Mam telefon Sony Ericsson k700i i kabel USB DCU-11.
Jakim programem mogę połączyć telefon z komputerem ??
Jaki sterownik jest mi potrzebny ??
System: Ubuntu 7.10
System: Ubuntu 7.10
podłącz kabel do kompa i tel do kabla i pokaż wyniki poleceń:
dmesg
i
lsusb
dmesg
marcin@marcin-desktop:~$ dmesg
[0.000000] Linux version 2.6.22-14-generic (buildd@palmer) (gcc version 4.1.3 20070929 (prerelease) (Ubuntu 4.1.2-16ubuntu2)) #1 SMP Sun Oct 14 23:05:12 GMT 2007 (Ubuntu 2.6.22-14.46-generic)
[0.000000] BIOS-provided physical RAM map:
[0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[0.000000] BIOS-e820: 00000000000e6000 - 0000000000100000 (reserved)
[0.000000] BIOS-e820: 0000000000100000 - 000000000ffb0000 (usable)
[0.000000] BIOS-e820: 000000000ffb0000 - 000000000ffc0000 (ACPI data)
[0.000000] BIOS-e820: 000000000ffc0000 - 000000000fff0000 (ACPI NVS)
[0.000000] BIOS-e820: 000000000fff0000 - 0000000010000000 (reserved)
[0.000000] BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved)
[0.000000] 0MB HIGHMEM available.
[0.000000] 255MB LOWMEM available.
[0.000000] Entering add_active_range(0, 0, 65456) 0 entries of 256 used
[0.000000] Zone PFN ranges:
[0.000000] DMA 0 -> 4096
[0.000000] Normal 4096 -> 65456
[0.000000] HighMem 65456 -> 65456
[0.000000] early_node_map[1] active PFN ranges
[0.000000] 0: 0 -> 65456
[0.000000] On node 0 totalpages: 65456
[0.000000] DMA zone: 32 pages used for memmap
[0.000000] DMA zone: 0 pages reserved
[0.000000] DMA zone: 4064 pages, LIFO batch:0
[0.000000] Normal zone: 479 pages used for memmap
[0.000000] Normal zone: 60881 pages, LIFO batch:15
[0.000000] HighMem zone: 0 pages used for memmap
[0.000000] DMI 2.3 present.
[0.000000] ACPI: RSDP signature @ 0xC00F8C40 checksum 0
[0.000000] ACPI: RSDP 000F8C40, 0014 (r0 ACPIAM)
[0.000000] ACPI: RSDT 0FFB0000, 0030 (r1 A M I OEMRSDT 8000426 MSFT 97)
[0.000000] ACPI: FACP 0FFB0200, 0081 (r2 A M I OEMFACP 8000426 MSFT 97)
[0.000000] ACPI: DSDT 0FFB0350, 345D (r1 K7UPG K7UPG001 1 INTL 2002026)
[0.000000] ACPI: FACS 0FFC0000, 0040
[0.000000] ACPI: APIC 0FFB0300, 004A (r1 A M I OEMAPIC 8000426 MSFT 97)
[0.000000] ACPI: OEMB 0FFC0040, 003F (r1 A M I OEMBIOS 8000426 MSFT 97)
[0.000000] ACPI: PM-Timer IO Port: 0x808
[0.000000] ACPI: Local APIC address 0xfee00000
[0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[0.000000] Processor #0 6:10 APIC version 16
[0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[0.000000] IOAPIC[0]: apic_id 1, version 3, address 0xfec00000, GSI 0-23
[0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[0.000000] ACPI: IRQ0 used by override.
[0.000000] ACPI: IRQ2 used by override.
[0.000000] ACPI: IRQ9 used by override.
