jasiu0406
(Jasiu0406)
22 Sierpień 2011 16:15
#1
Witam. Padłem ofiarą wirusa Koobface (Hi wanna laugh itd.). Wszystkie wirusy z komputera usunąłem programem SUPER AntiSpyware (wcześniej też przywracałem system). Jednak teraz nie mogę odpalić Fejsa… Proszę o pomoc
OTL: http://wklej.to/DT9oM
Extras: http://wklej.to/qxXL6
Leon1
(Leon$)
22 Sierpień 2011 17:09
#2
OTL w oknie Custom Scans-Fixes (własne opcje skanowania/skrypt)wklej następujący skrypt:
:OTL PRC - [2011-08-22 11:06:35 | 000,139,776 | ---- | M] () – C:\Windows\systemup.exe PRC - [2011-08-21 14:28:46 | 000,382,464 | ---- | M] () – C:\Windows\update.7.1\svchostdriver.exe MOD - [2011-08-22 11:06:35 | 000,139,776 | ---- | M] () – C:\Windows\systemup.exe SRV - File not found [Auto | Stopped] – -- (wxpdrivers) SRV - File not found [Auto | Stopped] – -- (srviecheck) SRV - File not found [Auto | Stopped] – -- (srvbtcclient) SRV - [2011-08-21 14:28:46 | 000,382,464 | ---- | M] () [Auto | Running] – C:\Windows\update.7.1\svchostdriver.exe – (ddservice) [2010-10-19 20:41:14 | 000,000,000 | —D | M] (vShare Plugin) – C:\Users\Jasiu\AppData\Roaming\mozilla\Firefox\Profiles\813flx5r.default\extensions\vshare@toolbar O4 - HKLM…\Run: [1254476.exe] C:\Windows\Temp\1254476.exe () O4 - HKLM…\Run: [3824847.exe] C:\Users\Jasiu\AppData\Local\Temp\3824847.exe () O4 - HKLM…\Run: [71488405-loader2.exe] C:\Windows\Temp\71488405-loader2.exe () O4 - HKLM…\Run: [7771840.exe] C:\Windows\Temp\7771840.exe () O4 - HKLM…\Run: [9331553.exe] C:\Windows\Temp\9331553.exe () O4 - HKLM…\Run: [Regedit32] File not found O4 - HKLM…\Run: [systemup] C:\Windows\systemup.exe () O4 - HKLM…\Run: [tray_ico] File not found O4 - HKLM…\Run: [tray_ico1] File not found O4 - HKLM…\Run: [tray_ico2] File not found O4 - HKLM…\Run: [tray_ico3] File not found O4 - HKLM…\Run: [tray_ico4] File not found O4 - HKU\S-1-5-21-2949146295-2053388235-3070815552-1000…\Run: [conhost] File not found O4 - HKU\S-1-5-21-2949146295-2053388235-3070815552-1000…\Run: [syncables] File not found O4 - HKU\S-1-5-19…\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (Microsoft Corporation) O4 - HKU\S-1-5-20…\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (Microsoft Corporation) F3 - HKU\S-1-5-21-2949146295-2053388235-3070815552-1000 WinNT: Load - (C:\Users\Jasiu\AppData\Local\Temp\csrss.exe) - File not found [2011-08-21 14:35:43 | 000,000,000 | —D | C] – C:\Windows\ufa [2011-08-21 14:35:43 | 000,000,000 | —D | C] – C:\Windows\rpcminer [2011-08-21 14:35:43 | 000,000,000 | —D | C] – C:\Windows\phoenix [2011-08-21 14:29:50 | 000,000,000 | -H-D | C] – C:\Windows\update.5.0 [2011-08-21 14:29:11 | 000,000,000 | -H-D | C] – C:\Windows\update.2 [2011-08-21 14:28:48 | 000,000,000 | -H-D | C] – C:\Windows\update.7.1 [2011-08-21 14:27:03 | 000,000,000 | —D | C] – C:\Windows\av_ico [2011-08-21 14:25:32 | 000,000,000 | -H-D | C] – C:\Windows\update.1 [2011-08-21 14:25:28 | 000,000,000 | -H-D | C] – C:\Windows\update.tray-8-0-lnk [2011-08-21 14:25:28 | 000,000,000 | -H-D | C] – C:\Windows\update.tray-8-0 [2011-08-22 13:49:21 | 000,000,734 | ---- | M] () – C:\Windows\System32\drivers\etc\hîsts [2011-08-22 11:06:36 | 000,000,202 | ---- | M] () – C:\Windows\info1 [2011-08-22 11:06:35 | 000,139,776 | ---- | M] () – C:\Windows\systemup.exe [2011-08-21 14:35:42 | 005,589,370 | ---- | M] () – C:\Windows\phoenix.rar [2011-08-21 14:35:42 | 001,075,284 | ---- | M] () – C:\Windows\rpcminer.rar [2011-08-21 14:35:42 | 000,246,272 | ---- | M] () – C:\Windows\unrar.exe [2011-08-21 14:35:42 | 000,182,617 | ---- | M] () – C:\Windows\ufa.rar [2011-08-21 14:29:08 | 000,904,792 | ---- | M] () – C:\Windows\geoiplist.rar [2011-08-21 14:28:05 | 000,000,000 | ---- | M] () – C:\Windows\loader2.exe_ok [2011-08-21 14:29:09 | 004,636,907 | ---- | C] () – C:\Windows\geoiplist :Files C:\Users\Jasiu\AppData\Local\Temp*.html :Reg [-HKEY_CURRENT_USER\software\microsoft\windows\currentversion\explorer\mountpoints2] :Commands [CLEARALLRESTOREPOINTS] [RESETHOSTS] [emptytemp]
Kliknij w Run Fix (Wykonaj scrypt). Zatwierdź restart komputera.
Pokaż log z usuwania.
potem nowy log OTL robiony opcją Run Scan (Skanuj)
jasiu0406
(Jasiu0406)
22 Sierpień 2011 21:18
#3
Leon1
(Leon$)
22 Sierpień 2011 21:25
#4
W OTL kilknij CleanUp (Sprzątanie)
Pobierz CCleaner http://www.filehippo.com/download_ccleaner/
przeskanuj nim i wyczyść rejestr.
przeskanuj
Dr.WEB CureIt! http://www.dobreprogramy.pl/DrWEB-CureI … 12976.html
@Leon$ AlternateShell raczej nie powinno się usuwać
Zastosuj raczej ten skrypt:
Reszta według powyższego posta.
jasiu0406
(Jasiu0406)
22 Sierpień 2011 21:51
#6
A jak już zrobiłem wg poprzedniego skryptu??..
– Dodane 23.08.2011 (Wt) 0:46 –
Fejsik działa poprawnie, jeszcze czekam na wynik skanu od Dr. Web, na razie nic nie wykryło, więc powinno być OK. DZIĘKUJĘ BARDZO ZA RZETELNĄ POMOC!!
To mimo wszystko uruchom jeszcze mój skrypt.
