Po zalogowaniu się na jednej ze stron pojawia się komunikat. Nie bardzo wiem co z tym począć??
You have a Browser, System or Network Setting conflicting
with the Members Section Authentication System…
Please read these suggestions.
A personal Firewall or a Firewall at your ISP can block you from accessing the galleries. Firewalls can block referrers and cookies (“to protect privacy”). Our system uses both referrers and cookies for security and customization. No referrers, no cookies = no access. Make sure any firewall blocking of cookies or referrers is disabled.
Proxy servers and firewalls at your ISP or on your private network may also cause problems accessing Galleries. A proxy server is a type of firewall. The term “firewall” actually refers to an entire group of technologies. The way a proxy server works is that they save in cache and show you previous copies of the pages that they’ve saved locally, rather than actually connect you to the Internet or back to the actual site. Our authentication requires a direct connection to our server every time.
Proxy servers have the same underlying problems that firewalls have and specific configuration will depend on the specific proxy and any filters installed or enabled. A correctly configured proxy server should not cause you problems accessing our galleries. However, if your company’s or your ISP’s proxy server blocks the sending of the referrer or cookie header, you can not access the galleries.
Did you try to access the Galleries using a bookmark or by typing in a URL? Because of the security features, like with video feeds, you can only access Photo Galleries from pages that contain the links. Use your back button to return to your previous page.
You may have tried accessing through a link that it incorrect or not authorized If the suggestions below do not solve your problem you should contact customer support for the site you are a member of. They should have Help or Support links elsewhere on their site.
Set browser Privacy to a maximum of Medium Higher privacy levels will not allow the proper authentication information to be passed through your browser and will cause access to be denied.
Proxy servers and firewalls at your ISP or on your private network may also cause problems accessing Galleries. A proxy server is a type of firewall. The term “firewall” actually refers to an entire group of technologies. The way a proxy server works is that they save in cache and show you previous copies of the pages that they’ve saved locally, rather than actually connect you to the Internet or back to the actual site. Our authentication requires a direct connection to our server every time. You may wish to contact them to find out if they have any firewalls or proxys that could interfere with the sending of the referrering URL information or the cookie header. (You will need to talk with a “Tech Administrator” or “System Administrator” and NOT a general Customer Service Rep.-- and most likely they will say “No” – even when they are using proxies.) (aol.com, @home, shaw.ca, charter.net seem to have this more often than any other providers.)
In the USA you can verify if the problem is with your ISP and proxy servers by trying a FREE or low-cost Internet Service Provider such as http://www.netzero.com or http://www.juno.com. These ISP’s generally do not use proxy servers, and provide FREE or very low cost Internet access. They often provide better quality service than many ISP’s that charge $15 - $30 a month. This is not a paid advertisement for these ISPs, just a recommendation that might help you to resolve your problem.