[0.000000] Enabling APIC mode: Flat. Using 1 I/O APICs
[0.000000] Using ACPI (MADT) for SMP configuration information
[0.000000] Allocating PCI resources starting at 20000000 (gap: 10000000:eff80000)
[0.000000] Built 1 zonelists. Total pages: 64945
[0.000000] Kernel command line: root=UUID=23319522-6738-486c-ace3-1efa3ccb90f5 ro quiet splash locale=pl_PL
[0.000000] mapped APIC to ffffd000 (fee00000)
[0.000000] mapped IOAPIC to ffffc000 (fec00000)
[0.000000] Enabling fast FPU save and restore... done.
[0.000000] Enabling unmasked SIMD FPU exception support... done.
[0.000000] Initializing CPU#0
[0.000000] PID hash table entries: 1024 (order: 10, 4096 bytes)
[0.000000] Detected 1600.106 MHz processor.
[12.856915] Console: colour VGA+ 80x25
[12.857136] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[12.857288] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[12.865983] Memory: 247820k/261824k available (2015k kernel code, 13468k reserved, 916k data, 364k init, 0k highmem)
[12.865996] virtual kernel memory layout:
[12.865997] fixmap : 0xfff4d000 - 0xfffff000 ( 712 kB)
[12.865999] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[12.866001] vmalloc : 0xd0800000 - 0xff7fe000 ( 751 MB)
[12.866002] lowmem : 0xc0000000 - 0xcffb0000 ( 255 MB)
[12.866004] .init : 0xc03e3000 - 0xc043e000 ( 364 kB)
[12.866006] .data : 0xc02f7d26 - 0xc03dce84 ( 916 kB)
[12.866007] .text : 0xc0100000 - 0xc02f7d26 (2015 kB)
[12.866011] Checking if this processor honours the WP bit even in supervisor mode... Ok.
[12.866068] SLUB: Genslabs=22, HWalign=32, Order=0-1, MinObjects=4, CPUs=1, Nodes=1
[12.945981] Calibrating delay using timer specific routine.. 3204.10 BogoMIPS (lpj=6408215)
[12.946021] Security Framework v1.0.0 initialized
[12.946030] SELinux: Disabled at boot.
[12.946051] Mount-cache hash table entries: 512
[12.946231] CPU: After generic identify, caps: 0383fbff c1cbfbff 00000000 00000000 00000000 00000000 00000000
[12.946244] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
[12.946247] CPU: L2 Cache: 256K (64 bytes/line)
[12.946251] CPU: After all inits, caps: 0383fbff c1cbfbff 00000000 00000420 00000000 00000000 00000000
[12.946265] Compat vDSO mapped to ffffe000.
[12.946280] Checking 'hlt' instruction... OK.
[12.962135] SMP alternatives: switching to UP code
[12.962490] Freeing SMP alternatives: 11k freed
[12.962976] Early unpacking initramfs... done
[13.368113] ACPI: Core revision 20070126
[13.368237] ACPI: Looking for DSDT in initramfs... error, file /DSDT.aml not found.
[13.370489] CPU0: AMD Athlon(tm) MP 1900+ stepping 00
[13.370520] Total of 1 processors activated (3204.10 BogoMIPS).
