Problem z Nero - nie nagrywa plyt dvd-+rw
(Marmazi) #1
wklejam loga jaki pokazał mi nero po nieudanej próbie nagrania na plytkę dvd rw
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2005-09-25 19:11:20
NT-SPTI used
Nero Version: 7.0.0.0
Recorder: Version: UL02 - HA 1 TA 0 - 7.0.0.0
 Adapter driver: HA 1
 Drive buffer : 2048kB
 Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
 Connected to MMC as unknown drive with class-nr : 1
 Drive is autodetected - recorder class:
CD-ROM: Version: 2.0B - HA 1 TA 1 - 7.0.0.0
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD2500KS-00MJB0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : HL-DT-STDVDRAM GSA-H12N UL02 JRAID Port 4 ID 0 DMA: Off
CdRomPeripheral : WL4849O NVJ804K 2.0B aeo27epc Port 5 ID 0 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-H12N G: CDRom0
WL4849O NVJ804K L: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1015MB (1039468kB)
Free physical memory: 659MB (675012kB)
Memory in use : 35 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
30.5.2007
Kompilacja ISO
22:09:25	#1 Text 0 File Isodoc.cpp, Line 6410
	Iso document burn settings
	Determine maximum speed : FALSE
	Simulate : FALSE
	Write : TRUE
	Finalize CD : FALSE
	Multisession : TRUE
	Multisession type: : Start multisession
	Burning mode : DAO
	Mode : 1
	ISO Level : 1 (Max. of 11 = 8 + 3 char)
	Character set : ISO 9660
	Joliet : TRUE
	Allow pathdepth more than 8 directories : TRUE
	Allow more than 255 characters in path : TRUE
	Write ISO9660 ;1 file extensions : TRUE
22:09:25	#2 Text 0 File ThreadedTransfer.cpp, Line 525
	ReadBuffer-Pipe got 81920KB of Memory
22:09:25	#3 Text 0 File Reader.cpp, Line 124
	Reader running
22:09:25	#4 ISO9660GEN -11 File Geniso.cpp, Line 3304
	First writeable address = 0 (0x00000000)
22:09:25	#5 Text 0 File Burncd.cpp, Line 3301
	Turn on Disc-At-Once, using DVD media
22:09:25	#6 Text 0 File DlgWaitCD.cpp, Line 277
	Last possible write address on media: 2295103 (510:01.28, 4482MB)
	Last address to be written: 357215 ( 79:22.65, 697MB)
22:09:25	#7 Text 0 File DlgWaitCD.cpp, Line 289
	Write in overburning mode: NO (enabled: CD DVD)
22:09:25	#8 Text 0 File DlgWaitCD.cpp, Line 2568
	Recorder: HL-DT-ST DVDRAM GSA-H12N, Media type: DVD+RW
	 Disc Manufacturer ID: MBIPG101, Media Type ID: W04, Product revision number: 0
	 Disc Application Code: 0, Extended Information Indicators: 1
22:09:25	#9 Text 0 File DlgWaitCD.cpp, Line 456
	>>> Protocol of DlgWaitCD activities: <<<
22:09:25	#10 Text 0 File ThreadedTransferInterface.cpp, Line 846
	Setup items (after recorder preparation)
	 0: TRM_DATA_MODE1 ()
	    2 indices, index0 (150) not provided
	    original disc pos #0 + 357216 (357216) = #357216/79:22.66
	    relocatable, disc pos for caching/writing not required/ required, no patch infos
	    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 357216 blocks [G]
22:09:25	#11 Text 0 File ThreadedTransferInterface.cpp, Line 1058
	Prepare recorder [G] for write in CUE-sheet-DAO
	DAO infos:
	 MCN: ""
	 TOCType: 0x00; Session Closed, disc not fixated
	 Tracks 1 to 1:
	   1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 731578368, ISRC ""
	DAO layout:
	 __Start_|____ Track_|_Idx_|_CtrlAdr_|_RecDep __________
	       0 | lead-in | 0 | 0x41 | 0x00
	       0 | 1 | 0 | 0x41 | 0x00
	       0 | 1 | 1 | 0x41 | 0x00
	  357216 | lead-out | 1 | 0x41 | 0x00
22:09:25	#12 Text 0 File SCSIPassThrough.cpp, Line 34
	SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
22:09:25	#13 Phase 24 File dlgbrnst.cpp, Line 1724
	Caching of files started
22:09:25	#14 Text 0 File Burncd.cpp, Line 4129
	Cache writing successful.
