Problem z skrótami na pulpicie
(Pizdzipiorek) #1
Mam problem ze skrótami na pulpicie, nie mogę otwierać programów ze skrótów, jedynie z dysku. Menu start również nie pozwala mi otwierać programów. Wyskakuje okienko “wybrać program z listy” itd.
A wygląda to tak.
Help
Pozdrawiam
(Cosik Ktosik) #2
W start->uruchom wpisz notepad.exe
Wklej to:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\.lnk]
@="lnkfile"
[HKEY_CLASSES_ROOT\.lnk\ShellEx]
[HKEY_CLASSES_ROOT\.lnk\ShellEx\{000214EE-0000-0000-C000-000000000046}]
@="{00021401-0000-0000-C000-000000000046}"
[HKEY_CLASSES_ROOT\.lnk\ShellEx\{000214F9-0000-0000-C000-000000000046}]
[HKEY_CLASSES_ROOT\.lnk\ShellEx\{00021500-0000-0000-C000-000000000046}]
[HKEY_CLASSES_ROOT\.lnk\ShellEx\{BB2E617C-0920-11d1-9A0B-00C04FC2D6C1}]
[HKEY_CLASSES_ROOT\.lnk\ShellNew]
"Command"="rundll32.exe appwiz.cpl,NewLinkHere %1"
[HKEY_CLASSES_ROOT\lnkfile]
@="Shortcut"
"EditFlags"=dword:00000001
"IsShortcut"=""
"NeverShowExt"=""
[HKEY_CLASSES_ROOT\lnkfile\CLSID]
[HKEY_CLASSES_ROOT\lnkfile\shellex]
[HKEY_CLASSES_ROOT\lnkfile\shellex\ContextMenuHandlers]
[HKEY_CLASSES_ROOT\lnkfile\shellex\ContextMenuHandlers\Offline Files]
@="{750fdf0e-2a26-11d1-a3ea-080036587f03}"
[HKEY_CLASSES_ROOT\lnkfile\shellex\ContextMenuHandlers\{00021401-0000-0000-C000-000000000046}]
[HKEY_CLASSES_ROOT\lnkfile\shellex\DropHandler]
[HKEY_CLASSES_ROOT\lnkfile\shellex\IconHandler]
[HKEY_CLASSES_ROOT\lnkfile\shellex\PropertySheetHandlers]
[HKEY_CLASSES_ROOT\lnkfile\shellex\PropertySheetHandlers\ShimLayer Property Page]
@="{513D916F-2A8E-4F51-AEAB-0CBC76FB1AF8}"
[HKEY_CLASSES_ROOT\CLSID\{00021401-0000-0000-C000-000000000046}]
@="Shortcut"
[HKEY_CLASSES_ROOT\CLSID\{00021401-0000-0000-C000-000000000046}\InProcServer32]
@="shell32.dll"
"ThreadingModel"="Apartment"
[HKEY_CLASSES_ROOT\CLSID\{00021401-0000-0000-C000-000000000046}\PersistentAddinsRegistered]
[HKEY_CLASSES_ROOT\CLSID\{00021401-0000-0000-C000-000000000046}\PersistentAddinsRegistered\{89BCB740-6119-101A-BCB7-00DD010655AF}]
[HKEY_CLASSES_ROOT\CLSID\{00021401-0000-0000-C000-000000000046}\PersistentHandler]
[HKEY_CLASSES_ROOT\CLSID\{00021401-0000-0000-C000-000000000046}\ProgID]
@="lnkfile"
[HKEY_CLASSES_ROOT\CLSID\{00021401-0000-0000-C000-000000000046}\shellex]
[HKEY_CLASSES_ROOT\CLSID\{00021401-0000-0000-C000-000000000046}\shellex\MayChangeDefaultMenu]
zapisz jako fix_lnk.reg na pulpicie (w typach plików, wybierz wszystkie pliki). Zamknij program, 2x kliknij i dodaj do rejestru. Po restarcie powinno być ok.
Napisz też, co spowodowało ten problem, nie podłapałeś wirusa?
(Pizdzipiorek) #3
Właśnie nie mam pojęcia, wczoraj wieczorem zainstalowałem BearShare, dzisiaj komp został włączony od rana przychodze jakiś czas temu i tak już wyglądało. Czeski film, niestety to co podałeś nie pomogło
(Cosik Ktosik) #4
A włączyłeś ponownie komputer?
Jeżeli nie pomaga to wejdź do katalogu: c:\windows\System32\restore\ i uruchom rstrui.exe, przywróć system do czasu sprzed awarii.
(zakładam, że system jest na C w katalogu windows)
(Pizdzipiorek) #5
Zrobiłem przywracanie. Też nic to nie dało, włączyłem ponownie komputer
(Cosik Ktosik) #6
A sprawdź dowolny skrót, PPM->Właściwości->element docelowy. Zobacz, czy ścieżka się zgadza z tym, gdy patrzysz się przez Mój komputer.
Na wypadek syfu w komputerze daj log z HijackThis
(log daj na wklej.org, a tu tylko link do niego).
(Longhorn2009) #7
Możesz też spróbować usunąć pliki iconcache.dll, jeśli masz je na dysku. Wystarczy je tylko wyszukać, usunąc i zrestartować komputer.
(Pizdzipiorek) #8
http://wklej.org/id/dfebed4dba - z combo fix
http://wklej.org/id/19c2cb07db - z hijacka
icon cache nie może znaleźć
Patrząc na właściwości przez mój komp. element docelowy znajduje
Już ■■■■■■■ nie wiem co robić.
Format C:?
W dniu 19.06.2008 , o godzinie 18:42 został dopisany post przez psychiczny
dalej czekam na pomoc
(huber2t) #9
otwórz notatnik i wklej
Z menu Notatnika -> Plik -> Zapisz jako -> Zmień rozszerzenie z .txt na wszystkie pliki -> zapisz pod nazwą Fix.reg
Uruchom ten plik, uruchom ponownie komputer
Do wyleczenia pendrive z wirusów użyj
Perlovg Removal Tool
Flash Disinfector
lub format
:slight_smile:
(Utrivv) #10
A może programy zmieniły lokalizacje?
Kiedyś tak miałem że litera drugiej partycji zmieniała się po zainstalowaniu nowego napędu :slight_smile: w efekcie programy zamiast na d: wędrowały na e: lub nawet f: - nic dziwnego że wszelkie skróty nei działały, ikonki znikały itp.
Możesz sprawdzić czy ścieżka dostępu ze skrótu pokrywa się z miejscem aktualnego przechowywania programu?
