Q3 1.11 win-x86 Nov 24 1999
----- FS_Startup -----
Current search path:
e:\gry\quake iii arena\baseq3\pak0.pk3 (3539 files)
e:\gry\quake iii arena/baseq3
execing default.cfg
execing q3config.cfg
couldn't exec autoexec.cfg
...detecting CPU, found Intel Pentium III
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
--- Common Initialization Complete ---
Winsock Initialized
Opening IP socket: localhost:27960
Hostname: ult1mepc
IP: 77.253.113.87
Working directory: e:\gry\quake iii arena
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 4: 800 600 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (800x600)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 0 )
...101 PFDs found
...hardware acceleration found
...PIXELFORMAT 7 selected
...creating GL context: succeeded
...making context current: succeeded
Initializing OpenGL extensions
...using GL_S3_s3tc
...using GL_EXT_texture_env_add
...using WGL_EXT_swap_control
...using GL_ARB_multitexture
...using GL_EXT_compiled_vertex_array
...WGL_3DFX_gamma_control not found
GL_VENDOR: NVIDIA Corporation
GL_RENDERER: GeForce FX 5200/AGP/SSE/3DNOW!
GL_VERSION: 2.1.2
GL_EXTENSIONS: GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_half_float_pixel GL_ARB_imaging GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shadow GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_texture_rectangle GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_gpu_program_parameters GL_EXT_multi_draw_a
GL_MAX_TEXTURE_SIZE: 4096
GL_MAX_ACTIVE_TEXTURES_ARB: 4
PIXELFORMAT: color(32-bits) Z(24-bit) stencil(0-bits)
MODE: 4, 800 x 600 fullscreen hz:60
GAMMA: hardware w/ 0 overbright bits
CPU: Intel Pentium III
rendering primitives: single glDrawElements
texturemode: GL_LINEAR_MIPMAP_NEAREST
picmip: 0
texture bits: 0
multitexture: enabled
compiled vertex arrays: enabled
texenv add: enabled
compressed textures: enabled
Initializing Shaders
...loading 'scripts/base.shader'
...loading 'scripts/base_button.shader'
...loading 'scripts/base_floor.shader'
...loading 'scripts/base_light.shader'
...loading 'scripts/base_object.shader'
...loading 'scripts/base_support.shader'
...loading 'scripts/base_trim.shader'
...loading 'scripts/base_wall.shader'
...loading 'scripts/common.shader'
...loading 'scripts/ctf.shader'
...loading 'scripts/eerie.shader'
...loading 'scripts/gfx.shader'
...loading 'scripts/gothic_block.shader'
...loading 'scripts/gothic_floor.shader'
...loading 'scripts/gothic_light.shader'
...loading 'scripts/gothic_trim.shader'
...loading 'scripts/gothic_wall.shader'
...loading 'scripts/hell.shader'
...loading 'scripts/liquid.shader'
...loading 'scripts/menu.shader'
...loading 'scripts/models.shader'
...loading 'scripts/organics.shader'
...loading 'scripts/sfx.shader'
...loading 'scripts/shrine.shader'
...loading 'scripts/skin.shader'
...loading 'scripts/sky.shader'
...loading 'scripts/test.shader'
----- finished R_Init -----
------- sound initialization -------
Initializing DirectSound
locked hardware. ok
----- Sound Info -----
sound system is muted
1 stereo
32768 samples
16 samplebits
1 submission_chunk
22050 speed
0x85e8060 dma buffer
Forcing all sounds to 8 bit
No background file.
Loading dll file ui.
Failed to load dll, looking for qvm.
Loading vm file vm/ui.qvm.
VM file ui compiled to 902626 bytes of code
30 arenas parsed
32 bots parsed
trFMV::play(), playing idlogo.RoQ
ERROR: Disconnected from server
RE_Shutdown( 0 )
----- R_Init -----
GL_VERSION: 2.1.2
picmip: 0
texture bits: 0
texenv add: enabled
30 arenas parsed
32 bots parsed
RE_Shutdown( 1 )
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
----- R_Init -----
...initializing QGL
...setting mode 5: 960 720 FS
...calling CDS: failed, bad mode
...trying next higher resolution: failed, DISP_CHANGE_FAILED
...restoring display settings
...created window@3,16 (966x752)
...101 PFDs found
...WARNING: fullscreen unavailable in this mode
...using colorsbits of 16
...window already present, CreateWindowEx skipped
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
Nie mogę ustawić rozdzielczości 960x720 oraz 1024x768, do których jest przeznaczony mój monitor.
Nie wiem co jest nie tak.
Grafa: nVidia GeForce Fx5200 Ultra 128MB
Proc: AMD Athlon XP 1800+
1GB RAM DDR1
Monitor Samsung SyncMaster 793DF.
