mój kumpel posiada płyte główna Asus p5n-d sli nforce 750i oraz dwie karty Geforce 8600gt 1gb spięte w SLI. Problem w tym że po zainstalowaniu Windows Vista Ultimate komp widzi 2 karty lecz podczas uruchomiania SLI w sterowniku Nvidii pojawia się Blue Screen…
* Bugcheck Analysis
Use !analyze -v to get detailed debugging information.
BugCheck 1000008E, {c0000005, 8d1909b1, 8e4f60c8, 0}
*** WARNING: Unable to verify timestamp for dxgkrnl.sys
*** ERROR: Module load completed but symbols could not be loaded for dxgkrnl.sys
*** WARNING: Unable to verify timestamp for watchdog.sys
*** ERROR: Module load completed but symbols could not be loaded for watchdog.sys
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB
fish_92 , nie podałeś całego raportu. Bardziej interesuje mnie koniec, niż środek. Najlepiej to daj go na wklej.org lub wklejto.pl, a tutaj daj tylko linka.
