Kupiłem router Cerberus p 6331-6 jakieś półtora roku temu przez 6 miesięcy było wszystko dobrze. Potem zaczoł tracić połączenie z internetem i miał problemy z ponownym połączeniem, nie pomagały restarty.
A moje pytanie brzmi czy to problem na linij czy ze strony routera?
PS. Mam NET24 i dołączam logi
Jan 1 00:00:15 syslog: OS (18:45:44, Jun 1 2007)
Jan 1 00:00:15 syslog: 176.94 MIPS
Jan 1 00:00:15 syslog: ============================================================
Jan 1 00:00:15 syslog: TC3162 PCI interface initialize
Jan 1 00:00:15 syslog: Initializing RT netlink socket
Jan 1 00:00:15 syslog: wdt_init ..
Jan 1 00:00:15 syslog: TC3162 watchdog initialize at Interrupt 9
Jan 1 00:00:15 syslog: init ADSL status timer
Jan 1 00:00:15 syslog: Ethernet driver for TC3162L2 version 1.0mac: 00:04:ed:a1:ac:c8
Jan 1 00:00:15 syslog: on eth0 (IRQ: 21), (mac 00:04:ed:a1:ac:c8)
Jan 1 00:00:15 syslog: eth0: driver installation completed.
Jan 1 00:00:15 syslog: TSARM: TC3162 ATM SAR driver 2.0.D3 init
Jan 1 00:00:15 syslog: TSARM: TC3162 ATM SAR driver 2.0.D3 done
Jan 1 00:00:15 syslog: TC3162 hardware watchdog module loaded.
Jan 1 00:00:15 syslog: tc3162 flash: probing 16-bit flash bus
Jan 1 00:00:15 syslog: TC3162 nor-flash: Probing for AMD compatible flash...
Jan 1 00:00:15 syslog: TC3162 nor-flash: Found 1 x 4MiB MXIC MX29LV320AB at 0x0
Jan 1 00:00:15 syslog: create 6 flash partitions
Jan 1 00:00:15 syslog: ADSL DMT initialization starting
Jan 1 00:00:15 syslog: Begin AdslTaskInit.....
Jan 1 00:00:15 syslog: End AdslTaskInit
Jan 1 00:00:15 syslog: Begin to request IRQ 19
Jan 1 00:00:15 syslog: DMT:Succeed to request IRQ 19
Jan 1 00:00:15 syslog: Initializing ADSL F/W 3.5.18.0 ......
Jan 1 00:00:15 syslog: Initializing ADSL F/W ........ done ^M
Jan 1 00:00:15 syslog: IP: routing cache hash table of 512 buckets, 4Kbytes
Jan 1 00:00:15 syslog: TCP: Hash tables configured (established 1024 bind 2048)
Jan 1 00:00:15 syslog: IP multicast router 0.06 plus PIM-SM
Jan 1 00:00:15 syslog: the ip_max_connection=3584, the udp_max_connection=1792, and tcp_large_port_max_connection=896
Jan 1 00:00:15 syslog: **********************************************
Jan 1 00:00:15 syslog: RT61AP Wireless Driver version-1.0.8.0-3
Jan 1 00:00:19 syslog: eth0: starting interface.
