Cześć mam problem z niebieskim ekranem. Od dwóch dni się pojawia. wkleje wam raport z windbg może coś zaradzicie
Microsoft (R) Windows Debugger Version 6.12.0002.633 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: ***Invalid***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image \SystemRoot\system32\ntkrnlpa.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntkrnlpa.exe
*** ERROR: Module load completed but symbols could not be loaded for ntkrnlpa.exe
Windows 7 Kernel Version 7601 (Service Pack 1) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.18044.x86fre.win7sp1_gdr.130104-1431
Machine Name:
Kernel base = 0x82a09000 PsLoadedModuleList = 0x82b524d0
Debug session time: Fri Mar 8 22:26:19.251 2013 (UTC + 1:00)
System Uptime: 0 days 9:37:48.908
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image \SystemRoot\system32\drivers\NETIO.SYS, Win32 error 0n2
*** WARNING: Unable to verify timestamp for NETIO.SYS
*** ERROR: Module load completed but symbols could not be loaded for NETIO.SYS
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck D1, {28, 2, 0, 8882a646}
*** WARNING: Unable to verify timestamp for fwpkclnt.sys
*** ERROR: Module load completed but symbols could not be loaded for fwpkclnt.sys
*** WARNING: Unable to verify timestamp for UrlFilter.sys
*** ERROR: Module load completed but symbols could not be loaded for UrlFilter.sys
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
***Your debugger is not using the correct symbols***
***In order for this command to work properly, your symbol path***
***must point to .pdb files that have full type information.***
***Certain .pdb files (such as the public OS symbols) do not***
***contain the required information. Contact the group that***
***provided you with these symbols if you need this command to***
***work.***
***Type referenced: nt!_KPRCB***
***work.***
***work.***
Probably caused by : NETIO.SYS ( NETIO+2a646 )
Followup: MachineOwner
nie wiedziałem co dokładnie skopiowac więc skopiowałem wszystko. Bardzo was proszę o pomoc
– Dodane 09.03.2013 (So) 10:21 –
jeżeli coś źle skopiowałem powiedzcie mi jak to zrobić.
– Dodane 09.03.2013 (So) 12:35 –
udało mi się wgrać cały plik dmp
http://www.sendspace.pl/file/8ece22874308f4e135aed68
jakbyście mogli zobaczyć ten plik i powiedzieć co może być przyczyną niebieskich ekranów