[13.371308] ENABLING IO-APIC IRQs
[13.371651] ..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
[13.517227] Brought up 1 CPUs
[13.517459] Booting paravirtualized kernel on bare hardware
[13.517571] Time: 21:48:27 Date: 09/26/107
[13.517614] NET: Registered protocol family 16
[13.517762] EISA bus registered
[13.517782] ACPI: bus type pci registered
[13.517951] PCI: PCI BIOS revision 2.10 entry at 0xf0031, last bus=1
[13.517955] PCI: Using configuration type 1
[13.517957] Setting up standard PCI resources
[13.528108] ACPI: EC: Look up EC in DSDT
[13.532090] ACPI: Interpreter enabled
[13.532094] ACPI: (supports S0 S1 S3 S4 S5)
[13.532115] ACPI: Using IOAPIC for interrupt routing
[13.540638] ACPI: PCI Root Bridge [PCI0] (0000:00)
[13.540651] PCI: Probing PCI hardware (bus 00)
[13.541685] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[13.549172] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[13.549294] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[13.549405] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[13.549515] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[13.549624] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[13.549735] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[13.549844] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[13.549953] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[13.550055] Linux Plug and Play Support v0.97 (c) Adam Belay
[13.550073] pnp: PnP ACPI init
[13.550096] ACPI: bus type pnp registered
[13.554483] pnp: PnP ACPI: found 14 devices
[13.554487] ACPI: ACPI bus type pnp unregistered
[13.554493] PnPBIOS: Disabled by ACPI PNP
[13.554577] PCI: Using ACPI for IRQ routing
[13.554582] PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
[13.558582] NET: Registered protocol family 8
[13.558585] NET: Registered protocol family 20
[13.558702] pnp: 00:09: iomem range 0xfec80000-0xfec800ff has been reserved
[13.558706] pnp: 00:09: iomem range 0xfec00000-0xfec00fff has been reserved
[13.558710] pnp: 00:09: iomem range 0xfee00000-0xfee00fff has been reserved
[13.558714] pnp: 00:09: iomem range 0xfff80000-0xffffffff could not be reserved
[13.558724] pnp: 00:0d: iomem range 0x0-0x9ffff could not be reserved
[13.558728] pnp: 00:0d: iomem range 0xc0000-0xdffff could not be reserved
[13.558731] pnp: 00:0d: iomem range 0xe0000-0xfffff could not be reserved
[13.558735] pnp: 00:0d: iomem range 0x100000-0xfffffff could not be reserved
[13.561100] Time: tsc clocksource has been installed.
[13.589107] PCI: Bridge: 0000:00:01.0
[13.589109] IO window: disabled.
[13.589115] MEM window: fca00000-feafffff
[13.589120] PREFETCH window: bff00000-cfefffff
[13.589143] PCI: Setting latency timer of device 0000:00:01.0 to 64
[13.589161] NET: Registered protocol family 2
[13.629078] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[13.629152] TCP established hash table entries: 8192 (order: 4, 98304 bytes)
[13.629332] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[13.629455] TCP: Hash tables configured (established 8192 bind 8192)
[13.629459] TCP reno registered
[13.641161] checking if image is initramfs... it is
[14.092346] Switched to high resolution mode on CPU 0
[14.409448] Freeing initrd memory: 7342k freed
[14.410081] audit: initializing netlink socket (disabled)
[14.410102] audit(1193435307.092:1): initialized
[14.412539] VFS: Disk quotas dquot_6.5.1
[14.412613] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[14.412762] io scheduler noop registered
[14.412765] io scheduler anticipatory registered
[14.412768] io scheduler deadline registered
[14.412787] io scheduler cfq registered (default)
[14.412810] PCI: VIA PCI bridge detected. Disabling DAC.
[14.412881] PCI: Bypassing VIA 8237 APIC De-Assert Message
[14.412891] Boot video device is 0000:01:00.0
[14.413131] isapnp: Scanning for PnP cards...
[14.766410] isapnp: No Plug & Play device found
[14.808957] Real Time Clock Driver v1.12ac
[14.809095] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[14.809203] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[14.810539] 00:0c: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[14.811705] RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
[14.812026] input: Macintosh mouse button emulation as /class/input/input0
[14.812143] PNP: PS/2 Controller [PNP0303] at 0x60,0x64 irq 1,12
[14.812564] serio: i8042 KBD port at 0x60,0x64 irq 1
[14.812572] serio: i8042 AUX port at 0x60,0x64 irq 12
[14.812800] mice: PS/2 mouse device common for all mice
[14.812954] EISA: Probing bus 0 at eisa.0
[14.812996] EISA: Detected 0 cards.