Jan 1 00:00:21 syslog: SETSNOOP : 0
Jan 1 00:00:32 syslog: Linesync achieved
Jan 1 00:00:32 syslog: ADSL line is up
Jan 1 00:00:43 syslog: Disable VLAN
Jan 1 00:00:44 syslog: device eth0 entered promiscuous mode
Jan 1 00:00:44 syslog: br0: port 1(eth0) entering learning state
Jan 1 00:00:44 syslog: br0: port 1(eth0) entering forwarding state
Jan 1 00:00:44 syslog: br0: topology change detected, propagating
Jan 1 00:00:45 syslog: device ra0 entered promiscuous mode
Jan 1 00:00:45 syslog: br0: port 2(ra0) entering learning state
Jan 1 00:00:45 syslog: br0: port 2(ra0) entering forwarding state
Jan 1 00:00:45 syslog: br0: topology change detected, propagating
Jan 1 00:00:46 syslog: Set LAN MII
Jan 1 00:00:46 syslog: Switch soft-Reset
Jan 1 00:00:47 syslog: ANNEXA^M
Jan 1 00:00:47 syslog: Open Loop Detect Disable ^M
Jan 1 00:00:47 syslog: ave snrm cnt = 1^M
Jan 1 00:00:47 syslog: Linesync lost
Jan 1 00:00:47 syslog: ADSL line is down
Jan 1 00:00:47 syslog: EC OFF!!^M
Jan 1 00:00:51 syslog: the configure tcp_large_port_timeout=120
Jan 1 00:00:51 syslog: after tcp_large_port_timeout=120
Jan 1 00:00:52 syslog: the configure wlan_ignore_interrupt=1
Jan 1 00:00:52 syslog: after wlan_ignore_interrupt=1
Jan 1 00:00:53 ATM_BRIDGE: ATM Bridge Interface created sucessfully
Jan 1 00:00:53 ATM_BRIDGE: Communicating over ATM 8/35, encapsulation: LLC
Jan 1 00:00:59 syslog: atm init aal5
Jan 1 00:00:59 ATM_BRIDGE: Interface configured
Jan 1 00:00:59 ATM_BRIDGE: RFC 1483/2684 bridge started
Jan 1 00:01:01 syslog: device nas0 entered promiscuous mode
Jan 1 00:01:01 syslog: nas0: attempt to add interface with same source address.
Jan 1 00:01:01 syslog: br0: port 3(nas0) entering learning state
Jan 1 00:01:01 syslog: br0: port 3(nas0) entering forwarding state
Jan 1 00:01:01 syslog: br0: topology change detected, propagating
Jan 1 00:01:02 syslog: pppoe main==>start
Jan 1 00:01:02 PPPoE: PPPoE: Use br0 for PPPoE discovery
Jan 1 00:01:02 PPPoE: pppoe module started
Jan 1 00:01:02 PPPoE: PPP Start
Jan 1 00:01:03 syslog: LINK_PPPOE=1
Jan 1 00:01:03 syslog: pid=108
Jan 1 00:01:05 DNS RELAY: start.
Jan 1 00:01:17 syslog: Linesync achieved
Jan 1 00:01:17 syslog: ADSL line is up
Jan 1 00:01:17 syslog: Downstream rate: 4960 kbps
Jan 1 00:01:17 syslog: Upstream rate: 637 kbps
Jan 1 00:01:22 PPPoE: Using interface ppp0
Jan 1 00:01:22 PPPoE: Connection start.
Jan 1 00:01:23 PPPoE: add ci req netmask 1
Jan 1 00:01:23 PPPoE: add ci netmask 0.0.0.0
Jan 1 00:01:23 PPPoE: 1 ack req netmask 0
Jan 1 00:01:23 PPPoE: 1 ack netmask 0.0.0.0
Jan 1 00:01:23 PPPoE: ipcp_up:start
Jan 1 00:01:23 PPPoE: local IP address 213.238.110.175
Jan 1 00:01:23 PPPoE: remote IP address 195.114.190.55
Jan 1 00:01:23 PPPoE: primary DNS address 83.238.255.76
Jan 1 00:01:23 PPPoE: secondary DNS address 213.241.79.37
Jan 1 00:01:23 PPPoE: ipcp_up:always on
Jan 1 00:01:23 PPPoE: 1.bil_ipcpup:run final route script /tmp/ppp/route.sh
Jan 1 00:01:23 PPPoE: WanIP 213.238.110.175 WanNetmask 255.255.255.255 Gateway 195.114.190.55
Jan 1 00:01:23 PPPoE: Dns1 83.238.255.76 Dns2 213.241.79.37
Jan 1 00:01:23 PPPoE: Cisco Netmask 0.0.0.0
Jan 1 00:01:23 PPPoE: 2. bil_ipcpup:run final route script /tmp/ppp/route.sh
Jan 1 00:01:25 DDNS: DDNS is started
Jan 1 00:01:25 DDNS: our host is przybylas.dyndns.info and DDNS server is members.dyndns.org
Jan 1 00:01:25 DDNS: got last update 81.219.5.218 on 2009/11/27 15:58 from cache file
Jan 1 00:01:25 DDNS: DynDNS can not be reliable if SNTP -time server do not reply to modem correctly, Please fix SNTP -server address.
