Problem z wypalaniem
Witam ,mam wielki problem z nagrywaniem mp3 w nero,zmarnowałem już kilkanaście plytek i nie mam pojęcia czemu po zakonczeniu nagrywania wyskakuje mi błąd,zamieszczam loga.
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File ‘C:\Program Files\Ahead\nero\Wnaspi32.dll’: Ver=2.0.1.74, size=164112 bytes, created 2004-11-02 12:54:32
NT-SPTI used
Nero Version: 6.6.1.4
Internal Version: 6, 6, 1, 4d
(Nero Express)
Recorder: Version: 1.03 - HA 1 TA 0 - 6.6.1.4
Adapter driver: HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: Version: 0015 - HA 1 TA 1 - 6.6.1.4
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD400BB-00GFA0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST CD-RW GCE-8526B atapi Port 1 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVD-ROM GDR8162B atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
HL-DT-ST CD-RW GCE-8526B E: CDRom0
HL-DT-ST DVD-ROM GDR8162B F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 40894464 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 255MB (261616kB)
Free physical memory: 57MB (58452kB)
Memory in use : 77 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
15.3.2006
CD-ROM (ISO)
09:06:48 #1 Text 0 File Isodoc.cpp, Line 6475
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
09:06:49 #2 Text 0 File Burncd.cpp, Line 3012
Włączono System ochrony zapisu
09:06:49 #3 Text 0 File ThreadedTransfer.cpp, Line 531
ReadBuffer-Pipe got 39936KB of Memory
09:06:49 #4 Text 0 File Reader.cpp, Line 124
Reader running
09:06:49 #5 Text 0 File Writer.cpp, Line 122
Writer HL-DT-ST CD-RW GCE-8526B running
09:06:49 #6 ISO9660GEN -11 File geniso.cpp, Line 3312
First writeable address = 0 (0x00000000)
09:06:49 #7 Text 0 File Burncd.cpp, Line 3305
Turn on Track-At-Once, using CD-R/RW media
09:06:49 #8 Text 0 File DlgWaitCD.cpp, Line 281
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 345311 ( 76:46.11)
09:06:49 #9 Text 0 File DlgWaitCD.cpp, Line 293
Write in overburning mode: NO (enabled: CD)
09:06:49 #10 Text 0 File DlgWaitCD.cpp, Line 2612
Recorder: HL-DT-ST CD-RW GCE-8526B;
CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd.
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 1B 12 (LI 97:27.18), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
09:06:49 #11 Text 0 File DlgWaitCD.cpp, Line 459
>>> Protocol of DlgWaitCD activities: <<<
09:06:49 #12 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 345312 (345312) = #345312/76:44.12
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 345310 blocks [HL-DT-ST CD-RW GCE-8526B]
09:06:50 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [HL-DT-ST CD-RW GCE-8526B] for write in TAO
DAO infos:
MCN: “”
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 707506176, ISRC “”
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
-150 | lead-in | 0 | 0x41 | 0x00
-150 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
345312 | lead-out | 1 | 0x41 | 0x00
09:06:50 #14 Text 0 File ThreadedTransferInterface.cpp, Line 1127
Removed 2 run-out blocks from end of track 1. Length: 345312 -> 345310.
09:06:50 #15 Text 0 File SCSIPassThrough.cpp, Line 38
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
09:06:50 #16 Text 0 File SCSIPassThrough.cpp, Line 83
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
09:06:50 #17 Phase 24 File dlgbrnst.cpp, Line 1685
Caching of files started
09:06:50 #18 Text 0 File Burncd.cpp, Line 4145
Cache writing successful.
09:06:50 #19 Phase 25 File dlgbrnst.cpp, Line 1685
Caching of files completed
09:06:50 #20 Phase 36 File dlgbrnst.cpp, Line 1685
Burn process started at 52x (7 800 KB/s)
09:06:50 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
09:06:50 #22 Text 0 File Mmc.cpp, Line 21840
Set BUFE: Buffer underrun protection -> ON
09:11:28 #23 SPTI -1135 File SCSIPassThrough.cpp, Line 289
E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 04 92 C0 00 00 20 00 00 00
Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 0C
Buffer x09610000: Len x10000
0x45 45 D7 D2 44 31 8C CA 3F 57 71 D1 66 C6 94 2C
0xF0 A4 6C F5 19 82 B7 38 AC 5C 4B 56 8E 28 84 60
0x82 8F 4C 20 FA BF 30 4E 5A 5E A9 E6 53 53 2B 58
09:11:28 #24 CDR -1135 File Writer.cpp, Line 311
Write error
E: HL-DT-ST CD-RW GCE-8526B
09:11:28 #25 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
09:11:29 #26 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
09:11:29 #27 CDR -201 File WriterStatus.cpp, Line 200
Invalid write state
09:11:29 #28 TRANSFER -18 File WriterStatus.cpp, Line 200
Could not perform EndTrack
09:11:29 #29 Text 0 File Mmc.cpp, Line 16608
start Close Session
09:12:03 #30 Phase 38 File dlgbrnst.cpp, Line 1685
Burn process failed at 52x (7 800 KB/s)
Existing drivers:
File ‘Drivers\PXHELP20.SYS’: Ver=2.03.28a, size=20640 bytes, created 2005-12-05 06:12:26 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
szkoda że nie wlozyłeś korby do napędu i nie próbowałeś nagrywać jeszcze szybciej poza mozliwości napędu , zwolnij przynajmniej o połowe tą(x52) szybkość nagrywania a powinno być ok. Wydaje mi sie że masz coś z firmware w nagrywarce nie tak , nagrywarka powinna dostosować predkość nagrywania do możliwości płyty , proponuje uaktualnić firmware, możliwe też ze masz ją źle podpietą do kabla , zamienić eksperymentlnie wtyczki ATA podpiąć tą z drugiego napędu a tą z LG do tamtego.
Kurde,zawsze nagrywam z tą prędkością i nigdy nie było najmniejszego problemu,dopiero od wczoraj tak się dzieje,a co dziwniejszeze jedne pliki nagrywają się z ta predkością bez kłopotu a inne własnie jak wynika z powyższego logu.Spróbuje zmniejszyć prędkość.
Może na innym nośniku :?
To co wypisują producenci płyt nie zawsze jest zgodne z prawdą.
Wypalanie z maksymalną prędkością jaką oferuje napęd zawsze wiąże się z ryzykiem powstania błędów w trakcie zapisu :!:
Zmień nośnik na lepszy zmniejsz predkość nagrywania i napisz czy sytuacja sie powtórzy.
Własnie zmarnowałem kolejną plytke którą nagrywałem ze zmniejszoną prędkością,te same pliki nagrałem na CD-RW i ponownie to samo,bląd.
W takim razie może to wina Nero.
Spróbuj użyć innego programu do wypalania lub przeinstaluj Nero.
Korzystasz z Nero 6 czy 7?
Jeśli 6 sprawdź czy masz najnowszą jej wersję, jeśli nie - uaktualnij.
Sytuacja przedstawia się następująco,przeinstalowałem nero i zmieniło sie tyle ze raz sie nagrywa a raz nie,czyli jest jeszcze gorzej.
Złączono Posta : 15.03.2006 (Sro) 15:45
Zaobserwowałem równiez że filmy nagrywa za kazdym razem natomiast mp3 nie zawsze.
