Witam,
jak mam odpalić ten program żeby zrobić loga ?
Ściągnołem go kilka razy z różnych stron i cały czas jak go odpalam pokazuje mi coś takiego (Silent Runners - Notatnik) zamiast się uruchomić :
'Silent Runners.vbs -- find out what programs start up with Windows!
'DO NOT REMOVE THIS HEADER!
'Copyright Andrew ARONOFF 19 June 2006, http://www.silentrunners.org/
'This script is provided without any warranty, either expressed or implied
'It may not be copied or distributed without permission
' **YOU RUN THIS SCRIPT AT YOUR OWN RISK!**
'HEADER ENDS HERE
Option Explicit
Dim strRevNo : strRevNo = "46"
Public flagTest : flagTest = False 'True if testing
'flagTest = True 'Uncomment to test
'This script is divided into 28 sections.
'malware launch points:
' registry keys (I-XII, XV)
' INI/INF-files (XVI-XVIII)
' folders (XIX)
' enabled scheduled tasks (XX)
' Winsock2 service provider DLLs (XXI)
' IE toolbars, explorer bars, extensions (XXII)
' started services (XXVI)
' keyboard driver filters (XXVII)
' printer monitors (XXVIII)
'hijack points:
' System/Group Policies (XIV)
' prefixes for IE URLs (XXIII)
' misc IE points (XXIV)
' HOSTS file (XXV)
'Output is suppressed if deemed normal unless the -all parameter is used
'Sections XVIII & XXII-dormant Explorer Bars are skipped unless the -supp/-all
' parameters are used or the first message box is answered "No"
' I. HKCU/HKLM... Run/RunOnce/RunOnce\Setup
' HKLM... RunOnceEx/RunServices/RunServicesOnce
' HKCU/HKLM... Policies\Explorer\Run
' II. HKLM... Active Setup\Installed Components\
' HKCU... Active Setup\Installed Components\
' (StubPath <> "" And HKLM version # > HKCU version #)
' III. HKLM... Explorer\Browser Helper Objects\
' IV. HKLM... Shell Extensions\Approved\
' V. HKLM... Explorer\SharedTaskScheduler/ShellExecuteHooks
' VI. HKCU/HKLM... ShellServiceObjectDelayLoad\
' VII. HKCU... Command Processor\AutoRun ((default) <> "")
' HKCU... Policies\System\Shell (W2K & WXP only)
' HKCU... Windows\load & run ((default) <> "")
' HKCU... Command Processor\AutoRun ((default) <> "")
' HKLM... Windows\AppInit_DLLs ((default) <> "")
' HKLM... Winlogon\Shell/Userinit/System/Ginadll/Taskman
' ((default) <> explorer.exe, userinit.exe, "", "", "")
' HKLM... Control\SafeBoot\Option\UseAlternateShell
' HKLM... Control\Session Manager\BootExecute
' HKLM... Control\Session Manager\WOW\cmdline, wowcmdline
' VIII. HKLM... Winlogon\Notify\ (subkey names/DLLName values <> O/S-specific dictionary data)
' IX. HKLM... Image File Execution Options\ (subkeys with name = "Debugger")
' X. HKCU/HKLM... Policies... Startup/Shutdown, Logon/Logoff
' XI. HKCU/HKLM Protocols\Filter
' XII. Context menu shell extensions
' XIII. HKCR executable file type (bat/cmd/com/exe/hta/pif/scr)
' (shell\open\command data <> "%1" %*; hta <> mshta.exe "%1" %*; scr <> "%1" /S)
' XIV. System/Group Policies
' XV. Enabled Wallpaper & Screen Saver
' XVI. WIN.INI (load/run <> ""), SYSTEM.INI (shell <> explorer.exe, scrnsave.exe), WINSTART.BAT
' XVII. AUTORUN.INF in root of fixed drive (open/shellexecute <> "")
' XVIII. DESKTOP.INI in any local fixed disk directory (section skipped by default)
' XIX. %WINDIR%... Startup & All Users... Startup (W98/WME) or
' %USERNAME%... Startup & All Users... Startup folder contents
' XX. Scheduled Tasks
' XXI. Winsock2 Service Provider DLLs
' XXII. Internet Explorer Toolbars, Explorer Bars, Extensions (dormant
' Explorer Bars section skipped by default)
' XXIII. Internet Explorer URL Prefixes
' XXIV. Misc. IE Hijack Points
' XXV. HOSTS file
' XXVI. Started Services
' XXVII. Keyboard Driver Filters
'XXVIII. Printer Monitors
Dim Wshso : Set Wshso = WScript.CreateObject("WScript.Shell")
Dim WshoArgs : Set WshoArgs = WScript.Arguments
Dim intErrNum, intMB 'Err.Number, MsgBox return value
Dim strflagTest : strflagTest = ""
If flagTest Then
strflagTest = "TEST "
Wshso.Popup "Silent Runners is in testing mode.",1, _
"Testing, testing, 1-2-3...", vbOKOnly + vbExclamation
End If
'Configuration Detection Section
' FileSystemObject creation error (112)
' CScript/WScript (147)
' Dim (161)
' GetFileVersion(WinVer.exe) (VBScript 5.1) (182)
' OS version (223)
' WMI (279)
' Dim (364)
' command line arguments (440)
' supplementary search MsgBox (532)
' startup MsgBox (557)
' CreateTextFile error (583)
' output file header (625)
' WXP SP2 (629)
On Error Resume Next
Dim Fso : Set Fso = CreateObject("Scripting.FileSystemObject")
intErrNum = Err.Number : Err.Clear
On Error Goto 0
If intErrNum <> 0 Then
strURL = "http://tinyurl.com/7nn6"
intMB = MsgBox (Chr(34) & "Silent Runners" & Chr(34) &_
" cannot access file services critical to" & vbCRLF &_
"proper script operation." & vbCRLF & vbCRLF &_
"If you are running Windows XP, make sure that the" &_
vbCRLF & Chr(34) & "Cryptographic Services" & Chr(34) &_
" service is started." & vbCRLF & vbCRLF &_
"You can also try reinstalling the latest version of the MS" &_
vbCRLF & "Windows Script Host." & vbCRLF & vbCRLF &_
"Press " & Chr(34) & "OK" & Chr(34) & " to direct your browser to " &_
"the download site or" & vbCRLF & Space(10) & Chr(34) & "Cancel" &_
Chr(34) & " to quit.", vbOKCancel + vbCritical, _
"Can't access the FileSystemObject!")
'if dl wanted now, send browser to dl site
If intMB = 1 Then Wshso.Run strURL
WScript.Quit
ITD.