Jan 1 00:01:25 syslog: get mac 00 04 ED A1 AC C8
Nov 28 10:25:18 syslog: NTP current time is Sat Nov 28 10:25:18 2009
Nov 28 10:25:19 DDNS: successful update for ppp0->213.238.110.175 (przybylas.dyndns.info)
Nov 28 10:25:21 PPPoE: bil_ipcpup:end
Nov 28 10:27:05 DHCP SERVER: DHCPDISCOVER from 00:1f:1f:1a:cb:4e via br0
Nov 28 10:27:05 DHCP SERVER: DHCP offer to 00:1f:1f:1a:cb:4e
Nov 28 10:27:05 DHCP SERVER: DHCP request from 00:1f:1f:1a:cb:4e
Nov 28 10:27:05 DHCP SERVER: DHCP ack to 00:1f:1f:1a:cb:4e
Nov 28 10:27:06 DNS RELAY: using nameserver 213.241.79.37#53
Nov 28 10:27:06 DNS RELAY: using nameserver 83.238.255.76#53
Nov 28 10:27:08 DHCP SERVER: DHCP request from 00:1f:1f:1a:cb:4e
Nov 28 10:27:08 DHCP SERVER: DHCP ack to 00:1f:1f:1a:cb:4e
Nov 28 10:28:02 DHCP SERVER: DHCPINFORM from 192.168.1.110
Nov 28 10:28:05 DHCP SERVER: DHCPINFORM from 192.168.1.110
Nov 28 10:43:40 PPPoE: Hangup (SIGHUP)
Nov 28 10:43:40 PPPoE: ipcp_down:start
Nov 28 10:43:40 PPPoE: ipcp_down:always
Nov 28 10:43:40 PPPoE: ipcp_down:script
Nov 28 10:43:40 syslog: Linesync lost
Nov 28 10:43:40 syslog: ADSL line is down
Nov 28 10:43:42 PPPoE: entering restore_dhcpd_and_lan
Nov 28 10:43:42 PPPoE: ipcp_down:end
Nov 28 10:43:48 PPPoE: Connection terminated.
Nov 28 10:43:48 PPPoE: Connect time 18.5 minutes.
Nov 28 10:43:48 PPPoE: Sent 1069350 bytes, received 41736533 bytes.
Nov 28 10:43:48 PPPoE: Doing disconnect
Nov 28 10:43:59 syslog: Linesync achieved
Nov 28 10:43:59 syslog: ADSL line is up
Nov 28 10:43:59 syslog: Downstream rate: 4960 kbps
Nov 28 10:43:59 syslog: Upstream rate: 637 kbps
Nov 28 10:44:18 PPPoE: Using interface ppp0
Nov 28 10:44:18 PPPoE: Connection start.
Nov 28 10:44:19 PPPoE: add ci req netmask 1
Nov 28 10:44:19 PPPoE: add ci netmask 0.0.0.0
Nov 28 10:44:19 PPPoE: 1 ack req netmask 0
Nov 28 10:44:19 PPPoE: 1 ack netmask 0.0.0.0
Nov 28 10:44:19 PPPoE: ipcp_up:start
Nov 28 10:44:19 PPPoE: local IP address 77.253.67.5
Nov 28 10:44:19 PPPoE: remote IP address 195.114.190.55
Nov 28 10:44:19 PPPoE: primary DNS address 83.238.255.76
Nov 28 10:44:19 PPPoE: secondary DNS address 213.241.79.37
Nov 28 10:44:19 PPPoE: ipcp_up:always on
Nov 28 10:44:19 PPPoE: 1.bil_ipcpup:run final route script /tmp/ppp/route.sh
Nov 28 10:44:19 PPPoE: WanIP 77.253.67.5 WanNetmask 255.255.255.255 Gateway 195.114.190.55
Nov 28 10:44:19 PPPoE: Dns1 83.238.255.76 Dns2 213.241.79.37
Nov 28 10:44:19 PPPoE: Cisco Netmask 0.0.0.0
Nov 28 10:44:19 PPPoE: 2. bil_ipcpup:run final route script /tmp/ppp/route.sh
Nov 28 10:44:21 DDNS: DDNS is started
Nov 28 10:44:21 DDNS: our host is przybylas.dyndns.info and DDNS server is members.dyndns.org
Nov 28 10:44:21 DDNS: got last update 213.238.110.175 on 2009/11/28 10:25 from cache file
Nov 28 10:44:19 syslog: NTP current time is Sat Nov 28 10:44:19 2009
Nov 28 10:44:20 DDNS: successful update for ppp0->77.253.67.5 (przybylas.dyndns.info)
