Witam, mam problem z uruchomieniem Railworks 3. Gdy włączam ikonką grę ukazuje mi się taki error http://fooh.pl/pokaz/4412108015.gif . Gdy dusze START to pokazuje mi się następny error http://fooh.pl/pokaz/1423684548.gif . Nie wiem już co mam zrobić. Jeśli ktoś wie o co chodzi i jak to zrobić to proszę o pomoc, z góry dziękuje
Coś z .NET ;p
Wklej to co pisze w Details
Proszę, o to są “Detatils” Takie same są w pierwszym i drugim error
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
**************Exception Text**************
System.ArgumentException: Destination array was not long enough. Check destIndex and length, and the array's lower bounds.
at System.Array.Copy(Array sourceArray, Int32 sourceIndex, Array destinationArray, Int32 destinationIndex, Int32 length, Boolean reliable)
at System.Array.CopyTo(Array array, Int32 index)
at WrapperNS.Wrapper.loadOptions()
at WrapperNS.Wrapper.loadAndProcessOptions()
at WrapperNS.Wrapper.Wrapper_Shown(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnShown(EventArgs e)
at System.Windows.Forms.Form.CallShownEvent()
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean ignoreSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
**************Loaded Assemblies**************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.239 (RTMGDR.030319-2300)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
RailWorks
Assembly Version: 2.0.0.1
Win32 Version: 2.0.0.1
CodeBase: file:///D:/Gry/RailSimulator.com/Railworks%203%20Train%20Simulator%202012%20Deluxe/RailWorks.exe
Win32 Version: 4.0.30319.235 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.0.30319.1 built by: RTMRel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
Win32 Version: 4.0.30319.236 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Xml
Win32 Version: 4.0.30319.233 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
15pl1kaf
**************JIT Debugging**************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Typowy błąd w programie albo bug w .NET, poszukaj updata do Railworksa. Jak nie pomoże to odpal Windows Update i zrób update systemu.
Zaktualizowałem .NET, wgrałem update Railworks, zrobiłem update systemu i nadal to samo… ;/
