Mam problem. Mam amd sempron 2800 ,karte graficzną g-force nx6600 (najnowsze sterowniki), 512 ram i win xp home sp2.
Otórz po formacie systemu gry zaczeły się zacinać. Próbowałem już wszystkiego. Skoki są na ułamek sekundy ale przed formatem nawet na wyższych detalach chodziło płynnie
Proszę o pomoc
StartupList report, 2006-11-30, 07:34:02
StartupList version: 1.52.2
Started from : E:\a\HijackThis.EXE
Detected: Windows XP Dodatek SP2 (WinNT 5.01.2600)
Detected: Internet Explorer v7.00 (7.00.5730.0011)
* Using default options
* Including empty and uninteresting sections
* Showing rarely important sections
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\Netropa\Multimedia Keyboard\nhksrv.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Alwil Software\Avast4\ashServ.exe
C:\WINDOWS\system32\nvsvc32.exe
C:\WINDOWS\system32\MsPMSPSv.exe
C:\WINDOWS\system32\CTHELPER.EXE
C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
C:\WINDOWS\system32\WinSys.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
C:\Program Files\Wanadoo\EspaceWanadoo.exe
C:\Program Files\Wanadoo\ComComp.exe
C:\Program Files\Wanadoo\Watch.exe
E:\a\HijackThis.exe
Listing of startup folders:
Shell folders Startup:
[C]
*No files*
Shell folders AltStartup:
*Folder not found*
User shell folders Startup:
*Folder not found*
User shell folders AltStartup:
*Folder not found*
Shell folders Common Startup:
[C]
*No files*
Shell folders Common AltStartup:
*Folder not found*
User shell folders Common Startup:
*Folder not found*
User shell folders Alternate Common Startup:
*Folder not found*
Checking Windows NT UserInit:
[HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon]
UserInit = C:\WINDOWS\system32\userinit.exe,
[HKLM\Software\Microsoft\Windows\CurrentVersion\Winlogon]
*Registry key not found*
[HKCU\Software\Microsoft\Windows NT\CurrentVersion\Winlogon]
*Registry value not found*
[HKCU\Software\Microsoft\Windows\CurrentVersion\Winlogon]
Autorun entries from Registry:
HKLM\Software\Microsoft\Windows\CurrentVersion\Run
WINDVDPatch = CTHELPER.EXE
UpdReg = C:\WINDOWS\UpdReg.EXE
SW20 = C:\WINDOWS\system32\sw20.exe
SW24 = C:\WINDOWS\system32\sw24.exe
NvCplDaemon = RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
avast! = C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
nwiz = nwiz.exe /install
HKLM\Software\Microsoft\Windows\CurrentVersion\RunOnce
*No values found*
HKLM\Software\Microsoft\Windows\CurrentVersion\RunOnceEx
*No values found*
HKLM\Software\Microsoft\Windows\CurrentVersion\RunServices
HKLM\Software\Microsoft\Windows\CurrentVersion\RunServicesOnce
HKCU\Software\Microsoft\Windows\CurrentVersion\Run
ctfmon.exe = C:\WINDOWS\system32\ctfmon.exe
HKCU\Software\Microsoft\Windows\CurrentVersion\RunOnce
*No values found*
HKCU\Software\Microsoft\Windows\CurrentVersion\RunOnceEx
HKCU\Software\Microsoft\Windows\CurrentVersion\RunServices
HKCU\Software\Microsoft\Windows\CurrentVersion\RunServicesOnce
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Run
HKCU\Software\Microsoft\Windows NT\CurrentVersion\Run
Autorun entries in Registry subkeys of:
[OptionalComponents]
*No values found*
*No subkeys found*
*No subkeys found*
*No subkeys found*
*No subkeys found*
File association entry for .EXE:
HKEY_CLASSES_ROOT\exefile\shell\open\command
(Default) = "%1" %*
File association entry for .COM:
HKEY_CLASSES_ROOT\comfile\shell\open\command
(Default) = "%1" %*
File association entry for .BAT:
HKEY_CLASSES_ROOT\batfile\shell\open\command
(Default) = "%1" %*
File association entry for .PIF:
HKEY_CLASSES_ROOT\piffile\shell\open\command
(Default) = "%1" %*
File association entry for .SCR:
