Witam mam lapa z kartą nvidia ge force 2 go i nie mogę nigdzie znaleść sterownika zeby chodziły mi gry ,dosłownie nie chodzi żadna gra POMOCY! ![]()
A jaki system masz w tym laptopie ??
System Windows XP 8) Home Edition
No dobra a jakie komunikaty wyskakują ![]()
— Common Initialization —
Medal of Honor Allied Assault 1.00 win-x86 Dec 6 2001
----- FS_Startup -----
Current search path:
C:\Program Files\Honor_pol\main\Pol.pk3 (504 files)
C:\Program Files\Honor_pol\main\PAK5.PK3 (259 files)
C:\Program Files\Honor_pol\main\PAK4.PK3 (593 files)
C:\Program Files\Honor_pol\main\PAK3.PK3 (669 files)
C:\Program Files\Honor_pol\main\PAK2.PK3 (4722 files)
C:\Program Files\Honor_pol\main\PAK1.PK3 (772 files)
C:\Program Files\Honor_pol\main\PAK0.PK3 (11175 files)
C:\Program Files\Honor_pol/main
18694 files in pk3 files
execing default.cfg
execing menu.cfg
execing newconfig.cfg
Config: unnamedsoldier.cfg
execing configs/unnamedsoldier.cfg
execing safemode.cfg
couldn’t exec localized.cfg
execing autoexec.cfg
Unknown command “fov”
couldn’t exec custom.cfg
…detecting CPU, found Intel Pentium III
------- Input Initialization -------
Initializing DirectInput…
Couldn’t set DI coop level
Falling back to Win32 mouse support…
------- Input Initialization Complete ------- 319
You are now setup for easy mode.
----- Client Initialization -----
Called FadeSound with: 0.000000
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
…initializing QGL
…calling LoadLibrary( ‘C:\WINDOWS\system32\opengl32.dll’ ): succeeded
…setting mode 3: 640 480 FS
…using colorsbits of 16
…calling CDS: ok
…registered window class
…created window@0,0 (640x480)
Initializing OpenGL driver
…getting DC: succeeded
…GLW_ChoosePFD( 16, 16, 0 )
…35 PFDs found
…GLW_ChoosePFD failed
…GLW_ChoosePFD( 8, 16, 0 )
…35 PFDs found
…failed to find an appropriate PIXELFORMAT
…restoring display settings
…WARNING: could not set the given mode (3)
…shutting down QGL
…unloading OpenGL DLL
…assuming ‘3dfxvgl’ is a standalone driver
…initializing QGL
…WARNING: missing Glide installation, assuming no 3Dfx available
…shutting down QGL
GLW_StartOpenGL() - could not load OpenGL subsystem
Aha i na Nvidia tez nic takiego nie ma
Znaczy niby jest ale zaden sterownik nic nie daje
A masz płytę CD do lapa tam powinny być stery do grafiki.
Lub strona producenta lapa i pobierz ster do grafiki do twojego modelu lapa i systemu XP.
Co to za lap.
Jak będziesz miał prawidłowy ster,zrób czystę w kompie ze sterów do karty grafiki,restart kompa i uruchom go na sterze systemowym .
Wgraj stery do płyty głównej jak są potrzebne.
Sprawdź co słychać w menadzeże urządzeń czy nie ma konfliktów i wszystko jest zainstalowane.
I teraz dopiero nowy ster do grafiki.
Na końcu z uruchom komenda dxdiag i zrób testy czy wszystko gra.
Ja to widzę ze musisz odwiedzić jakąś stronkę i zainstalować poprawkę . Albo ten path jest nie tego i gra wyczuła coś lewego.
