Po instalacji wyjmuje plyte ,restartuje się PC i wyskakuje komunikat Loading Grub Stage 1.5 Error Grub 15. Przedtem na win7 zainstalowałem mandrive 2011 beta, a teraz zainstalowałem ubuntu. Co robić?
/dev/sda5 - ext4 - 1000mb - /boot
/dev/sda6 - linux-swap 4000mb
/dev/sda7 - ext4 - 10 000mb - /home
/dev/sda8 - ext4 -50 000mb - /mnt/root
i /dev/sda2 - ntfs 160 000mb
grub.cfg
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [-s $prefix/grubenv]; then
  set have_grubenv=true
  load_env
fi
set default="0"
if ["${prev_saved_entry}"]; then
  set saved_entry="${prev_saved_entry}"
  save_env saved_entry
  set prev_saved_entry=
  save_env prev_saved_entry
  set boot_once=true
fi
function savedefault {
  if [-z "${boot_once}"]; then
    saved_entry="${chosen}"
  fi
function recordfail {
  set recordfail=1
  if [-n "${have_grubenv}"]; then if [-z "${boot_once}"]; then save_env recordfail; fi; fi
function load_video {
  insmod vbe
  insmod vga
insmod part_msdos
insmod ext2
set root='(hd0,msdos8)'
search --no-floppy --fs-uuid --set a5958bd1-6249-4dd7-bff2-7952c12d49c8
if loadfont /usr/share/grub/unicode.pf2 ; then
  set gfxmode=640x480
  load_video
  insmod gfxterm
fi
terminal_output gfxterm
insmod part_msdos
insmod ext2
set root='(hd0,msdos5)'
search --no-floppy --fs-uuid --set b438f1d4-79d9-4e06-b337-a74b8319562a
set locale_dir=($root)/grub/locale
set lang=pl
insmod gettext
if ["${recordfail}" = 1]; then
  set timeout=-1
else
  set timeout=10
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'Ubuntu, with Linux 2.6.35-23-generic' --class ubuntu --class gnu-linux --class gnu --class os {
	recordfail
	insmod part_msdos
	insmod ext2
	linux	/vmlinuz-2.6.35-23-generic root=UUID=a5958bd1-6249-4dd7-bff2-7952c12d49c8 ro quiet splash
	initrd	/initrd.img-2.6.35-23-generic
menuentry 'Ubuntu, with Linux 2.6.35-23-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os {
	recordfail
	insmod part_msdos
	insmod ext2
	echo	'Loading Linux 2.6.35-23-generic ...'
	linux	/vmlinuz-2.6.35-23-generic root=UUID=a5958bd1-6249-4dd7-bff2-7952c12d49c8 ro single
	echo	'Loading initial ramdisk ...'
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/20_memtest86+ ###
menuentry "Memory test (memtest86+)" {
	insmod part_msdos
	insmod ext2
	linux16	/memtest86+.bin
menuentry "Memory test (memtest86+, serial console 115200)" {
	insmod part_msdos
	insmod ext2
	linux16	/memtest86+.bin console=ttyS0,115200n8
### END /etc/grub.d/20_memtest86+ ###
### BEGIN /etc/grub.d/30_os-prober ###
if ["x${timeout}" != "x-1"]; then
  if keystatus; then
    if keystatus --shift; then
      set timeout=-1
    else
      set timeout=0
    fi
  else
    if sleep --interruptible 3 ; then
      set timeout=0
    fi
  fi
fi
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [-f $prefix/custom.cfg]; then
  source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