HKEY_CLASSES_ROOT\scrfile\shell\open\command
(Default) = "%1" /S
File association entry for .HTA:
HKEY_CLASSES_ROOT\htafile\shell\open\command
(Default) = C:\WINDOWS\system32\mshta.exe "%1" %*
File association entry for .TXT:
HKEY_CLASSES_ROOT\txtfile\shell\open\command
(Default) = %SystemRoot%\system32\NOTEPAD.EXE %1
Enumerating Active Setup stub paths:
HKLM\Software\Microsoft\Active Setup\Installed Components
(* = disabled by HKCU twin)
[<{12d0ed0d-0ee0-4f90-8827-78cefb8f4988}] *
StubPath = C:\WINDOWS\system32\ieudinit.exe
[>{22d6f312-b0f6-11d0-94ab-0080c74c7e95}]
StubPath = C:\WINDOWS\inf\unregmp2.exe /ShowWMP
[>{26923b43-4d38-484f-9b9e-de460746276c}] *
StubPath = C:\WINDOWS\system32\ie4uinit.exe -UserIconConfig
[>{60B49E34-C7CC-11D0-8953-00A0C90347FF}] *
StubPath = RunDLL32 IEDKCS32.DLL,BrandIE4 SIGNUP
[>{60B49E34-C7CC-11D0-8953-00A0C90347FF}MICROS] *
[>{881dd1c5-3dcf-431b-b061-f3f88e8be88a}] *
StubPath = %systemroot%\system32\shmgrate.exe OCInstallUserConfigOE
[{2C7339CF-2B09-4501-B3F3-F3508C9228ED}] *
StubPath = %SystemRoot%\system32\regsvr32.exe /s /n /i:/UserInstall %SystemRoot%\system32\themeui.dll
[{44BBA840-CC51-11CF-AAFA-00AA00B6015C}] *
StubPath = "%ProgramFiles%\Outlook Express\setup50.exe" /APP:OE /CALLER:WINNT /user /install
[{44BBA842-CC51-11CF-AAFA-00AA00B6015B}] *
StubPath = rundll32.exe advpack.dll,LaunchINFSection C:\WINDOWS\INF\msnetmtg.inf,NetMtg.Install.PerUser.NT
[{5945c046-1e7d-11d1-bc44-00c04fd912be}] *
StubPath = rundll32.exe advpack.dll,LaunchINFSection C:\WINDOWS\INF\msmsgs.inf,BLC.QuietInstall.PerUser
[{6BF52A52-394A-11d3-B153-00C04F79FAA6}] *
StubPath = rundll32.exe advpack.dll,LaunchINFSection C:\WINDOWS\INF\wmp10.inf,PerUserStub
[{7790769C-0471-11d2-AF11-00C04FA35D02}] *
StubPath = "%ProgramFiles%\Outlook Express\setup50.exe" /APP:WAB /CALLER:WINNT /user /install
[{89820200-ECBD-11cf-8B85-00AA005B4340}] *
StubPath = regsvr32.exe /s /n /i:U shell32.dll
[{89820200-ECBD-11cf-8B85-00AA005B4383}] *
StubPath = C:\WINDOWS\system32\ie4uinit.exe -BaseSettings
Enumerating ICQ Agent Autostart apps:
HKCU\Software\Mirabilis\ICQ\Agent\Apps
Load/Run keys from C:\WINDOWS\WIN.INI:
load=*INI section not found*
run=*INI section not found*
Load/Run keys from Registry:
HKLM\..\Windows NT\CurrentVersion\WinLogon: load=*Registry value not found*
HKLM\..\Windows NT\CurrentVersion\WinLogon: run=*Registry value not found*
HKLM\..\Windows\CurrentVersion\WinLogon: load=*Registry key not found*
HKLM\..\Windows\CurrentVersion\WinLogon: run=*Registry key not found*
HKCU\..\Windows NT\CurrentVersion\WinLogon: load=*Registry value not found*
HKCU\..\Windows NT\CurrentVersion\WinLogon: run=*Registry value not found*
HKCU\..\Windows\CurrentVersion\WinLogon: load=*Registry key not found*
HKCU\..\Windows\CurrentVersion\WinLogon: run=*Registry key not found*
HKCU\..\Windows NT\CurrentVersion\Windows: load=
HKCU\..\Windows NT\CurrentVersion\Windows: run=*Registry value not found*
HKLM\..\Windows NT\CurrentVersion\Windows: load=*Registry value not found*
HKLM\..\Windows NT\CurrentVersion\Windows: run=*Registry value not found*
HKLM\..\Windows NT\CurrentVersion\Windows: AppInit_DLLs=
Shell & screensaver key from C:\WINDOWS\SYSTEM.INI:
Shell=*INI section not found*
SCRNSAVE.EXE=*INI section not found*
drivers=*INI section not found*
Shell & screensaver key from Registry:
Shell=Explorer.exe
SCRNSAVE.EXE=*Registry value not found*
drivers=*Registry value not found*
Policies Shell key:
HKCU\..\Policies: Shell=*Registry value not found*
HKLM\..\Policies: Shell=*Registry value not found*
Checking for EXPLORER.EXE instances:
C:\WINDOWS\Explorer.exe: PRESENT!
