Windows Worms Doors Cleaner pokazuje mi ze moj system moze byc zainfekowany przez wirus, i ze moj SVCHOST virtual memory usage 54280Ko is beyond usual values. Co mam z tym zrobic? Prosze o porade.
Dodam raport fixwareout :
Successfully flushed the DNS Resolver Cache.
[HKEY\_LOCAL\_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"SunJavaUpdateSched"="C:\\Program Files\\Java\\j2re1.4.2\_03\\bin\\jusched.exe"
"IntelWireless"="C:\\Program Files\\Intel\\Wireless\\Bin\\ifrmewrk.exe /tf Intel PROSet/Wireless"
"ISUSPM Startup"="C:\\PROGRA~1\\COMMON~1\\INSTAL~1\\UPDATE~1\\ISUSPM.exe -startup"
"ISUSScheduler"="\"C:\\Program Files\\Common Files\\InstallShield\\UpdateService\\issch.exe\" -start"
"dla"="C:\\WINDOWS\\system32\\dla\\tfswctrl.exe"
"igfxtray"="C:\\WINDOWS\\system32\\igfxtray.exe"
"igfxhkcmd"="C:\\WINDOWS\\system32\\hkcmd.exe"
"igfxpers"="C:\\WINDOWS\\system32\\igfxpers.exe"
"SigmatelSysTrayApp"="stsystra.exe"
"SynTPEnh"="C:\\Program Files\\Synaptics\\SynTP\\SynTPEnh.exe"
"AVKTray"="\"C:\\Program Files\\G DATA AntiVirus Trial\\AVKTray\\AVKTray.exe\""
"Adobe Reader Speed Launcher"="\"C:\\Program Files\\Adobe\\Reader 8.0\\Reader\\Reader\_sl.exe\""
[HKEY\_LOCAL\_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\avp6\_post\_uninstall]
[HKEY\_CURRENT\_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"Skype"="\"C:\\Program Files\\Skype\\Phone\\Skype.exe\" /nosplash /minimized"
"ctfmon.exe"="C:\\WINDOWS\\system32\\ctfmon.exe"
"swg"="C:\\Program Files\\Google\\GoogleToolbarNotifier\\GoogleToolbarNotifier.exe"
"SpybotSD TeaTimer"="C:\\Program Files\\Spybot - Search & Destroy\\TeaTimer.exe"
Hosts file was reset, If you use a custom hosts file please replace it...
~~~~~End report~~~~~
