Byłem w serwisie . Tam wszystko działa. Błąd tkwi chyba w moim systemie.Załączam plik log , może ktoś wie o co chodzi?
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File ‘D:\Program Files\Ahead\nero\Wnaspi32.dll’: Ver=2.0.1.68, size=160016 bytes, created 2004-07-22 17:33:44
Wersja Nero: 6.3.1.26 (Nero Express)
Nagrywarka: Wersja: KS02 - HA 1 TA 0 - 6.3.1.26
Sterownik adaptera: HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: Wersja: 1.01 - HA 1 TA 1 - 6.3.1.26
=== Scsi-Device-Map ===
DiskPeripheral : ST340810A atapi Port 0 ID 0 DMA: On
DiskPeripheral : SAMSUNG SP0802N atapi Port 0 ID 1 DMA: On
CdRomPeripheral : LITE-ON DVDRW SOHW-1693S atapi Port 1 ID 0 DMA: On
CdRomPeripheral : LG CD-ROM CRD-8400B atapi Port 1 ID 1 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
LITE-ON DVDRW SOHW-1693S H: CDRom0
LG CD-ROM CRD-8400B I: CDRom1
AXV CD/DVD-ROM K: CDRom4
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 175MB (179920kB)
Memory in use : 65 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
24.7.2005
CD-ROM (ISO)
17:02:11 #1 Text 0 File Isodoc.cpp, Line 6083
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
17:02:11 #2 Phase 90 File dlgbrnst.cpp, Line 1855
Włączono system ochrony zapisu
17:02:11 #3 Text 0 File Reader.cpp, Line 126
Reader running
17:02:11 #4 Text 0 File Writer.cpp, Line 124
Writer LITE-ON DVDRW SOHW-1693S running
17:02:11 #5 ISO9660GEN -11 File geniso.cpp, Line 3899
First writeable address = 0 (0x00000000)
17:02:11 #6 Text 0 File Burncd.cpp, Line 3152
Turn on Track-At-Once, using CD-R/RW media
17:02:27 #7 Text 0 File DlgWaitCD.cpp, Line 247
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 182836 ( 40:39.61)
17:02:27 #8 Text 0 File DlgWaitCD.cpp, Line 259
Write in overburning mode: NO (enabled: CD)
17:02:27 #9 Text 0 File DlgWaitCD.cpp, Line 2162
Recorder: LITE-ON DVDRW SOHW-1693S;
CDRW code: 00 00 00 00; CD manufacturer unknown
ATIP Data:
Special Info [hex] 1: 00 00 00, 2: 00 00 00 (LI 0:00.00), 3: 00 00 00 (LO 0:00.00)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
17:02:27 #10 Text 0 File DlgWaitCD.cpp, Line 420
>>> Protocol of DlgWaitCD activities: <<<
Need correct multisession disc to write.
(Medium in drive: CD-RW. Medium required by compilation: CD-R/RW.)
17:02:27 #11 Text 0 File ThreadedTransferInterface.cpp, Line 813
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 171137 (171137) = #171137/38:1.62
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 171135 blocks [LITE-ON DVDRW SOHW-1693S]
17:02:27 #12 Text 0 File ThreadedTransferInterface.cpp, Line 984
Prepare recorder [LITE-ON DVDRW SOHW-1693S] for write in TAO
DAO infos:
MCN: “”
TOCType: 0x00; Session Closed, disc not fixated
Tracks 2 to 2:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 350795776, ISRC “”
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
11550 | lead-in | 0 | 0x00 | 0x41
11550 | 2 | 0 | 0x00 | 0x41
11700 | 2 | 1 | 0x00 | 0x41
182837 | lead-out | 1 | 0x00 | 0x41
17:02:27 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1030
Removed 2 run-out blocks from end of track 2. Length: 171137 -> 171135.
17:02:28 #14 Phase 24 File dlgbrnst.cpp, Line 1855
Rozpoczęto buforowanie plików
17:02:29 #15 Text 0 File Burncd.cpp, Line 4163
Cache writing successful.
17:02:29 #16 Phase 25 File dlgbrnst.cpp, Line 1855
Zakończono buforowanie plików
17:02:29 #17 Phase 36 File dlgbrnst.cpp, Line 1855
Rozpoczęto zapis z prędkością 10x (1 500 KB/s)
17:02:29 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #11700
17:02:29 #19 Text 0 File Mmc.cpp, Line 20794
Set BUFE: supported -> ON , SMART-BURN : ON
17:02:33 #20 SCSI -1024 File Cdrdrv.cpp, Line 1445
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0AB30000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x08
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0x00 0x00 0x2E 0x14 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x04 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x08 0x03
17:02:33 #21 CDR -1024 File Writer.cpp, Line 304
Błąd komunikacji!
17:02:33 #22 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
17:02:33 #23 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
17:02:53 #24 CDR -201 File WriterStatus.cpp, Line 196
Niewłaściwy stan zapisu!
LITE-ON DVDRW SOHW-1693S\H1 T0
17:02:53 #25 TRANSFER -18 File WriterStatus.cpp, Line 196
Nie można wykonać polecenia ZakończŚcieżkę!
17:02:53 #26 Text 0 File Mmc.cpp, Line 15612
start Close Session
17:03:11 #27 Text 0 File dlgbrnst.cpp, Line 1713
Set remaining time: 0:00,000 (0ms) -> OK
17:03:11 #28 Phase 38 File dlgbrnst.cpp, Line 1855
Zapis z prędkością 10x (1 500 KB/s) nie powiódł się!
Existing drivers:
File ‘Drivers\InCDfs.SYS’: Ver=4, 3, 0, 3, size=92928 bytes, created 2004-08-27 10:02:30 (InCD4 driver for win NT/2K/XP)
File ‘Drivers\InCDpass.SYS’: Ver=4, 3, 0, 3, size=28672 bytes, created 2004-08-27 10:02:46 (InCD4 driver for win NT/2K/XP)
File ‘Drivers\InCDrec.SYS’: Ver=4, 3, 0, 3, size=7680 bytes, created 2004-08-27 10:04:16 (InCD4 driver for win NT/2K/XP)
File ‘Drivers\atapi.sys’: Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 2004-08-03 22:59:44 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
pozdrawiam andrew