C:\Explorer.exe: not present
C:\WINDOWS\Explorer\Explorer.exe: not present
C:\WINDOWS\System\Explorer.exe: not present
C:\WINDOWS\System32\Explorer.exe: not present
C:\WINDOWS\Command\Explorer.exe: not present
C:\WINDOWS\Fonts\Explorer.exe: not present
Checking for superhidden extensions:
.lnk: HIDDEN! (arrow overlay: yes)
.pif: HIDDEN! (arrow overlay: yes)
.exe: not hidden
.com: not hidden
.bat: not hidden
.hta: not hidden
.scr: not hidden
.shs: HIDDEN!
.shb: HIDDEN!
.vbs: not hidden
.vbe: not hidden
.wsh: not hidden
.scf: HIDDEN! (arrow overlay: NO!)
.url: HIDDEN! (arrow overlay: yes)
.js: not hidden
.jse: not hidden
Verifying REGEDIT.EXE integrity:
- Regedit.exe found in C:\WINDOWS
- .reg open command is normal (regedit.exe %1)
- Company name OK: 'Microsoft Corporation'
- Original filename OK: 'REGEDIT.EXE'
- File description: 'Edytor rejestru'
Registry check passed
Enumerating Browser Helper Objects:
*No BHO's found*
Enumerating Task Scheduler jobs:
*No jobs found*
Enumerating Download Program Files:
[Windows Genuine Advantage Validation Tool]
InProcServer32 = C:\WINDOWS\system32\LegitCheckControl.DLL
CODEBASE = http://go.microsoft.com/fwlink/?LinkID=39204
[MUWebControl Class]
InProcServer32 = C:\WINDOWS\system32\muweb.dll
CODEBASE = http://update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1159813734218
[Java Plug-in 1.3.1_03]
InProcServer32 = C:\Program Files\JavaSoft\JRE\1.3.1_03\bin\npjava131_03.dll
CODEBASE = http://java.sun.com/products/plugin/1.3.1/jinstall-131_03-win.cab
[Update Class]
InProcServer32 = C:\WINDOWS\system32\iuctl.dll
CODEBASE = http://v4.windowsupdate.microsoft.com/CAB/x86/unicode/iuctl.CAB?39029.3111689815
[Shockwave Flash Object]
InProcServer32 = C:\WINDOWS\system32\Macromed\Flash\Flash9.ocx
CODEBASE = http://fpdownload.macromedia.com/pub/shockwave/cabs/flash/swflash.cab
Enumerating Winsock LSP files:
NameSpace #1: C:\WINDOWS\System32\mswsock.dll
NameSpace #2: C:\WINDOWS\System32\winrnr.dll
NameSpace #3: C:\WINDOWS\System32\mswsock.dll
Protocol #1: C:\WINDOWS\system32\mswsock.dll
Protocol #2: C:\WINDOWS\system32\mswsock.dll
Protocol #3: C:\WINDOWS\system32\mswsock.dll
Protocol #4: C:\WINDOWS\system32\rsvpsp.dll
Protocol #5: C:\WINDOWS\system32\rsvpsp.dll
Protocol #6: C:\WINDOWS\system32\mswsock.dll
Protocol #7: C:\WINDOWS\system32\mswsock.dll
Protocol #8: C:\WINDOWS\system32\mswsock.dll
Protocol #9: C:\WINDOWS\system32\mswsock.dll
Protocol #10: C:\WINDOWS\system32\mswsock.dll
Protocol #11: C:\WINDOWS\system32\mswsock.dll
Protocol #12: C:\WINDOWS\system32\mswsock.dll
Protocol #13: C:\WINDOWS\system32\mswsock.dll
Protocol #14: C:\WINDOWS\system32\mswsock.dll
Protocol #15: C:\WINDOWS\system32\mswsock.dll
Protocol #16: C:\WINDOWS\system32\mswsock.dll
Protocol #17: C:\WINDOWS\system32\mswsock.dll
Enumerating Windows NT/2000/XP services
Sterownik Microsoft ACPI: system32\DRIVERS\ACPI.sys (system)
General Purpose USB Driver (adildr.sys): System32\Drivers\adildr.sys (autostart)
USB ADSL WAN Adapter: system32\DRIVERS\adiusbaw.sys (manual start)
Microsoft Kernel Acoustic Echo Canceller: system32\drivers\aec.sys (manual start)
AFD: \SystemRoot\System32\drivers\afd.sys (system)
Urządzenie alarmowe: %SystemRoot%\system32\svchost.exe -k LocalService (manual start)
Usługa bramy warstwy aplikacji: %SystemRoot%\System32\alg.exe (manual start)