[14.813254] TCP cubic registered
[14.813268] NET: Registered protocol family 1
[14.813297] Using IPI No-Shortcut mode
[14.813564] Magic number: 11:993:854
[14.813737] hash matches device ptyv6
[14.814425] Freeing unused kernel memory: 364k freed
[14.851233] input: AT Translated Set 2 keyboard as /class/input/input1
[16.094266] AppArmor: AppArmor initialized<5>audit(1193435309.092:2): type=1505 info="AppArmor initialized" pid=1194
[16.105532] fuse init (API version 7.8)
[16.113256] Failure registering capabilities with primary security module.
[16.963651] SCSI subsystem initialized
[16.970021] libata version 2.21 loaded.
[16.971749] sata_via 0000:00:0f.0: version 2.2
[16.971808] ACPI: PCI Interrupt 0000:00:0f.0[B] -> GSI 20 (level, low) -> IRQ 16
[16.971895] sata_via 0000:00:0f.0: routed to hard irq line 10
[16.972058] scsi0 : sata_via
[16.972123] scsi1 : sata_via
[16.972163] ata1: SATA max UDMA/133 cmd 0x0001ec00 ctl 0x0001e802 bmdma 0x0001dc00 irq 16
[16.972168] ata2: SATA max UDMA/133 cmd 0x0001e400 ctl 0x0001e002 bmdma 0x0001dc08 irq 16
[17.010755] usbcore: registered new interface driver usbfs
[17.010796] usbcore: registered new interface driver hub
[17.010830] usbcore: registered new device driver usb
[17.012063] USB Universal Host Controller Interface driver v3.0
[17.123163] via-rhine.c:v1.10-LK1.4.3 2007-03-06 Written by Donald Becker
[17.175501] ata1: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
[17.220942] Floppy drive(s): fd0 is 1.44M
[17.304958] FDC 0 is a post-1991 82077
[17.387155] ata2: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
[17.404435] Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
[17.404444] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[17.405446] VP_IDE: IDE controller at PCI slot 0000:00:0f.1
[17.405478] ACPI: PCI Interrupt 0000:00:0f.1[A] -> GSI 20 (level, low) -> IRQ 16
[17.405496] VP_IDE: chipset revision 6
[17.405499] VP_IDE: not 100% native mode: will probe irqs later
[17.405513] VP_IDE: VIA vt8237 (rev 00) IDE UDMA133 controller on pci0000:00:0f.1
[17.405524] ide0: BM-DMA at 0xfc00-0xfc07, BIOS settings: hda:DMA, hdb:pio
[17.405541] ide1: BM-DMA at 0xfc08-0xfc0f, BIOS settings: hdc:DMA, hdd:pio
[17.405550] Probing IDE interface ide0...
[17.818573] hda: HDS722516VLAT80, ATA DISK drive
[18.490058] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[18.496779] Probing IDE interface ide1...
