Hej z niewiadomych przyczyn przy uruchamianiu wyskakuje mi coś takiego
Return to Castle Wolfenstein: problem z uruchomieniem
Wolf 1.0.0 win-x86 Nov 13 2001
----- FS_Startup -----
Current search path:
C:\Program Files\Programy\Gryt\Return to Castle Wolfenstein\main\sp_pak2.pk3 (232 files)
C:\Program Files\Programy\Gryt\Return to Castle Wolfenstein\main\sp_pak1.pk3 (1342 files)
C:\Program Files\Programy\Gryt\Return to Castle Wolfenstein\main\pak0.pk3 (4775 files)
C:\Program Files\Programy\Gryt\Return to Castle Wolfenstein/main
6349 files in pk3 files
execing default.cfg
couldn’t exec language.cfg
execing wolfconfig.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
…detecting CPU, found Intel Pentium III
Bypassing CD checks
----- Client Initialization -----
Cmd_AddCommand: map_restart already defined
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
…initializing QGL
…calling LoadLibrary( ‘C:\Windows\system32\opengl32.dll’ ): succeeded
…setting mode 9: 1600 1200 FS
…using desktop display depth of 32
…calling CDS: failed, DISP_CHANGE_FAILED
…trying next higher resolution: failed, DISP_CHANGE_FAILED
…restoring display settings
…registered window class
…created window@3,22 (1606x1225)
Initializing OpenGL driver
…getting DC: succeeded
…GLW_ChoosePFD( 32, 24, 0 )
…41 PFDs found
…hardware acceleration found
…PIXELFORMAT 6 selected
…creating GL context: succeeded
…making context current: succeeded
…WARNING: fullscreen unavailable in this mode
…using colorsbits of 16
…window already present, CreateWindowEx skipped
…shutting down QGL
…unloading OpenGL DLL
…assuming ‘3dfxvgl’ is a standalone driver
…initializing QGL
…WARNING: missing Glide installation, assuming no 3Dfx available
…shutting down QGL
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