Sterownik procesora AMD K7: system32\DRIVERS\amdk7.sys (system)
Zarządzanie aplikacjami: %SystemRoot%\system32\svchost.exe -k netsvcs (manual start)
avast! iAVS4 Control Service: "C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe" (autostart)
Sterownik multimediów asynchronicznych RAS: system32\DRIVERS\asyncmac.sys (manual start)
Standardowy kontroler dysku twardego IDE/ESDI: system32\DRIVERS\atapi.sys (system)
Protokół klienta ARP ATM: system32\DRIVERS\atmarpc.sys (manual start)
Windows Audio: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
Sterownik Audio Stub: system32\DRIVERS\audstub.sys (manual start)
avast! Antivirus: "C:\Program Files\Alwil Software\Avast4\ashServ.exe" (autostart)
avast! Mail Scanner: "C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe" /service (manual start)
avast! Web Scanner: "C:\Program Files\Alwil Software\Avast4\ashWebSv.exe" /service (manual start)
Usługa inteligentnego transferu w tle: %SystemRoot%\system32\svchost.exe -k netsvcs (manual start)
Bluetooth Audio Service: system32\DRIVERS\blueletaudio.sys (manual start)
Bluetooth SCO Audio Service: system32\DRIVERS\BlueletSCOAudio.sys (manual start)
BlueSoleil Hid Service: C:\Program Files\IVT Corporation\BlueSoleil\BTNtService.exe (autostart)
Przeglądarka komputera: %SystemRoot%\system32\svchost.exe -k netsvcs (manual start)
Bluetooth PAN Network Adapter: system32\DRIVERS\btnetdrv.sys (manual start)
Bluetooth USB For Bluetooth Service: System32\Drivers\btcusb.sys (manual start)
Bluetooth HID Enumerator: system32\DRIVERS\vbtenum.sys (manual start)
Bluetooth HID Manager Service: System32\Drivers\BTHidMgr.sys (system)
Bluetooth Network Filter: \??\C:\Program Files\IVT Corporation\BlueSoleil\Device\Win2k\BTNetFilter.sys (manual start)
Dekoder napisów: system32\DRIVERS\CCDECODE.sys (manual start)
Sterownik stacji dysków CD-ROM: system32\DRIVERS\cdrom.sys (system)
Usługa indeksowania: %SystemRoot%\system32\cisvc.exe (disabled)
ClipBook: %SystemRoot%\system32\clipsrv.exe (disabled)
Aplikacja systemowa modelu COM+: C:\WINDOWS\system32\dllhost.exe /Processid:{02D4B3F1-FD88-11D1-960D-00805FC79235} (manual start)
Creative Service for CDROM Access: C:\WINDOWS\system32\CTsvcCDA.exe (autostart)
Usługi kryptograficzne: %SystemRoot%\system32\svchost.exe -k netsvcs (manual start)
Creative AC3 Software Decoder: System32\drivers\ctac32k.sys (manual start)
Creative Audio Driver (WDM): system32\drivers\ctaud2k.sys (manual start)
Port gier dla karty Creative SB Live!: system32\DRIVERS\ctljystk.sys (manual start)
Creative Proxy Driver: System32\drivers\ctprxy2k.sys (manual start)
Creative SoundFont Management Device Driver: System32\drivers\ctsfm2k.sys (manual start)
Program uruchamiający proces serwera DCOM: %SystemRoot%\system32\svchost -k DcomLaunch (autostart)
Klient DHCP: %SystemRoot%\system32\svchost.exe -k netsvcs (autostart)
Sterownik dysku: system32\DRIVERS\disk.sys (system)
Usługa administracyjna Menedżera dysków logicznych: %SystemRoot%\System32\dmadmin.exe /com (manual start)
dmboot: System32\drivers\dmboot.sys (disabled)
dmio: System32\drivers\dmio.sys (disabled)
dmload: System32\drivers\dmload.sys (disabled)
Menedżer dysków logicznych: %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
Syntezator Microsoft Kernel DLS: system32\drivers\DMusic.sys (manual start)
