Length: 03:40.51, Pause frames: 150, Filters: 1, Name: ‘Kalwi & Remi - Explosion (original).mp3’. Track 12: Length: 03:39.47, Pause frames: 150, Filters: 1, Name: ‘Shakira ft Wyclef Jean- Hips Don’t Lie.MP3’. Track 13: Length: 03:42.59, Pause frames: 150, Filters: 1, Name: ‘Andru Donalds & Eugenia Vlasova - Wind Of Hope.mp3’. Track 14: Length: 03:23.74, Pause frames: 150, Filters: 1, Name: ‘Antibazz vs deep melange - Wonderful life.mp3’. Track 15: Length: 03:04.53, Pause frames: 150, Filters: 1, Name: ‘Helene Rask - No Love (Deep Frost Radio Edit).mp3’. Total size: 73:34.51 19:27:53 #2 Text 0 File Burncd.cpp, Line 2945 HL-DT-ST DVDRAM GSA-4167B Włączono System ochrony zapisu 19:27:53 #3 Text 0 File Reader.cpp, Line 127 Reader running 19:27:53 #4 Text 0 File AudioCompilationImpl.cpp, Line 842 DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1) DRM: Beginning burn process. 19:27:53 #5 Text 0 File Writer.cpp, Line 122 Writer HL-DT-ST DVDRAM GSA-4167B running 19:27:53 #6 Text 0 File Burncd.cpp, Line 3230 Turn on Disc-At-Once, using CD-R/RW media 19:27:53 #7 Text 0 File DlgWaitCD.cpp, Line 267 Last possible write address on media: 359844 ( 79:59.69) Last address to be written: 330950 ( 73:34.50) 19:27:53 #8 Text 0 File DlgWaitCD.cpp, Line 279 Write in overburning mode: NO (enabled: CD) 19:27:53 #9 Text 0 File DlgWaitCD.cpp, Line 2433 Recorder: HL-DT-ST DVDRAM GSA-4167B; CDR code: 00 97 15 17; OSJ entry from: Ritek Co. ATIP Data: Special Info [hex] 1: C0 00 90, 2: 61 0F 11 (LI 97:15.17), 3: 4F 3B 46 (LO 79:59.70) Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid) 19:27:53 #10 Text 0 File DlgWaitCD.cpp, Line 445 >>> Protocol of DlgWaitCD activities: <<< ========================================= 19:27:53 #11 Text 0 File ThreadedTransferInterface.cpp, Line 830 Setup items (after recorder preparation) 0: TRM_AUDIO_NOPRE (Aquarius - Sex Is Not The End (Dj E-Maxx Club Remix).mp3) 2 indices, index0 (150) not provided original disc pos #0 + 26731 (26731) = #26731/5:56.31 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 26731 blocks [HL-DT-ST DVDRAM GSA-4167B] 1: TRM_AUDIO_NOPRE (Aquarius - Sex Is Not The End (Radio Mix) - http://Www.Bestmp3.Pl .mp3) 2 indices, index0 (150) not provided original disc pos #0 + 16680 (16680) = #16680/3:42.30 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16680 blocks [HL-DT-ST DVDRAM GSA-4167B] 2: TRM_AUDIO_NOPRE (moonbootica-june-standard.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 30576 (30576) = #30576/6:47.51 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 30576 blocks [HL-DT-ST DVDRAM GSA-4167B] 3: TRM_AUDIO_NOPRE (Royal Gigolos - Self Control 2005 (Club Mix) H. Eletro.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 21866 (21866) = #21866/4:51.41 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21866 blocks [HL-DT-ST DVDRAM GSA-4167B] 4: TRM_AUDIO_NOPRE (z-The Pussycat Dolls - Don’t Cha (Ralphi Rosario Vocal Freak Mix).mp3) 2 indices, index0 (150) not provided original disc pos #0 + 44587 (44587) = #44587/9:54.37 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 44587 blocks [HL-DT-ST DVDRAM GSA-4167B] 5: TRM_AUDIO_NOPRE (Blank & Jones - Beyond time.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 16208 (16208) = #16208/3:36.8 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16208 blocks [HL-DT-ST DVDRAM GSA-4167B] 6: TRM_AUDIO_NOPRE (Blank & Jones - Cream.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 15034 (15034) = #15034/3:20.34 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15034 blocks [HL-DT-ST DVDRAM GSA-4167B] 7: TRM_AUDIO_NOPRE (Blank & Jones - Desire (rave mix).mp3) 2 indices, index0 (150) not provided original disc pos #0 + 33578 (33578) = #33578/7:27.53 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 33578 blocks [HL-DT-ST DVDRAM GSA-4167B] 8: TRM_AUDIO_NOPRE (Boogie Pimps - Somebody To Love (Salt Shaker Remix).mp3) 2 indices, index0 (150) not provided original disc pos #0 + 15130 (15130) = #15130/3:21.55 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15130 blocks [HL-DT-ST DVDRAM GSA-4167B] 9: TRM_AUDIO_NOPRE (The_Disco_Boys_-_Hey_St._Peter_[www.power-portal.to].mp3) 2 indices, index0 (150) not provided original disc pos #0 + 29577 (29577) = #29577/6:34.27 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 29577 blocks [HL-DT-ST DVDRAM GSA-4167B] 10: TRM_AUDIO_NOPRE (Kalwi & Remi - Explosion (original).mp3) 2 indices, index0 (150) not provided original disc pos #0 + 16551 (16551) = #16551/3:40.51 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16551 blocks [HL-DT-ST DVDRAM GSA-4167B] 11: TRM_AUDIO_NOPRE (Shakira ft Wyclef Jean- Hips Don’t Lie.MP3) 2 indices, index0 (150) not provided original disc pos #0 + 16472 (16472) = #16472/3:39.47 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16472 blocks [HL-DT-ST DVDRAM GSA-4167B] 12: TRM_AUDIO_NOPRE (Andru Donalds & Eugenia Vlasova - Wind Of Hope.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 16709 (16709) = #16709/3:42.59 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16709 blocks [HL-DT-ST DVDRAM GSA-4167B] 13: TRM_AUDIO_NOPRE (Antibazz vs deep melange - Wonderful life.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 15299 (15299) = #15299/3:23.74 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15299 blocks [HL-DT-ST DVDRAM GSA-4167B] 14: TRM_AUDIO_NOPRE (Helene Rask - No Love (Deep Frost Radio Edit).mp3) 2 indices, index0 (150) not provided original disc pos #0 + 13853 (13853) = #13853/3:4.53 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13853 blocks [HL-DT-ST DVDRAM GSA-4167B] -------------------------------------------------------------- 19:27:53 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1043 Prepare recorder [HL-DT-ST DVDRAM GSA-4167B] for write in CUE-sheet-DAO DAO infos: ========== MCN: “” TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 15: 1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 63224112, ISRC “” 2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 63224112 63576912 102808272, ISRC “” 3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 102808272 103161072 175075824, ISRC “” 4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 175075824 175428624 226857456, ISRC “” 5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 226857456 227210256 332078880, ISRC “” 6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 332078880 332431680 370552896, ISRC “” 7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 370552896 370905696 406265664, ISRC “” 8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 406265664 406618464 485593920, ISRC “” 9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 485593920 485946720 521532480, ISRC “” 10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 521532480 521885280 591450384, ISRC “” 11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 591450384 591803184 630731136, ISRC “” 12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 630731136 631083936 669826080, ISRC “” 13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 669826080 670178880 709478448, ISRC “” 14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 709478448 709831248 745814496, ISRC “” 15: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 745814496 746167296 778749552, ISRC “” DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ -150 | lead-in | 0 | 0x01 | 0x00 -150 | 1 | 0 | 0x21 | 0x00 0 | 1 | 1 | 0x21 | 0x00 26731 | 2 | 0 | 0x21 | 0x00 26881 | 2 | 1 | 0x21 | 0x00 43561 | 3 | 0 | 0x21 | 0x00 43711 | 3 | 1 | 0x21 | 0x00 74287 | 4 | 0 | 0x21 | 0x00 74437 | 4 | 1 | 0x21 | 0x00 96303 | 5 | 0 | 0x21 | 0x00 96453 | 5 | 1 | 0x21 | 0x00 141040 | 6 | 0 | 0x21 | 0x00 141190 | 6 | 1 | 0x21 | 0x00 157398 | 7 | 0 | 0x21 | 0x00 157548 | 7 | 1 | 0x21 | 0x00 172582 | 8 | 0 | 0x21 | 0x00 172732 | 8 | 1 | 0x21 | 0x00 206310 | 9 | 0 | 0x21 | 0x00 206460 | 9 | 1 | 0x21 | 0x00 221590 | 10 | 0 | 0x21 | 0x00 221740 | 10 | 1 | 0x21 | 0x00 251317 | 11 | 0 | 0x21 | 0x00 251467 | 11 | 1 | 0x21 | 0x00 268018 | 12 | 0 | 0x21 | 0x00 268168 | 12 | 1 | 0x21 | 0x00 284640 | 13 | 0 | 0x21 | 0x00 284790 | 13 | 1 | 0x21 | 0x00 301499 | 14 | 0 | 0x21 | 0x00 301649 | 14 | 1 | 0x21 | 0x00 316948 | 15 | 0 | 0x21 | 0x00 317098 | 15 | 1 | 0x21 | 0x00 330951 | lead-out | 1 | 0x01 | 0x00 19:27:54 #13 Phase 36 File dlgbrnst.cpp, Line 1832 Burn process started at 32x (4 800 KB/s) 19:27:54 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0 19:27:54 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #26881 19:27:54 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #43711 19:27:54 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #74437 19:27:54 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #96453 19:27:54 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #141190 19:27:54 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #157548 19:27:54 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #172732 19:27:54 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #206460 19:27:54 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #221740 19:27:54 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #251467 19:27:54 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #268168 19:27:54 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 12 (relocatable, no disc pos, no patch infos, orig at #0): write at #284790 19:27:54 #27 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 13 (relocatable, no disc pos, no patch infos, orig at #0): write at #301649 19:27:54 #28 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 14 (relocatable, no disc pos, no patch infos, orig at #0): write at #317098 19:27:54 #29 Text 0 File Mmc.cpp, Line 16810 StartDAO : CD-Text - On 19:27:54 #30 Text 0 File Mmc.cpp, Line 21592 Set BUFE: Buffer underrun protection -> ON 19:27:54 #31 Text 0 File Mmc.cpp, Line 17099 CueData, Len=256 21 00 00 41 00 00 00 00 21 01 00 00 00 00 00 00 21 01 01 00 00 00 02 00 21 02 00 00 00 05 3a 1f 21 02 01 00 00 06 00 1f 21 03 00 00 00 09 2a 3d 21 03 01 00 00 09 2c 3d 21 04 00 00 00 10 20 25 21 04 01 00 00 10 22 25 21 05 00 00 00 15 1a 03 21 05 01 00 00 15 1c 03 21 06 00 00 00 1f 16 28 21 06 01 00 00 1f 18 28 21 07 00 00 00 23 00 30 21 07 01 00 00 23 02 30 21 08 00 00 00 26 17 07 21 08 01 00 00 26 19 07 21 09 00 00 00 2d 34 3c 21 09 01 00 00 2d 36 3c 21 0a 00 00 00 31 10 28 21 0a 01 00 00 31 12 28 21 0b 00 00 00 37 34 43 21 0b 01 00 00 37 36 43 21 0c 00 00 00 3b 23 2b 21 0c 01 00 00 3b 25 2b 21 0d 00 00 00 3f 11 0f 21 0d 01 00 00 3f 13 0f 21 0e 00 00 00 43 01 4a 21 0e 01 00 00 43 03 4a 21 0f 00 00 00 46 1b 49 21 0f 01 00 00 46 1d 49 01 aa 01 01 00 49 22 33 19:28:56 #32 SCSI -1024 File Cdrdrv.cpp, Line 1436 SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0BBC0000 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x04 (KEY_HARDWARE_ERROR) Sense Code: 0x08 Sense Qual: 0x03 CDB Data: 0x2A 0x00 0x00 0x00 0x68 0x34 0x00 0x00 0x1B 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x04 0x00 0x00 0x00 0x00 0x10 0x03 0x3E 0xC8 0x80 0x08 0x03 19:28:56 #33 CDR -1024 File Writer.cpp, Line 311 Communication failure 19:28:56 #34 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 19:28:56 #35 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader 19:29:02 #36 Phase 38 File dlgbrnst.cpp, Line 1832 Burn process failed at 32x (4 800 KB/s) 19:29:02 #37 Text 0 File AudioCompilationImpl.cpp, Line 867 DRM: DRM burn session terminated. 19:29:02 #38 Text 0 File AudioCompilationImpl.cpp, Line 896 DRM: Closing entire DRM handling. Bye. Existing drivers: File ‘Drivers\ASPI32.SYS’: Ver=4.71 (0001) built by: WinDDK, size=16512 bytes, created 2005-05-15 21:02:12 File ‘Drivers\PXHELP20.SYS’: Ver=2.03.28a, size=20640 bytes, created 2005-03-12 00:28:10 (Prassi/Veritas driver for win 2K) File ‘Drivers\InCDfs.SYS’: Ver=4, 3, 18, 0, size=99584 bytes, created 2005-07-08 17:17:54 (InCD4 driver for win NT/2K/XP) File ‘Drivers\InCDpass.SYS’: Ver=4, 3, 18, 0, size=29696 bytes, created 2005-07-08 17:17:36 (InCD4 driver for win NT/2K/XP) File ‘Drivers\InCDrec.SYS’: Ver=4, 3, 18, 0, size=8704 bytes, created 2005-07-08 17:17:56 (InCD4 driver for win NT/2K/XP) File ‘Drivers\atapi.sys’: Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 2004-08-03 22:59:44 (Adapter driver for rec) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
