zoomman
(zoomman)
6 Listopad 2006 20:14
#1
Gdy chce nagrać płytke wyskakuje coś takiego
Error:
Cannot connect TRF.
O co chodzi?
Windows XP 5.1 IA32 WinAspi: - ahead WinASPI: File ‘D:\Programy\Nagrywamy\Core\Wnaspi32.dll’: Ver=2.0.1.74, size=164112 bytes, created 2004-11-02 13:54:32 NT-SPTI used Nero Version: 7.0.0.0 (Nero Express) Recorder: Version: US0A - HA 1 TA 0 - 7.0.0.0 Adapter driver: HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ? CD-ROM: Version: US0A - HA 1 TA 0 - 7.0.0.0 Adapter driver: HA 1 === Scsi-Device-Map === DiskPeripheral : WDC WD800JB-00CRA1 atapi Port 0 ID 0 DMA: On DiskPeripheral : ST310212A atapi Port 0 ID 1 DMA: On CdRomPeripheral : LITE-ON DVDRW SOHW-812S atapi Port 1 ID 0 DMA: On CdRomPeripheral : LITE-ON LTR-48246S atapi Port 1 ID 1 DMA: On === CDRom-Device-Map === LITE-ON DVDRW SOHW-812S E: CDRom0 LITE-ON LTR-48246S F: CDRom1 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 639MB (654832kB) Free physical memory: 385MB (395136kB) Memory in use : 39 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 6.11.2006 CD Image 21:30:35 #1 Text 0 File Burncd.cpp, Line 3007 LITE-ON DVDRW SOHW-812S Buffer underrun protection activated Existing drivers: File ‘Drivers\CDRALW2K.SYS’: Ver=8.0.0.212 , size=2560 bytes, created 2006-05-19 22:16:24 File ‘Drivers\PXHELP20.SYS’: Ver=3.00.11B, size=46080 bytes, created 2006-05-16 21:23:54 (Prassi/Veritas driver for win 2K) File ‘Drivers\InCDfs.SYS’: Ver=5, 0, 0, 0, size=101504 bytes, created 2005-08-30 17:24:38 (InCD4 driver for win NT/2K/XP) File ‘Drivers\InCDpass.SYS’: Ver=5, 0, 0, 0, size=29312 bytes, created 2005-08-30 17:24:18 (InCD4 driver for win NT/2K/XP) File ‘Drivers\InCDrec.SYS’: Ver=5, 0, 0, 0, size=8704 bytes, created 2005-08-30 17:24:40 (InCD4 driver for win NT/2K/XP) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
adpawl
(adpawl)
6 Listopad 2006 20:32
#2
Może ten temat w czymś pomoże:
http://club.cdfreaks.com/showthread.php?t=104720
Osobiście zalecał bym update nero do najnowszej wersji ew. instalacje starszej (czyli jakiejś 6-tki)
zoomman
(zoomman)
6 Listopad 2006 22:03
#3
Hmm… tutaj jasnej odpowiedzi nie ma:(. Albo ponownie zainstalować z “typowymi ustawieniami”(czyli na dysk c:, ale tam mi nie pasi) albo wrócić do ver. 6
qrczak13
(qrczak13)
6 Listopad 2006 22:12
#4
Polecam 6.6.0.18. Doświadczenia z trialem 7.0.4.5 nie są za ciekawe. Zrób jak radzi adpawl .
A dlaczego 6.6.0.18 jeżeli najnowsza wersja spośród 6 to 6.6.1.4?
qrczak13
(qrczak13)
7 Listopad 2006 12:04
#6
A bo taką sobie kupiłem. I od początku żadnej popsutej płyty ( z mojej winy 2). Do tego Nero Vision 2 i spolszczenie. Nic więcej nie używam do nagrywania.
to ściągnij triala z strony nero i zobacz czy ten sam błąd wywala