Klient DNS: %SystemRoot%\system32\svchost.exe -k NetworkService (autostart)
Dot4 HPH11: system32\DRIVERS\hphid411.sys (manual start)
Print Class Driver for IEEE-1284.4 HPH11: system32\DRIVERS\hphipr11.sys (manual start)
Dot4Usb HPH11: System32\drivers\hphius11.sys (manual start)
Microsoft Kernel DRM Audio Descrambler: system32\drivers\drmkaud.sys (manual start)
E-mu Plug-in Architecture Driver: System32\drivers\emupia2k.sys (manual start)
Usługa raportowania błędów: %SystemRoot%\System32\svchost.exe -k netsvcs (disabled)
Dziennik zdarzeń: %SystemRoot%\system32\services.exe (autostart)
System zdarzeń COM+: C:\WINDOWS\system32\svchost.exe -k netsvcs (manual start)
Zgodność szybkiego przełączania użytkowników: %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
Sterownik kontrolera stacji dyskietek: system32\DRIVERS\fdc.sys (manual start)
Sterownik stacji dyskietek: system32\DRIVERS\flpydisk.sys (manual start)
FltMgr: system32\DRIVERS\fltMgr.sys (system)
Sterownik Menedżera woluminów: system32\DRIVERS\ftdisk.sys (system)
Licznik portów gier: system32\DRIVERS\gameenum.sys (manual start)
GMSIPCI: \??\H:\INSTALL\GMSIPCI.SYS (manual start)
Rodzajowy klasyfikator pakietu: system32\DRIVERS\msgpc.sys (manual start)
715 USB Scanner Driver: system32\drivers\gt680x.sys (manual start)
Creative Hardware Abstract Layer Driver: system32\drivers\ha10kx2k.sys (manual start)
Pomoc i obsługa techniczna: %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
Dostęp do urządzeń interfejsu HID: %SystemRoot%\System32\svchost.exe -k netsvcs (disabled)
HTTP: System32\Drivers\HTTP.sys (manual start)
HTTP SSL: %SystemRoot%\System32\svchost.exe -k HTTPFilter (manual start)
Sterownik portu klawiatury i8042 i myszy PS/2: system32\DRIVERS\i8042prt.sys (system)
Sterownik filtru nagrywania dysków CD: system32\DRIVERS\imapi.sys (system)
Usługa COM nagrywania dysków CD IMAPI: C:\WINDOWS\system32\imapi.exe (manual start)
Sterownik Zapory systemu Windows IPv6: system32\DRIVERS\Ip6Fw.sys (manual start)
Sterownik filtru ruchu IP: system32\DRIVERS\ipfltdrv.sys (manual start)
Sterownik IP w tunelu IP: system32\DRIVERS\ipinip.sys (manual start)
Translator adresów sieciowych IP: system32\DRIVERS\ipnat.sys (manual start)
Sterownik IPSEC: system32\DRIVERS\ipsec.sys (system)
Usługa wyliczania IR: system32\DRIVERS\irenum.sys (manual start)
Sterownik PnP magistrali ISA/EISA: system32\DRIVERS\isapnp.sys (system)
Sterownik klasy klawiatury: system32\DRIVERS\kbdclass.sys (system)
Sterownik klawiatury HID: system32\DRIVERS\kbdhid.sys (system)
Microsoft Kernel Wave Audio Mixer: system32\drivers\kmixer.sys (manual start)
Serwer: %SystemRoot%\system32\svchost.exe -k netsvcs (autostart)
Stacja robocza: %SystemRoot%\system32\svchost.exe -k netsvcs (autostart)
Pomoc TCP/IP NetBIOS: %SystemRoot%\system32\svchost.exe -k LocalService (autostart)
NetMeeting Remote Desktop Sharing: C:\WINDOWS\system32\mnmsrvc.exe (disabled)
Sterownik klasy myszy: system32\DRIVERS\mouclass.sys (system)
Sterownik myszy HID: system32\DRIVERS\mouhid.sys (manual start)
Readresator klienta WebDav: system32\DRIVERS\mrxdav.sys (manual start)
MRXSMB: system32\DRIVERS\mrxsmb.sys (system)
Distributed Transaction Coordinator: C:\WINDOWS\system32\msdtc.exe (disabled)
Multimedia Keyboard Filter Driver: System32\DRIVERS\msikbd2k.sys (system)