[19.360178] hdc: _NEC DVD_RW ND-3550A, ATAPI CD/DVD-ROM drive
[20.031418] ide1 at 0x170-0x177,0x376 on irq 15
[20.033197] ACPI: PCI Interrupt 0000:00:10.0[A] -> GSI 21 (level, low) -> IRQ 17
[20.033216] uhci_hcd 0000:00:10.0: UHCI Host Controller
[20.033713] uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 1
[20.033754] uhci_hcd 0000:00:10.0: irq 17, io base 0x0000c000
[20.034329] usb usb1: configuration #1 chosen from 1 choice
[20.034507] hub 1-0:1.0: USB hub found
[20.034519] hub 1-0:1.0: 2 ports detected
[20.044307] hda: max request size: 512KiB
[20.056212] hda: 321672960 sectors (164696 MB) w/7938KiB Cache, CHS=20023/255/63, UDMA(33)
[20.056589] hda: cache flushes supported
[20.056682] hda: hda1 hda2 < hda5 hda6 hda7 hda8 hda9 >
[20.127616] hdc: ATAPI 48X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache, UDMA(33)
[20.127632] Uniform CD-ROM driver Revision: 3.20
[20.135136] ACPI: PCI Interrupt 0000:00:10.1[A] -> GSI 21 (level, low) -> IRQ 17
[20.135158] uhci_hcd 0000:00:10.1: UHCI Host Controller
[20.135194] uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 2
[20.135223] uhci_hcd 0000:00:10.1: irq 17, io base 0x0000c400
[20.135370] usb usb2: configuration #1 chosen from 1 choice
[20.135406] hub 2-0:1.0: USB hub found
[20.135419] hub 2-0:1.0: 2 ports detected
[20.238927] ACPI: PCI Interrupt 0000:00:10.2[B] -> GSI 21 (level, low) -> IRQ 17
[20.238949] uhci_hcd 0000:00:10.2: UHCI Host Controller
[20.238985] uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 3
[20.239013] uhci_hcd 0000:00:10.2: irq 17, io base 0x0000c800
[20.239169] usb usb3: configuration #1 chosen from 1 choice
[20.239206] hub 3-0:1.0: USB hub found
[20.239219] hub 3-0:1.0: 2 ports detected
[20.342759] ACPI: PCI Interrupt 0000:00:10.3[B] -> GSI 21 (level, low) -> IRQ 17
[20.342779] uhci_hcd 0000:00:10.3: UHCI Host Controller
[20.342821] uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 4
[20.342849] uhci_hcd 0000:00:10.3: irq 17, io base 0x0000cc00
[20.343038] usb usb4: configuration #1 chosen from 1 choice
[20.343078] hub 4-0:1.0: USB hub found
[20.343090] hub 4-0:1.0: 2 ports detected
[20.446786] ACPI: PCI Interrupt 0000:00:10.4[C] -> GSI 21 (level, low) -> IRQ 17
[20.446809] ehci_hcd 0000:00:10.4: EHCI Host Controller
[20.446851] ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 5
[20.446909] ehci_hcd 0000:00:10.4: irq 17, io mem 0xfebff800
[20.446918] ehci_hcd 0000:00:10.4: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[20.447061] usb usb5: configuration #1 chosen from 1 choice
[20.447100] hub 5-0:1.0: USB hub found
[20.447113] hub 5-0:1.0: 8 ports detected
[20.550690] ACPI: PCI Interrupt 0000:00:12.0[A] -> GSI 23 (level, low) -> IRQ 18
[20.550903] eth0: VIA Rhine II at 0x1d400, 00:0b:6a:7b:f4:da, IRQ 18.
[20.551618] eth0: MII PHY found at address 1, status 0x786d advertising 05e1 Link 41e1.
[20.583068] Attempting manual resume
[20.583074] swsusp: Resume From Partition 3:6
[20.583076] PM: Checking swsusp image.
[20.583329] PM: Resume from disk failed.
[20.625405] kjournald starting. Commit interval 5 seconds
[20.625424] EXT3-fs: mounted filesystem with ordered data mode.
[21.736388] usb 2-1: new full speed USB device using uhci_hcd and address 2
[21.898447] usb 2-1: configuration #1 chosen from 1 choice
[26.896452] eth0: link up, 100Mbps, full-duplex, lpa 0x41E1
[27.727555] NET: Registered protocol family 10
[27.727689] lo: Disabled Privacy Extensions
[29.220172] Linux agpgart interface v0.102 (c) Dave Jones
[29.255798] agpgart: Detected VIA KT880 chipset
[29.260867] agpgart: AGP aperture is 64M @ 0xe0000000
[29.272975] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[29.365877] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[29.789326] Linux video capture interface: v2.00
[30.411362] input: PC Speaker as /class/input/input2
[30.640620] saa7130/34: v4l2 driver version 0.2.14 loaded
[30.640732] ACPI: PCI Interrupt 0000:00:0a.0[A] -> GSI 18 (level, low) -> IRQ 19
[30.640745] saa7133[0]: found at 0000:00:0a.0, rev: 208, irq: 19, latency: 32, mmio: 0xfebff000
[30.640754] saa7133[0]: subsystem: 1461:f31f, board: Avermedia AVerTV GO 007 FM [card=57,autodetected]
[30.640765] saa7133[0]: board init: gpio is 803e8
[30.640890] input: saa7134 IR (Avermedia AVerTV GO as /class/input/input3
[30.700915] nvidia: module license 'NVIDIA' taints kernel.
