Witam jestem posiadaczem Linuxa o dystrybucji Debian 5.0. Przy instalacji jakiegokolwiek pakietu wywala mi następujący komunikat:
daniel:~# aptitude install ktoorent
Reading package lists... Done
Building dependency tree... Done
Reading extended state information
Initializing package states... Done
Reading task descriptions... Done
Building tag database... Done
Couldn't find any package whose name or description matched "ktoorent"
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0B of archives. After unpacking 0B will be used.
daniel:~# aptitude install ktorrent
The following NEW packages will be automatically installed:
  aspell aspell-en dbus esound-clients esound-common fontconfig
  hicolor-icon-theme jackd kdelibs-data kdelibs4c2a libakode2 libart-2.0-2
  libarts1-akode libarts1c2a libartsc0 libasound2 libaspell15 libaudio2
  libaudiofile0 libavahi-client3 libavahi-common-data libavahi-common3
  libavahi-qt3-1 libcupsys2 libdbus-1-3 libesd0 libflac7 libglu1-mesa
  libgmp3c2 libjack0.100.0-0 libjasper-1.701-1 libjpeg62 liblcms1 liblua50
  liblualib50 libmad0 libmng1 libogg0 liboggflac3 libopenexr2c2a libqt3-mt
  libsamplerate0 libsndfile1 libspeex1 libtiff4 libvorbis0a libvorbisenc2
  libvorbisfile3 libxinerama1 libxslt1.1 menu menu-xdg perl-suid
The following NEW packages will be installed:
  hicolor-icon-theme jackd kdelibs-data kdelibs4c2a ktorrent libakode2
  libart-2.0-2 libarts1-akode libarts1c2a libartsc0 libasound2 libaspell15
  libaudio2 libaudiofile0 libavahi-client3 libavahi-common-data
  libavahi-common3 libavahi-qt3-1 libcupsys2 libdbus-1-3 libesd0 libflac7
  libglu1-mesa libgmp3c2 libjack0.100.0-0 libjasper-1.701-1 libjpeg62
  liblcms1 liblua50 liblualib50 libmad0 libmng1 libogg0 liboggflac3
  libopenexr2c2a libqt3-mt libsamplerate0 libsndfile1 libspeex1 libtiff4
  libvorbis0a libvorbisenc2 libvorbisfile3 libxinerama1 libxslt1.1 menu
  menu-xdg perl-suid
0 packages upgraded, 54 newly installed, 0 to remove and 0 not upgraded.
Need to get 0B/31.0MB of archives. After unpacking 97.7MB will be used.
Do you want to continue? [Y/n/?] y
Writing extended state information... Done
Extracting templates from packages: 100%
dpkg: syntax error: unknown user `postfix' in statoverride file
E: Sub-process /usr/bin/dpkg returned an error code (2)
A package failed to install. Trying to recover:
daniel:~#
Prosiłbym o pomoc, dodam że próbowałem usunąć postfix lecz nie wyszło mi to.