Instalator Windows: C:\WINDOWS\system32\msiexec.exe /V (manual start)
Serwer proxy usługi Microsoft Streaming: system32\drivers\MSKSSRV.sys (manual start)
Serwer proxy zegara Microsoft Streaming: system32\drivers\MSPCLOCK.sys (manual start)
Serwer proxy menedżera jakości Microsoft Streaming: system32\drivers\MSPQM.sys (manual start)
Sterownik BIOS zarządzania systemem firmy Microsoft: system32\DRIVERS\mssmbios.sys (manual start)
Konwerter strumieni Tee/Sink-to-Sink Microsoft Streaming: system32\drivers\MSTEE.sys (manual start)
Sterownik portu MIDI UART Microsoft MPU-401: system32\drivers\msmpu401.sys (manual start)
Koder-dekoder NABTS/FEC VBI: system32\DRIVERS\NABTSFEC.sys (manual start)
Połączenie TV/wideo firmy Microsoft: system32\DRIVERS\NdisIP.sys (manual start)
Sterownik usługi Dostęp zdalny NDIS TAPI: system32\DRIVERS\ndistapi.sys (manual start)
Protokół We/Wy trybu użytkownika NDIS: system32\DRIVERS\ndisuio.sys (manual start)
Sterownik usługi Dostęp zdalny NDIS WAN: system32\DRIVERS\ndiswan.sys (manual start)
Interfejs NetBIOS: system32\DRIVERS\netbios.sys (system)
NetBios przez TCP/IP: system32\DRIVERS\netbt.sys (system)
DDE sieci: %SystemRoot%\system32\netdde.exe (disabled)
DSDM DDE sieci: %SystemRoot%\system32\netdde.exe (disabled)
Logowanie do sieci: %SystemRoot%\system32\lsass.exe (manual start)
Połączenia sieciowe: %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
Netropa NHK Server: C:\Program Files\Netropa\Multimedia Keyboard\nhksrv.exe (autostart)
Rozpoznawanie lokalizacji w sieci (NLA): %SystemRoot%\system32\svchost.exe -k netsvcs (manual start)
Usługa NT LM Security Support Provider: %SystemRoot%\system32\lsass.exe (manual start)
Magazyn wymienny: %SystemRoot%\system32\svchost.exe -k netsvcs (manual start)
nv: system32\DRIVERS\nv4_mini.sys (manual start)
nVidia WDM Video Capture (universal): system32\DRIVERS\nvcap.sys (autostart)
NVIDIA Display Driver Service: %SystemRoot%\system32\nvsvc32.exe (autostart)
nVidia WDM A/V Crossbar: system32\DRIVERS\NVxbar.sys (autostart)
NVIDIA nForce AGP Bus Filter: system32\DRIVERS\nv_agp.sys (system)
Sterownik filtru ruchu IPX: system32\DRIVERS\nwlnkflt.sys (manual start)
Sterownik usług przesyłania dalej ruchu IPX: system32\DRIVERS\nwlnkfwd.sys (manual start)
Creative OS Services Driver: system32\drivers\ctoss2k.sys (manual start)
Sterownik portu równoległego: system32\DRIVERS\parport.sys (manual start)
PCI Bus Driver: system32\DRIVERS\pci.sys (system)
PCIIde: system32\DRIVERS\pciide.sys (system)
PfModNT: \??\C:\WINDOWS\system32\drivers\PfModNT.sys (autostart)
Plug and Play: %SystemRoot%\system32\services.exe (autostart)
Pml Driver HPH11: C:\WINDOWS\system32\HPHipm11.exe (manual start)
Usługi IPSEC: %SystemRoot%\system32\lsass.exe (manual start)
WAN Miniport (PPTP): system32\DRIVERS\raspptp.sys (manual start)
Magazyn chroniony: %SystemRoot%\system32\lsass.exe (autostart)
Harmonogram pakietów QoS: system32\DRIVERS\psched.sys (manual start)
Sterownik bezpośredniego połączenia kablowego: system32\DRIVERS\ptilink.sys (manual start)
Sterownik automatycznego połączenia dostępu zdalnego: system32\DRIVERS\rasacd.sys (system)
Menedżer autopołączenia dostępu zdalnego: %SystemRoot%\system32\svchost.exe -k netsvcs (manual start)
WAN Miniport (L2TP): system32\DRIVERS\rasl2tp.sys (manual start)