Nov 28 10:44:21 DNS RELAY: using nameserver 213.241.79.37#53
Nov 28 10:44:21 DNS RELAY: using nameserver 83.238.255.76#53
Nov 28 10:44:22 PPPoE: bil_ipcpup:end
Nov 28 10:44:28 syslog: TC3162 nor-flash: waiting for chip to read, state = 4
Nov 28 10:44:48 PPPoE: Hangup (SIGHUP)
Nov 28 10:44:48 PPPoE: ipcp_down:start
Nov 28 10:44:48 PPPoE: ipcp_down:always
Nov 28 10:44:48 PPPoE: ipcp_down:script
Nov 28 10:44:48 syslog: Linesync lost
Nov 28 10:44:48 syslog: ADSL line is down
Nov 28 10:44:50 PPPoE: entering restore_dhcpd_and_lan
Nov 28 10:44:50 PPPoE: ipcp_down:end
Nov 28 10:44:56 PPPoE: Connection terminated.
Nov 28 10:44:56 PPPoE: Connect time 0.6 minutes.
Nov 28 10:44:56 PPPoE: Sent 13615 bytes, received 44081 bytes.
Nov 28 10:44:56 PPPoE: Doing disconnect
Nov 28 10:45:06 syslog: Linesync achieved
Nov 28 10:45:06 syslog: ADSL line is up
Nov 28 10:45:06 syslog: Downstream rate: 4960 kbps
Nov 28 10:45:06 syslog: Upstream rate: 637 kbps
Nov 28 10:45:26 PPPoE: Using interface ppp0
Nov 28 10:45:26 PPPoE: Connection start.
Nov 28 10:45:27 PPPoE: add ci req netmask 1
Nov 28 10:45:27 PPPoE: add ci netmask 0.0.0.0
Nov 28 10:45:27 PPPoE: 1 ack req netmask 0
Nov 28 10:45:27 PPPoE: 1 ack netmask 0.0.0.0
Nov 28 10:45:27 PPPoE: ipcp_up:start
Nov 28 10:45:27 PPPoE: local IP address 213.238.108.131
Nov 28 10:45:27 PPPoE: remote IP address 195.114.190.55
Nov 28 10:45:27 PPPoE: primary DNS address 83.238.255.76
Nov 28 10:45:27 PPPoE: secondary DNS address 213.241.79.37
Nov 28 10:45:27 PPPoE: ipcp_up:always on
Nov 28 10:45:27 PPPoE: 1.bil_ipcpup:run final route script /tmp/ppp/route.sh
Nov 28 10:45:27 PPPoE: WanIP 213.238.108.131 WanNetmask 255.255.255.255 Gateway 195.114.190.55
Nov 28 10:45:27 PPPoE: Dns1 83.238.255.76 Dns2 213.241.79.37
Nov 28 10:45:27 PPPoE: Cisco Netmask 0.0.0.0
Nov 28 10:45:27 PPPoE: 2. bil_ipcpup:run final route script /tmp/ppp/route.sh
Nov 28 10:45:29 DDNS: DDNS is started
Nov 28 10:45:29 DDNS: our host is przybylas.dyndns.info and DDNS server is members.dyndns.org
Nov 28 10:45:30 DDNS: got last update 77.253.67.5 on 2009/11/28 10:44 from cache file
Nov 28 10:45:30 syslog: NTP current time is Sat Nov 28 10:45:30 2009
Nov 28 10:45:30 DDNS: successful update for ppp0->213.238.108.131 (przybylas.dyndns.info)
Nov 28 10:45:31 DNS RELAY: using nameserver 213.241.79.37#53
Nov 28 10:45:31 DNS RELAY: using nameserver 83.238.255.76#53
Nov 28 10:45:32 PPPoE: bil_ipcpup:end
Nov 28 10:45:38 syslog: TC3162 nor-flash: waiting for chip to read, state = 4
Nov 28 10:45:49 PPPoE: Hangup (SIGHUP)
Nov 28 10:45:49 PPPoE: ipcp_down:start
Nov 28 10:45:49 PPPoE: ipcp_down:always
Nov 28 10:45:49 PPPoE: ipcp_down:script
Nov 28 10:45:49 syslog: Linesync lost
Nov 28 10:45:49 syslog: ADSL line is down
Nov 28 10:45:51 PPPoE: entering restore_dhcpd_and_lan
Nov 28 10:45:51 PPPoE: ipcp_down:end
Nov 28 10:45:57 PPPoE: Connection terminated.