22:09:25	#15 Phase 25 File dlgbrnst.cpp, Line 1724
	Caching of files completed
22:09:25	#16 Phase 36 File dlgbrnst.cpp, Line 1724
	Burn process started at 2,4x (3 324 KB/s)
22:09:25	#17 Text 0 File ThreadedTransferInterface.cpp, Line 2669
	Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
22:09:25	#18 Text 0 File Cdrdrv.cpp, Line 8385
	---- DVD Structure: Physical Format Information (00h) ----
	Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
	 Book Type: DVD+RW (9), Part Version: 1.1x (2)
	 Disc Size: 120 mm, Maximum Rate: (F h)
	 Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: re-writable
	 Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
	 Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
	 End Physical Sector Number of Data Area: 26053F h
	 End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
	 Data in Burst Cutting Area (BCA) does not exist
	  Disc Application Code: 0 / 0 h
	  Extended Information indicators: 1 h
	  Media type ID: W04
	  Number of Physical format information bytes in use in ADIP up to byte 63: 57
	 Media Specific [16..63]:
	      00 00 01 4D 42 49 50 47 - 31 30 31 57 30 34 00 39 ...MBIPG101W04.9
	      23 00 94 79 64 02 20 00 - 9C 7A 6C 02 20 00 9A 7B #.”yd...śzl...š{
	      68 02 20 12 12 10 E0 00 - F0 00 00 00 00 00 00 00 h.....ŕ.đ.......
22:09:25	#19 Text 0 File DVDR.cpp, Line 5281
	Drive: HL-DT-ST DVDRAM GSA-H12N
	Book Type request [LG]: DVD-ROM
	Book Type setting not supported for the loaded disc type
22:09:25	#20 Phase 98 File dlgbrnst.cpp, Line 1724
	Start formatting disc before burning
22:09:25	#21 SPTI -1065 File SCSIPassThrough.cpp, Line 306
	CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1065)
	Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
	Sense Code: 0x20
	Sense Qual: 0x00
	CDB Data: 0x04 11 00 00 00 00 00 00 00 00 00 00
	Sense Area: 0x70 00 05 00 00 00 00 0A 24 00 00 0F 20
	Buffer x038e8200: Len xc
	0x00 82 00 08 00 23 05 40 98 00 00 00
22:09:25	#22 Phase 101 File dlgbrnst.cpp, Line 1724
	Formatting disc failed
22:09:25	#23 Text 0 File DVDPlusRW.cpp, Line 666
	Start write address at LBA 0
	DVD high compatibility mode: Yes
22:09:25	#24 CDR -1065 File ThreadedTransferInterface.cpp, Line 1783
	Invalid command
	G: HL-DT-ST DVDRAM GSA-H12N
22:09:25	#25 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1783
	Could not perform start of Disc-at-once
22:09:25	#26 Phase 38 File dlgbrnst.cpp, Line 1724
	Burn process failed at 2,4x (3 324 KB/s)
Existing drivers:
File 'Drivers\scsiport.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=96256 bytes, created 2004-08-03 23:59:42 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
(Clubbasse207) #2
czy jesteś pewiem że płyta jest sprawna ?
(Marmazi) #3
tak , próbowałem już chyba na 5 rodzajach i na + i na -
(Anonymous Dreams) #4
Ale numeru seryjnego to chyba nie musisz wszystkim ujawniać. :o
(Marmazi) #5
no tak , ale to nadal nie rozwiązuje mojego problemu
(Anonymous Dreams) #6
Zaktualizuj firmware nagrywarki.
Odinstaluj nero. Narzędziami Nero Cleaner i jv16 wyczyść rejestr i zainstaluj ponownie.
(Marmazi) #7
przed wczoraj instalowałem na nowo system i nadal to samo co przed instalką
(Anonymous Dreams) #8
A jakie to płyty? może to jakieś nowości i firmware nagrywarki tych płyt nie obsługuje. Albo jakiś badziew …podstawki pod szklanki z piwem :mrgreen:
a właśnie firmware…
tu masz nowe
http://www.cdrinfo.pl/bios/7030130009
z dnia 2007/01/29
(Marmazi) #9
zrobiłem firmware , a płytki to Platinum bądź TDK , a to nie są chyba raczej podkładki pod piwo
(system) #10
Uaktualnij Nero.
(Marmazi) #11
Teraz dla odmiany pokazuje mi coś takiego:
Windows XP 5.1
[color=darkblue][size=75]Złączono Posta: 02.06.2007 (Sob) 16:11[/size][/color]
bardzo proszę o pomoc , jeżeli wasza wiedza nie pomoże w rozwiązaniu mojego problemu pewnie będę musiał ją oddać do reklamacji
