hm no tak sie domyslalem tylko skad na tej formatowanej partycji cos z mandrivy sie wzielo, ona byla glownie po to zeby rozne pliki “wymieniac” miedzy systemami, no ale nic stalo sie
Złączono Posta : 07.11.2005 (Pon) 22:38
Areh nie dam rady: disk /dev/scsi/host1/bus0/target0/lun0/disc: 257 MB, 257802752 bytes
8 heads, 62 sectors/track, 1015 cylinders
Units = cylinders of 496 * 512 = 253952 bytes
Device Boot Start End Blocks Id System
/dev/scsi/host1/bus0/target0/lun0/part1 ? 3769701 4109801 84344761 69 Unknown
Partition 1 has different physical/logical beginnings (non-Linux?):
phys=(68, 13, 10) logical=(3769700, 2, 42)
Partition 1 has different physical/logical endings:
phys=(288, 115, 43) logical=(4109800, 1, 25)
Partition 1 does not end on cylinder boundary.
/dev/scsi/host1/bus0/target0/lun0/part2 ? 3430483 7200406 934940732+ 73 Unknown
Partition 2 has different physical/logical beginnings (non-Linux?):
phys=(371, 114, 37) logical=(3430482, 6, 38)
Partition 2 has different physical/logical endings:
phys=(366, 32, 33) logical=(7200405, 1, 4)
Partition 2 does not end on cylinder boundary.
/dev/scsi/host1/bus0/target0/lun0/part3 ? 6 6 0 74 Unknown
Partition 3 has different physical/logical beginnings (non-Linux?):
phys=(371, 114, 37) logical=(5, 1, 32)
Partition 3 has different physical/logical endings:
phys=(372, 97, 50) logical=(5, 1, 31)
Partition 3 does not end on cylinder boundary.
/dev/scsi/host1/bus0/target0/lun0/part4 1 6925632 1717556736 0 Empty
Partition 4 has different physical/logical beginnings (non-Linux?):
phys=(0, 0, 0) logical=(0, 0, 1)
Partition 4 has different physical/logical endings:
phys=(0, 0, 0) logical=(6925631, 7, 62)
Partition 4 does not end on cylinder boundary.
Partition table entries are not in disk order
Disk /dev/ide/host0/bus0/target0/lun0/disc: 80.0 GB, 80026361856 bytes
255 heads, 63 sectors/track, 9729 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
/dev/ide/host0/bus0/target0/lun0/part1 * 1 1912 15358108+ 7 HPFS/NTFS
/dev/ide/host0/bus0/target0/lun0/part2 1913 9729 62789800+ f W95 Ext’d (LBA)
/dev/ide/host0/bus0/target0/lun0/part5 1913 1976 511528+ 82 Linux swap
/dev/ide/host0/bus0/target0/lun0/part6 1977 2243 2144646 83 Linux
/dev/ide/host0/bus0/target0/lun0/part7 2244 2501 2072353+ 83 Linux
/dev/ide/host0/bus0/target0/lun0/part8 2502 2765 2120548+ 83 Linux
/dev/ide/host0/bus0/target0/lun0/part9 2766 4513 14040778+ 7 HPFS/NTFS
/dev/ide/host0/bus0/target0/lun0/part10 4514 9729 41897488+ b W95 FAT32
Złączono Posta : 07.11.2005 (Pon) 22:42
no niestety z lilo.conf nie umiem skopiowac
Złączono Posta : 07.11.2005 (Pon) 22:45
LILO configuration file
generated by ‘liloconfig’
Start LILO global section
boot = /dev/hda
prompt
timeout = 1200
Override dangerous defaults that rewrite the partition table:
change-rules
reset
Normal VGA console
vga = normal
End LILO global section
DOS bootable partition config begins
other = /dev/hda3
label = other
table = /dev/hda
DOS bootable partition config ends
Linux bootable partition config begins
image = /boot/vmlinuz
root = /dev/hda2
label = Linux
read-only
Linux bootable partition config ends
