Witam,wlaśnie zakupiłem skaner Agfa Arcus 1200.
Jest to model sprzed kilku lat.
Podłączylem kablem który był w zestawie czyli 25 pin do kompa i 50 pin plus jakaś aktywna przejscówka do skanera.
Wgrałem oprogramowanie i nic.
Wiem ze potrzeba do tego dokupioc jakis inny kabel lub przejsciówke ale nie wiem jaką.
Przy próbie uruchomienia wyskakuje taki komunikat:
Make sure you installed the necessary drivers for your SCSI board.
Check all cables and connections and make sure the power switch is
turned on. Also verify that a unique SCSI ID is assigned to each device
and that the SCSI chain is terminated at the first and last device on the scsi cable.
STI driver installation
Driver successfully installed
Could not find an Agfa scanner on host adapter 0 (STI)
NT SCSI driver installation
Could not find an Agfa scanner on host adapter 0 (atapi)
Could not find an Agfa scanner on host adapter 1 (atapi)
Could not find an Agfa scanner on host adapter 2 (si3112r)
32 bit ASPI driver installation
Could not find an Agfa scanner on host adapter 0 (SI3112R)
SCSI ID 00 - DISK
Could not find an Agfa scanner on host adapter 1 (SI3112R)
WNASPI32.DLL initialization failed.
EPP2 driver installation
SCNDRVxx.DLL initialization failed.
RPC driver installation
Not supported
