Test Selected: Full Diagnostic Test
Running Full Diagnostic Test…
Testing drive ST950042 0AS…
Test Results:
Model: ST950042 0AS
Capacity: 465.76 GB
Full Diagnostic Test: Passed.
Recommendations:
Full Diagnostic Test for drive ST950042 0AS passed, no physical drive problems have been found. Run the PartitionTests tool, from the Disk Diagnostics category, on any partitions with data loss, to verify on-disk structures. If you ARE experiencing a data loss situation, you should run the applicable tools in the Data Recovery category to recover lost data. Also, professional services are available by contacting Technical Support or Ontrack Data Recovery Services.
Test Selected: Partition Test
Checking volume E: for errors…
File system check complete.
Test Results:
Partition test for volume E: Failed!
Recommendations:
Partition test for drive E failed, critical system structure errors have been found. Run the Full Diagnostic Test, from the DriveTests tool, on the drive containing the partition to verify if your drive has any physical problems. If you ARE experiencing a data loss situation, you should run the applicable tools in the Data Recovery category to recover lost data. Also, professional services are available by contacting Technical Support or Ontrack Data Recovery Services. If you ARE NOT experiencing a data loss situation, use the Windows Check Disk tool or other file system repair utility to fix the file structure errors. In the case of severely corrupted partitions, you may need to reformat you drive and restore data from a previous backup. NOTE: Reformatting your drive will destroy all data on your drive.
Test Selected: SMART Status Check
Test Results:
Intel® 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B34 : Samsung S2 Portable USB Device
Model: Samsung S2 Portable USB Device
Serial Number: j339
Capacity: 596.17 GB
Status: No SMART thresholds exceeded.
Recommendations:
SMART Status Check for drive Samsung S2 Portable USB Device passed, no physical drive problems have been found. Run the PartitionTests tool, from the Disk Diagnostics category, on any partitions with data loss, to verify on-disk structures. If you ARE experiencing a data loss situation, you should run the applicable tools in the Data Recovery category to recover lost data. Also, professional services are available by contacting Technical Support or Ontrack Data Recovery Services.
I co dalej?
– Dodane 11.11.2012 (N) 22:57 –
Ok leci.
Zobaczymy ile da się uratować??
– Dodane 14.11.2012 (Śr) 16:31 –
Super!
Udało się większość plików odzyskać
Część uległa zniszczeniu ale to już mnie ważne.
Teraz mam tylko jeszcze jedno pytanie.
Czy teraz mogę dysk sformatować i używać normalnie czy po jakimś czasie znów mi się takie coś może wydarzyć?
Chodzi mi dokładnie o to czy jest duże prawdopodobieństwo tego, że to się znów powtórzy?
