gdy wchodze na tą strone pewną strone loguje się ale cały czas czekam i nic ten sam problem mam z innymi menagerami piłkarskimi błąd występuje w firefoxie,operze i IE jave mam ok virusów nie mam więc za bardzo nie wiem co może być przyczyną w konsoli błędów pojawia mi się to
function safeLogin(f)
loginFocus();
var lf = document.forms["login"];
var lf2 = document.forms["logindata"];
md5c = lf['md5c'].value;
username = lf2['username'].value;
password = lf2['password'].value.toLowerCase();
sport = lf2['sport'].value;
try {
lf['logindata[md5]'].value = hex_hmac_md5(md5c, password);
lf['logindata[username]'].value = username;
lf['logindata[md5c]'].value = md5c;
} catch(error) {
alert("There was a client problem when logging in: " + error.description + "\\nPlease report this to support@managerzone.com\\n");
return false;
params = "logindata_md5=" + lf['logindata[md5]'].value + "&logindata_username=" + lf['logindata[username]'].value + "&logindata_md5c=" + lf['logindata[md5c]'].value;
ajaxCallLightboxLoading("ajax_com/start.php", "val=Login&" + params, "loginResponse", "");
return false;
function sendActivationRequest()
var f = document.forms["activationemailform"];
if(f["email"].value!="")
lightboxHide();
ajaxCallLightboxLoading("ajax_com/start.php", "val=resendactivation&email" + f["email"].value, "loginResponse", "");
function setNewLoginKey(key)
document.forms["login"]['md5c'].value = key;
function loginSport(sport)
if(document.getElementById('markasdefault'))
if(document.getElementById('markasdefault').checked)
lf['logindata[markasdefault]'].value = "on";
lf['logindata[sport]'].value = sport;
lf.submit();
function loginResponse(readyState, response, responseParameter)
if (readyState == 4)
eval(response);
if(templates['regselectsport']!=undefined)
prepareRegistration(4, response, '');
return;
if (templates['login'] && templates['login'].length == 3)
if(templates['login'][0]!="L")
lightboxHide();
if(templates['login'][0]=="E")
handleErrorFrame(templates['login'][1]);
else if(templates['login'][0]=="F")
myfunc = eval(templates['login'][1]);
if(myfunc)
myfunc(templates['login'][2]);
else {
lightboxShow(590, [templates['login'][2], "closebutton"], templates['login'][1]);
lightboxSetPosY(130);
function handleErrorFrame(content)
layer_write('login_error_window', content);
layer_show('login_error_window');
// Połączono posty.
Może to nie jest wina scryptu ale nie wiem co sie stało ponowna instalacja przeglądarki nie pomogła
