Witam.
Mam pewien kod źródłowy pewnego programu i chciałbym go skompilować, próbowałem za pomocą dev++ lecz nie jestem w stanie bo niby są jakieś błędy w kodzie…
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:26:24: caml/alloc.h: No such file or directory
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:27:23: caml/fail.h: No such file or directory
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:28:25: caml/memory.h: No such file or directory
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:29:27: caml/bigarray.h: No such file or directory
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:34: error: syntax error before "value"
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:34: error: syntax error before "src_arr"
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c: In function `string_of_binary_array':
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:36: error: `src_arr' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:36: error: (Each undeclared identifier is reported only once
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:36: error: for each function it appears in.)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:36: error: `src_idx' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:36: error: `src_len' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:37: error: `retval' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:40: warning: passing arg 1 of `memmove' makes pointer from integer without a cast
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c: At top level:
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:46: error: syntax error before "value"
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:46: error: syntax error before "src_arr"
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c: In function `string_from_binary_array':
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:48: error: `src_arr' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:48: error: `buffer' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:48: error: `src_idx' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:48: error: `src_len' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:48: error: `dst_idx' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:49: warning: initialization makes pointer from integer without a cast
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:51: error: `Val_unit' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:57: error: syntax error before "value"
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:57: error: syntax error before "src_arr"
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c: In function `cstring_of_binary_array':
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:59: error: `src_arr' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:59: error: `src_idx' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:59: error: `src_len' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:60: error: `retval' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:71: error: syntax error before "value"
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:71: error: syntax error before "src_arr"
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c: In function `unsafe_cstring_of_binary_array':
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:73: error: `src_arr' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:73: error: `src_idx' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:78: error: syntax error before "value"
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:78: error: syntax error before "dst_arr"
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c: In function `string_to_binary_array':
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:80: error: `dst_arr' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:80: error: `dst_idx' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:80: error: `src_str' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:82: error: invalid type argument of `->'
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:83: warning: passing arg 2 of `memcpy' makes pointer from integer without a cast
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:84: error: `Val_unit' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:90: error: syntax error before "value"
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:90: error: syntax error before "dst_arr"
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c: In function `cstring_to_binary_array':
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:92: error: `dst_arr' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:92: error: `dst_idx' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:92: error: `dst_len' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:92: error: `src_str' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:94: error: invalid type argument of `->'
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:95: warning: passing arg 2 of `memcpy' makes pointer from integer without a cast
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:97: error: `Val_unit' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:104: error: syntax error before "uint32"
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:104: warning: no semicolon at end of struct or union
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:105: warning: data definition has no type or storage class
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:107: error: syntax error before '}' token
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:107: warning: data definition has no type or storage class
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:109: error: syntax error before "void"
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:109: error: syntax error before '*' token
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:110: error: syntax error before "void"
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:110: error: syntax error before '*' token
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:111: error: syntax error before "void"
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:111: error: syntax error before "MD5Context"
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:113: error: syntax error before "value"
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:113: error: syntax error before "v_iarr"
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c: In function `digest_array':
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:115: error: `v_iarr' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:116: error: `result' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:117: error: syntax error before "context"
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:118: error: invalid type argument of `->'
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:119: warning: initialization makes pointer from integer without a cast
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:121: error: `context' undeclared (first use in this function)
x:\Users\xXx\Desktop\rldev-1.40\src\common\binarray-c.c:130: error: invalid lvalue in unary `&'
Wykonanie zakończone
anyway, wiem, że teraz zabrzmi to głupio ale ja nie mam bladego pojęcia o programowaniu w tym języku ani jak należy kompilować taki program. Do tej pory używałem jedynie Autohotkey’a + vTaskStudio i tam sprawa była jasna bo wszystko zawsze było w jednym pliku, a tutaj jest dodatkowo z setka innych które nic mi nie mówią.
Wracając do tematu zadam pytanie proste: jakie takie coś się kompiluje - od razu mówię, w sieci jest już skompilowany ten program ale bez tego patcha bez którego nic nie zrobię.
Z góry przepraszam i dziękuję za wszelką wyrozumiałość i pomoc.
