Witam wszystkich, od miesiąca komputer resetuje się praktycznie co chwile. Dopiero dzisiaj zdecydowałem się coś z tym zrobić i zacząłem szukać w internecie czegoś na ten temat. Według tego co znalazłem miałem wkleić na jakies forum to
Microsoft (R) Windows Debugger Version 6.6.0003.5
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: ***Invalid***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0x804d7000 PsLoadedModuleList = 0x805644a0
Debug session time: Sun May 9 13:55:07.296 2010 (GMT+2)
System Uptime: 0 days 0:14:18.024
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck A, {e8, 2, 1, 80703a16}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** WARNING: Unable to verify timestamp for USBPORT.SYS
*** ERROR: Module load completed but symbols could not be loaded for USBPORT.SYS
*** WARNING: Unable to verify timestamp for usbhub.sys
*** ERROR: Module load completed but symbols could not be loaded for usbhub.sys
***Your debugger is not using the correct symbols***
***In order for this command to work properly, your symbol path***
***must point to .pdb files that have full type information.***
***Certain .pdb files (such as the public OS symbols) do not***
***contain the required information. Contact the group that***
***provided you with these symbols if you need this command to***
***work.***
***Type referenced: nt!_KPRCB***
*** WARNING: Unable to verify timestamp for hal.dll
*** ERROR: Module load completed but symbols could not be loaded for hal.dll
*** WARNING: Unable to verify timestamp for Sacm2A.sys
*** ERROR: Module load completed but symbols could not be loaded for Sacm2A.sys
Probably caused by : Sacm2A.sys ( Sacm2A+94e )
Followup: MachineOwner
Jak ktoś wie co zrobić proszę o odpis.