Menedżer połączeń usługi Dostęp zdalny: %SystemRoot%\system32\svchost.exe -k netsvcs (manual start)
Sterownik usługi Dostęp zdalny PPPOE: system32\DRIVERS\raspppoe.sys (manual start)
Bezpośrednie połączenie kablowe: system32\DRIVERS\raspti.sys (manual start)
Rdbss: system32\DRIVERS\rdbss.sys (system)
RDPCDD: System32\DRIVERS\RDPCDD.sys (system)
Menedżer sesji pomocy pulpitu zdalnego: C:\WINDOWS\system32\sessmgr.exe (disabled)
Sterownik filtru odtwarzania audio cyfrowych dysków CD: system32\DRIVERS\redbook.sys (system)
Routing i dostęp zdalny: %SystemRoot%\system32\svchost.exe -k netsvcs (manual start)
Microsoft Legacy Modem Driver: System32\Drivers\RootMdm.sys (manual start)
Lokalizator usługi zdalnego wywołania procedury (RPC): %SystemRoot%\system32\locator.exe (manual start)
Zdalne wywoływanie procedur (RPC): %SystemRoot%\system32\svchost -k rpcss (autostart)
QoS RSVP: %SystemRoot%\system32\rsvp.exe (disabled)
Menedżer kont zabezpieczeń: %SystemRoot%\system32\lsass.exe (manual start)
Karta inteligentna: %SystemRoot%\System32\SCardSvr.exe (manual start)
Harmonogram zadań: %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
Secdrv: system32\DRIVERS\secdrv.sys (autostart)
Logowanie pomocnicze: %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
Zawiadomienie o zdarzeniu systemowym: %SystemRoot%\system32\svchost.exe -k netsvcs (autostart)
Serenum Filter Driver: system32\DRIVERS\serenum.sys (manual start)
Sterownik portu szeregowego: system32\DRIVERS\serial.sys (system)
Zapora systemu Windows/Udostępnianie połączenia internetowego: %SystemRoot%\system32\svchost.exe -k netsvcs (autostart)
Wykrywanie sprzętu powłoki: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
BDA Slip De-Framer: system32\DRIVERS\SLIP.sys (manual start)
Microsoft Kernel Audio Splitter: system32\drivers\splitter.sys (manual start)
Bufor wydruku: %SystemRoot%\system32\spoolsv.exe (autostart)
Sterownik filtru Przywracania systemu: \SystemRoot\system32\DRIVERS\sr.sys (disabled)
Usługa przywracania systemu: %SystemRoot%\system32\svchost.exe -k netsvcs (autostart)
Srv: system32\DRIVERS\srv.sys (manual start)
Usługa odnajdywania SSDP: %SystemRoot%\system32\svchost.exe -k LocalService (manual start)
Windows Image Acquisition (WIA): %SystemRoot%\system32\svchost.exe -k imgsvc (manual start)
BDA IPSink: system32\DRIVERS\StreamIP.sys (manual start)
Sterownik magistrali programowej: system32\DRIVERS\swenum.sys (manual start)
Syntezator tablicy dźwięków WAVE Microsoft Kernel GS: system32\drivers\swmidi.sys (manual start)
MS Software Shadow Copy Provider: C:\WINDOWS\system32\dllhost.exe /Processid:{3212D59D-5859-474A-8627-E56330490AF9} (disabled)
Urządzenie audio Microsoft Kernel System: system32\drivers\sysaudio.sys (manual start)
Dzienniki wydajności i alerty: %SystemRoot%\system32\smlogsvc.exe (disabled)
Telefonia: %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
Sterownik protokołu TCP/IP: system32\DRIVERS\tcpip.sys (system)
Sterownik urządzenia terminalu: system32\DRIVERS\termdd.sys (system)
Usługi terminalowe: %SystemRoot%\System32\svchost -k DComLaunch (disabled)
Kompozycje: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
Klient śledzenia łączy rozproszonych: %SystemRoot%\system32\svchost.exe -k netsvcs (disabled)
Windows User Mode Driver Framework: C:\WINDOWS\system32\wdfmgr.exe (autostart)