Nov 28 10:45:57 PPPoE: Connect time 0.4 minutes.
Nov 28 10:45:57 PPPoE: Sent 34078 bytes, received 45076 bytes.
Nov 28 10:45:57 PPPoE: Doing disconnect
Nov 28 10:46:07 syslog: Linesync achieved
Nov 28 10:46:07 syslog: ADSL line is up
Nov 28 10:46:07 syslog: Downstream rate: 4960 kbps
Nov 28 10:46:07 syslog: Upstream rate: 637 kbps
Nov 28 10:46:27 PPPoE: Using interface ppp0
Nov 28 10:46:27 PPPoE: Connection start.
Nov 28 10:46:28 PPPoE: add ci req netmask 1
Nov 28 10:46:28 PPPoE: add ci netmask 0.0.0.0
Nov 28 10:46:28 PPPoE: 1 ack req netmask 0
Nov 28 10:46:28 PPPoE: 1 ack netmask 0.0.0.0
Nov 28 10:46:28 PPPoE: ipcp_up:start
Nov 28 10:46:28 PPPoE: local IP address 213.238.122.126
Nov 28 10:46:28 PPPoE: remote IP address 195.114.190.55
Nov 28 10:46:28 PPPoE: primary DNS address 83.238.255.76
Nov 28 10:46:28 PPPoE: secondary DNS address 213.241.79.37
Nov 28 10:46:28 PPPoE: ipcp_up:always on
Nov 28 10:46:28 PPPoE: 1.bil_ipcpup:run final route script /tmp/ppp/route.sh
Nov 28 10:46:28 PPPoE: WanIP 213.238.122.126 WanNetmask 255.255.255.255 Gateway 195.114.190.55
Nov 28 10:46:28 PPPoE: Dns1 83.238.255.76 Dns2 213.241.79.37
Nov 28 10:46:28 PPPoE: Cisco Netmask 0.0.0.0
Nov 28 10:46:28 PPPoE: 2. bil_ipcpup:run final route script /tmp/ppp/route.sh
Nov 28 10:46:28 DNS RELAY: using nameserver 213.241.79.37#53
Nov 28 10:46:28 DNS RELAY: using nameserver 83.238.255.76#53
Nov 28 10:46:30 DDNS: DDNS is started
Nov 28 10:46:30 DDNS: our host is przybylas.dyndns.info and DDNS server is members.dyndns.org
Nov 28 10:46:30 DDNS: got last update 213.238.108.131 on 2009/11/28 10:45 from cache file
Nov 28 10:46:30 syslog: NTP current time is Sat Nov 28 10:46:30 2009
Nov 28 10:46:31 DDNS: successful update for ppp0->213.238.122.126 (przybylas.dyndns.info)
Nov 28 10:46:39 syslog: TC3162 nor-flash: waiting for chip to read, state = 4
Nov 28 10:46:40 PPPoE: bil_ipcpup:end
Nov 28 10:46:52 PPPoE: Hangup (SIGHUP)
Nov 28 10:46:52 PPPoE: ipcp_down:start
Nov 28 10:46:52 PPPoE: ipcp_down:always
Nov 28 10:46:52 PPPoE: ipcp_down:script
Nov 28 10:46:52 syslog: Linesync lost
Nov 28 10:46:52 syslog: ADSL line is down
Nov 28 10:46:54 PPPoE: entering restore_dhcpd_and_lan
Nov 28 10:46:54 PPPoE: ipcp_down:end
Nov 28 10:47:00 PPPoE: Connection terminated.
Nov 28 10:47:00 PPPoE: Connect time 0.5 minutes.
Nov 28 10:47:00 PPPoE: Sent 30655 bytes, received 50974 bytes.
