Witam,
na świeżo postawionym Windows 7, zainstalowane aktualizacje oraz kilkanaście programów z których korzystam,
wyrzuca mi raz na jakiś czas BSOD’a, załączam LOG, co może być przyczyną?:
Microsoft ® Windows Debugger Version 6.6.0003.5
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [E:_user\011215-12963-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image \SystemRoot\system32\ntoskrnl.exe, Win32 error 2
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows Vista Kernel Version 7601 (Service Pack 1) MP (2 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.18409.amd64fre.win7sp1_gdr.140303-2144
Kernel base = 0xfffff80002a07000 PsLoadedModuleList = 0xfffff80002c4a890
Debug session time: Mon Jan 12 09:05:52.929 2015 (GMT+1)
System Uptime: 0 days 0:02:29.209
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 3B, {c0000005, fffff80002a74ac5, fffff880074669f0, 0}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
Probably caused by : ntoskrnl.exe ( nt+6dac5 )
Followup: MachineOwner
