Zainstalowałem Wolfenstein ET (legal) i przy próbie odpalenia pojawia się taki tekst(w ramce) i potem wywala mnie do pulpitu.
Panowie. Jakm możecie to powiedzcie co z tym można zrobić?
Z góry dzięki za wszelkie podpowiedzi.
pozdro.
TEKST KTÓRY WYWALA:
ET 2.55 win-x86 May 27 2003
----- FS_Startup -----
Current search path:
D:\PROGRA~1\WOLFEN~1\etmain\pak0.pk3 (3725 files)
D:\PROGRA~1\WOLFEN~1\etmain\mp_bin.pk3 (4 files)
D:\PROGRA~1\WOLFEN~1/etmain
3729 files in pk3 files
execing default.cfg
couldn’t exec language.cfg
couldn’t exec autoexec.cfg
Hunk_Clear: reset the hunk ok
…detecting CPU, found AMD w/ 3DNow!
Bypassing CD checks
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
…initializing QGL
…calling LoadLibrary( ‘D:\WINDOWS\System32\opengl32.dll’ ): succeeded
…setting mode 4: 800 600 FS
…using desktop display depth of 32
…calling CDS: ok
…registered window class
…created window@0,0 (800x600)
Initializing OpenGL driver
…getting DC: succeeded
…GLW_ChoosePFD( 32, 24, 0 )
…35 PFDs found
…GLW_ChoosePFD failed
…35 PFDs found
…failed to find an appropriate PIXELFORMAT
…restoring display settings
…WARNING: could not set the given mode (4)
…using colorsbits of 16
…calling CDS: ok
…GLW_ChoosePFD( 16, 16, 0 )
…35 PFDs found
…35 PFDs found
…WARNING: could not set the given mode (3)
…shutting down QGL
…unloading OpenGL DLL
…assuming ‘3dfxvgl’ is a standalone driver
…initializing QGL
…WARNING: missing Glide installation, assuming no 3Dfx available
…shutting down QGL
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