Nov 28 10:47:00 PPPoE: Doing disconnect
Nov 28 10:47:10 syslog: Linesync achieved
Nov 28 10:47:10 syslog: ADSL line is up
Nov 28 10:47:10 syslog: Downstream rate: 4960 kbps
Nov 28 10:47:10 syslog: Upstream rate: 637 kbps
Nov 28 10:47:30 PPPoE: Using interface ppp0
Nov 28 10:47:30 PPPoE: Connection start.
Nov 28 10:47:30 PPPoE: add ci req netmask 1
Nov 28 10:47:30 PPPoE: add ci netmask 0.0.0.0
Nov 28 10:47:31 PPPoE: 1 ack req netmask 0
Nov 28 10:47:31 PPPoE: 1 ack netmask 0.0.0.0
Nov 28 10:47:31 PPPoE: ipcp_up:start
Nov 28 10:47:31 PPPoE: local IP address 77.253.68.49
Nov 28 10:47:31 PPPoE: remote IP address 195.114.190.55
Nov 28 10:47:31 PPPoE: primary DNS address 83.238.255.76
Nov 28 10:47:31 PPPoE: secondary DNS address 213.241.79.37
Nov 28 10:47:31 PPPoE: ipcp_up:always on
Nov 28 10:47:31 PPPoE: 1.bil_ipcpup:run final route script /tmp/ppp/route.sh
Nov 28 10:47:31 PPPoE: WanIP 77.253.68.49 WanNetmask 255.255.255.255 Gateway 195.114.190.55
Nov 28 10:47:31 PPPoE: Dns1 83.238.255.76 Dns2 213.241.79.37
Nov 28 10:47:31 PPPoE: Cisco Netmask 0.0.0.0
Nov 28 10:47:31 PPPoE: 2. bil_ipcpup:run final route script /tmp/ppp/route.sh
Nov 28 10:47:33 DDNS: DDNS is started
Nov 28 10:47:33 DDNS: our host is przybylas.dyndns.info and DDNS server is members.dyndns.org
Nov 28 10:47:33 DDNS: got last update 213.238.122.126 on 2009/11/28 10:46 from cache file
Nov 28 10:47:33 syslog: NTP current time is Sat Nov 28 10:47:33 2009
Nov 28 10:47:33 DDNS: successful update for ppp0->77.253.68.49 (przybylas.dyndns.info)
Nov 28 10:47:35 DNS RELAY: using nameserver 213.241.79.37#53
Nov 28 10:47:35 DNS RELAY: using nameserver 83.238.255.76#53
Nov 28 10:47:35 PPPoE: bil_ipcpup:end
Nov 28 10:48:06 PPPoE: Hangup (SIGHUP)
Nov 28 10:48:06 PPPoE: ipcp_down:start
Nov 28 10:48:06 PPPoE: ipcp_down:always
Nov 28 10:48:06 PPPoE: ipcp_down:script
Nov 28 10:48:06 syslog: Linesync lost
Nov 28 10:48:06 syslog: ADSL line is down
Nov 28 10:48:08 PPPoE: entering restore_dhcpd_and_lan
Nov 28 10:48:08 PPPoE: ipcp_down:end
Nov 28 10:48:14 PPPoE: Connection terminated.
Nov 28 10:48:14 PPPoE: Connect time 0.6 minutes.
Nov 28 10:48:14 PPPoE: Sent 25514 bytes, received 26765 bytes.
Nov 28 10:48:14 PPPoE: Doing disconnect
Nov 28 10:48:25 syslog: Linesync achieved
Nov 28 10:48:25 syslog: ADSL line is up
Nov 28 10:48:25 syslog: Downstream rate: 4960 kbps
Nov 28 10:48:25 syslog: Upstream rate: 637 kbps
Nov 28 10:48:52 PPPoE: Hangup (SIGHUP)
Nov 28 10:48:52 syslog: Linesync lost
Nov 28 10:48:52 syslog: ADSL line is down
Nov 28 10:49:27 syslog: Linesync achieved
Nov 28 10:49:27 syslog: ADSL line is up
Nov 28 10:49:27 syslog: Downstream rate: 4960 kbps
Nov 28 10:49:27 syslog: Upstream rate: 637 kbps
Nov 28 11:47:52 PPPoE: Terminating on signal 15.
