Witam. Posiadam Windows XP Home Edition oczywiście oryginalny i mam problem z Blue Screenami. Oto plik mindup
Microsoft ® Windows Debugger Version 6.8.0004.0 X86
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [C]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055a620
Debug session time: Sun Jun 1 19:37:29.578 2008 (GMT+2)
System Uptime: 0 days 0:08:18.150
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 100000D1, {ffffff22, 2, 0, f6c54926}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** WARNING: Unable to verify timestamp for hal.dll
*** ERROR: Module load completed but symbols could not be loaded for hal.dll
*** WARNING: Unable to verify timestamp for USBPORT.SYS
*** ERROR: Module load completed but symbols could not be loaded for USBPORT.SYS
Unable to load image torususb.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for torususb.sys
*** ERROR: Module load completed but symbols could not be loaded for torususb.sys
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
Probably caused by : torususb.sys ( torususb+937e4 )
Wydaje mi sie że jest to problem z zasilaczem. Komputer ma 5 lat i ani razu nie był wymieniany. Zasilacz ma 300W. Proszę o pomoc.
W dniu 01.06.2008 , o godzinie 21:21 został dopisany post przez bartekzmc
Naprawdę bardzo proszę o pomoc, bo nie wiem co mam robić :(