[31.030728] parport_pc 00:06: reported by Plug and Play ACPI
[31.030845] parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,EPP,ECP,DMA]
[31.062384] saa7133[0]: i2c eeprom 00: 61 14 1f f3 ff ff ff ff ff ff ff ff ff ff ff ff
[31.062396] saa7133[0]: i2c eeprom 10: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[31.062405] saa7133[0]: i2c eeprom 20: ff d2 fe ff ff ff ff ff ff ff ff ff ff ff ff ff
[31.062413] saa7133[0]: i2c eeprom 30: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[31.062421] saa7133[0]: i2c eeprom 40: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[31.062429] saa7133[0]: i2c eeprom 50: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[31.062438] saa7133[0]: i2c eeprom 60: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[31.062446] saa7133[0]: i2c eeprom 70: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[31.383348] usbcore: registered new interface driver usbserial
[31.383388] /build/buildd/linux-source-2.6.22-2.6.22/drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
[31.383437] usbcore: registered new interface driver usbserial_generic
[31.383441] /build/buildd/linux-source-2.6.22-2.6.22/drivers/usb/serial/usb-serial.c: USB Serial Driver core
[31.394351] /build/buildd/linux-source-2.6.22-2.6.22/drivers/usb/serial/usb-serial.c: USB Serial support registered for cp2101
[31.394412] cp2101 2-1:1.0: cp2101 converter detected
[31.505214] usb 2-1: reset full speed USB device using uhci_hcd and address 2
[31.666439] usb 2-1: cp2101 converter now attached to ttyUSB0
[31.666466] usbcore: registered new interface driver cp2101
[31.666471] /build/buildd/linux-source-2.6.22-2.6.22/drivers/usb/serial/cp2101.c: Silicon Labs CP2101/CP2102 RS232 serial adaptor driver v0.07
[31.810131] tuner 1-004b: chip found @ 0x96 (saa7133[0])
[31.841653] input: ImExPS/2 Generic Explorer Mouse as /class/input/input4
[31.912556] tuner 1-004b: setting tuner address to 61
[31.952489] tuner 1-004b: type set to tda8290+75
[33.593938] tuner 1-004b: setting tuner address to 61
[33.633874] tuner 1-004b: type set to tda8290+75
[35.230113] saa7133[0]: registered device video0 [v4l2]
[35.230297] saa7133[0]: registered device vbi0
[35.230472] saa7133[0]: registered device radio0
[35.301539] ACPI: PCI Interrupt 0000:00:11.5[C] -> GSI 22 (level, low) -> IRQ 20
[35.301692] PCI: Setting latency timer of device 0000:00:11.5 to 64
[35.318342] saa7134 ALSA driver for DMA sound loaded
[35.318391] saa7133[0]/alsa: saa7133[0] at 0xfebff000 irq 19 registered as card -2
[35.816293] ACPI: PCI Interrupt 0000:01:00.0[A] -> GSI 16 (level, low) -> IRQ 21
[35.816869] NVRM: loading NVIDIA UNIX x86 Kernel Module 100.14.19 Wed Sep 12 14:12:24 PDT 2007
[36.505969] lp0: using parport0 (interrupt-driven).
[36.568361] Adding 682720k swap on /dev/hda6. Priority:-1 extents:1 across:682720k
[37.062974] EXT3 FS on hda8, internal journal
[37.738795] kjournald starting. Commit interval 5 seconds
[37.739031] EXT3 FS on hda9, internal journal
[37.739038] EXT3-fs: mounted filesystem with ordered data mode.