Nov 28 11:47:52 PPPoE: Connection failed
Nov 28 11:47:52 PPPoE: Doing disconnect
Nov 28 11:47:52 PPPoE: pppoe-main:fail and die 5
Nov 28 11:47:52 PPPoE: Exit.
Nov 28 11:47:57 syslog: br0: port 3(nas0) entering disabled state
Nov 28 11:47:57 syslog: device nas0 left promiscuous mode
Nov 28 11:47:59 syslog: device nas0 entered promiscuous mode
Nov 28 11:47:59 syslog: nas0: attempt to add interface with same source address.
Nov 28 11:47:59 syslog: br0: port 3(nas0) entering learning state
Nov 28 11:47:59 syslog: br0: port 3(nas0) entering forwarding state
Nov 28 11:47:59 syslog: br0: topology change detected, propagating
Nov 28 11:48:00 syslog: pppoe main==>start
Nov 28 11:48:00 PPPoE: PPPoE: Use br0 for PPPoE discovery
Nov 28 11:48:00 PPPoE: pppoe module started
Nov 28 11:48:00 PPPoE: PPP Start
Nov 28 11:48:00 PPPoE: Using interface ppp0
Nov 28 11:48:00 PPPoE: Connection start.
Nov 28 11:48:01 PPPoE: add ci req netmask 1
Nov 28 11:48:01 PPPoE: add ci netmask 0.0.0.0
Nov 28 11:48:01 PPPoE: 1 ack req netmask 0
Nov 28 11:48:01 PPPoE: 1 ack netmask 0.0.0.0
Nov 28 11:48:01 PPPoE: ipcp_up:start
Nov 28 11:48:01 PPPoE: local IP address 213.238.122.108
Nov 28 11:48:01 PPPoE: remote IP address 195.114.190.55
Nov 28 11:48:01 PPPoE: primary DNS address 83.238.255.76
Nov 28 11:48:01 PPPoE: secondary DNS address 213.241.79.37
Nov 28 11:48:01 PPPoE: ipcp_up:always on
Nov 28 11:48:01 PPPoE: 1.bil_ipcpup:run final route script /tmp/ppp/route.sh
Nov 28 11:48:01 PPPoE: WanIP 213.238.122.108 WanNetmask 255.255.255.255 Gateway 195.114.190.55
Nov 28 11:48:01 PPPoE: Dns1 83.238.255.76 Dns2 213.241.79.37
Nov 28 11:48:01 PPPoE: Cisco Netmask 0.0.0.0
Nov 28 11:48:01 PPPoE: 2. bil_ipcpup:run final route script /tmp/ppp/route.sh
Nov 28 11:48:03 DDNS: DDNS is started
Nov 28 11:48:03 DDNS: our host is przybylas.dyndns.info and DDNS server is members.dyndns.org
Nov 28 11:48:03 DDNS: got last update 77.253.68.49 on 2009/11/28 10:47 from cache file
Nov 28 11:48:04 DNS RELAY: using nameserver 213.241.79.37#53
Nov 28 11:48:04 DNS RELAY: using nameserver 83.238.255.76#53
Nov 28 11:48:04 DDNS: successful update for ppp0->213.238.122.108 (przybylas.dyndns.info)
Nov 28 11:48:13 syslog: TC3162 nor-flash: waiting for chip to read, state = 4
Nov 28 11:48:14 PPPoE: bil_ipcpup:end
Nov 28 11:48:28 syslog: NTP current time is Sat Nov 28 11:48:28 2009
Nov 28 11:52:36 DHCP SERVER: DHCPINFORM from 192.168.1.110
Nov 28 11:52:39 DHCP SERVER: DHCPINFORM from 192.168.1.110
Nov 28 12:12:56 DHCP SERVER: DHCPDISCOVER from 00:1f:3c:7f:8b:67 via br0
Nov 28 12:12:57 DHCP SERVER: DHCP offer to 00:1f:3c:7f:8b:67
Nov 28 12:12:57 DHCP SERVER: DHCP request from 00:1f:3c:7f:8b:67
Nov 28 12:12:57 DHCP SERVER: DHCP ack to 00:1f:3c:7f:8b:67