Sterownik Microcode Update: system32\DRIVERS\update.sys (manual start)
Host uniwersalnego urządzenia Plug and Play: %SystemRoot%\system32\svchost.exe -k LocalService (manual start)
Zasilacz awaryjny (UPS): %SystemRoot%\System32\ups.exe (manual start)
USB to Serial Bridge Controller: System32\Drivers\usb2vcom.sys (manual start)
Sterownik Miniport rozszerzonego kontrolera hosta USB 2.0 Microsoft: system32\DRIVERS\usbehci.sys (manual start)
Koncentrator z obsługą USB2: system32\DRIVERS\usbhub.sys (manual start)
Sterownik Miniport otwartego kontrolera hosta USB Microsoft: system32\DRIVERS\usbohci.sys (manual start)
Klasa PRINTER USB Microsoft: system32\DRIVERS\usbprint.sys (manual start)
Sterownik magazynu masowego USB: system32\DRIVERS\USBSTOR.SYS (manual start)
Virtual Serial port driver: system32\DRIVERS\VComm.sys (manual start)
Bluetooth VComm Manager Service: System32\Drivers\VcommMgr.sys (manual start)
VgaSave: \SystemRoot\System32\drivers\vga.sys (system)
Bluetooth HID Device Service: system32\drivers\VHIDMini.sys (manual start)
Kopiowanie woluminów w tle: %SystemRoot%\System32\vssvc.exe (manual start)
Usługa Czas systemu Windows: %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
Sterownik usługi Dostęp zdalny IP ARP: system32\DRIVERS\wanarp.sys (manual start)
Sterownik zgodności audio Microsoft WINMM WDM: system32\drivers\wdmaud.sys (manual start)
WebClient: %SystemRoot%\system32\svchost.exe -k LocalService (manual start)
Instrumentacja zarządzania Windows: %systemroot%\system32\svchost.exe -k netsvcs (autostart)
WMDM PMSP Service: C:\WINDOWS\system32\MsPMSPSv.exe (autostart)
Usługa numeru seryjnego multimediów przenośnych: %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
Karta wydajności WMI: C:\WINDOWS\system32\wbem\wmiapsrv.exe (disabled)
Centrum zabezpieczeń: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
Kodery-dekodery teletekstu w standardzie światowym: system32\DRIVERS\WSTCODEC.SYS (manual start)
Aktualizacje automatyczne: %systemroot%\system32\svchost.exe -k netsvcs (autostart)
Konfiguracja zerowej sieci bezprzewodowej: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
Usługa dostarczania sieci: %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
Enumerating Windows NT logon/logoff scripts:
*No scripts set to run*
Windows NT checkdisk command:
BootExecute = autocheck autochk *
Windows NT 'Wininit.ini':
PendingFileRenameOperations: *Registry value not found*
Enumerating ShellServiceObjectDelayLoad items:
PostBootReminder: C:\WINDOWS\system32\SHELL32.dll
CDBurn: C:\WINDOWS\system32\SHELL32.dll
WebCheck: C:\WINDOWS\system32\webcheck.dll
SysTray: C:\WINDOWS\system32\stobject.dll
HKCU\Software\Microsoft\Windows\CurrentVersion\policies\Explorer\Run
HKLM\Software\Microsoft\Windows\CurrentVersion\policies\Explorer\Run
End of report, 33 812 bytes
Report generated in 0,110 seconds
Command line options:
/verbose - to add additional info on each section
/complete - to include empty sections and unsuspicious data
/full - to include several rarely-important sections
/force9x - to include Win9x-only startups even if running on WinNT
/forcent - to include WinNT-only startups even if running on Win9x
/forceall - to include all Win9x and WinNT startups, regardless of platform
/history - to list version history only