[38.258700] eth0: no IPv6 routers present
[39.269931] No dock devices found.
[39.449402] input: Power Button (FF) as /class/input/input5
[39.456072] ACPI: Power Button (FF) [PWRF]
[39.505619] input: Power Button (CM) as /class/input/input6
[39.512237] ACPI: Power Button (CM) [PWRB]
[41.191342] ppdev: user-space parallel port driver
[41.400739] audit(1193428134.646:3): type=1503 operation="inode_permission" requested_mask="a" denied_mask="a" name="/dev/tty" pid=4790 profile="/usr/sbin/cupsd"
[41.508095] apm: BIOS not found.
[41.761126] Failure registering capabilities with primary security module.
[42.009004] Bluetooth: Core ver 2.11
[42.009208] NET: Registered protocol family 31
[42.009211] Bluetooth: HCI device and connection manager initialized
[42.009217] Bluetooth: HCI socket layer initialized
[42.047193] Bluetooth: L2CAP ver 2.8
[42.047201] Bluetooth: L2CAP socket layer initialized
[42.167271] Bluetooth: RFCOMM socket layer initialized
[42.167430] Bluetooth: RFCOMM TTY layer initialized
[42.167433] Bluetooth: RFCOMM ver 1.8
[43.668278] agpgart: Found an AGP 3.5 compliant device at 0000:00:00.0.
[43.668306] agpgart: Putting AGP V3 device at 0000:00:00.0 into 8x mode
[43.668370] agpgart: Putting AGP V3 device at 0000:01:00.0 into 8x mode
[104.480902] NET: Registered protocol family 4
[104.528677] NET: Registered protocol family 3
[104.553408] NET: Registered protocol family 5
[1325.366652] cp2101 ttyUSB0: cp2101_set_config - Unable to send request, request=0x0 size=2 result=-32
[1325.366663] cp2101 ttyUSB0: cp2101_open - Unable to enable UART
[1325.367636] cp2101 ttyUSB0: cp2101_set_config - Unable to send request, request=0x0 size=2 result=-32
[1325.367641] cp2101 ttyUSB0: cp2101_open - Unable to enable UART
[1325.369870] cp2101 ttyUSB0: cp2101_set_config - Unable to send request, request=0x0 size=2 result=-32
[1325.369880] cp2101 ttyUSB0: cp2101_open - Unable to enable UART
[1325.370640] cp2101 ttyUSB0: cp2101_set_config - Unable to send request, request=0x0 size=2 result=-32
[1325.370646] cp2101 ttyUSB0: cp2101_open - Unable to enable UART
[1325.371627] cp2101 ttyUSB0: cp2101_set_config - Unable to send request, request=0x0 size=2 result=-32
[1325.371631] cp2101 ttyUSB0: cp2101_open - Unable to enable UART
[1325.372626] cp2101 ttyUSB0: cp2101_set_config - Unable to send request, request=0x0 size=2 result=-32
[1325.372631] cp2101 ttyUSB0: cp2101_open - Unable to enable UART
[1325.373623] cp2101 ttyUSB0: cp2101_set_config - Unable to send request, request=0x0 size=2 result=-32
[1325.373628] cp2101 ttyUSB0: cp2101_open - Unable to enable UART
[1325.374621] cp2101 ttyUSB0: cp2101_set_config - Unable to send request, request=0x0 size=2 result=-32
[1325.374625] cp2101 ttyUSB0: cp2101_open - Unable to enable UART
lsusb
Bus 005 Device 001: ID 0000:0000
Bus 003 Device 001: ID 0000:0000
Bus 004 Device 001: ID 0000:0000
Bus 002 Device 002: ID 10a6:aa26
Bus 002 Device 001: ID 0000:0000
Bus 001 Device 001: ID 0000:0000
