zrzut z pliku minidump:
Microsoft ® Windows Debugger Version 6.2.8229.0 X86
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [C]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image \SystemRoot\system32\ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Machine Name:
Kernel base = 0x81c0f000 PsLoadedModuleList = 0x81d1c930
Debug session time: Mon Mar 5 17:47:15.947 2012 (UTC + 1:00)
System Uptime: 0 days 0:01:26.634
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
TRIAGER: Could not open triage file : C:\Programy\Windows Kits\8.0\Debuggers\x86\triage\oca.ini, error 2
TRIAGER: Could not open triage file : C:\Programy\Windows Kits\8.0\Debuggers\x86\winxp\triage.ini, error 2
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1A, {8884, 83969828, 8396a440, 501}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Either you specified an unqualified symbol, or your debugger ***
*** doesn’t have full symbol information. Unqualified symbol ***
*** resolution is turned off by default. Please either specify a ***
*** fully qualified symbol module!symbolname, or enable resolution ***
*** of unqualified symbols by typing “.symopt- 100”. Note that ***
*** enabling unqualified symbol resolution with network symbol ***
*** server shares in the symbol path may cause the debugger to ***
*** appear to hang for long periods of time when an incorrect ***
*** symbol name is typed or the network symbol server is down. ***
*** For some commands to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
TRIAGER: Could not open triage file : C:\Programy\Windows Kits\8.0\Debuggers\x86\triage\modclass.ini, error 2
*** work. ***
*** work. ***
Probably caused by : ntoskrnl.exe ( nt+bb89f )
Followup: MachineOwner
Pomocy!
