@ libros
Niestety nie naprawił. Końcowy log wygląda tak:
Test [The Shell Hardware Detection service is running.] - Instance [N/A]:
Result [AutoStart Setting]: OK
Result [The Shell Hardware Detection service is running.]: OK
Test [Policies] - Instance [H]:
Result [HKCU…\Policies!NoDrives]: OK {Present}
Result [HKCU…\Policies!NoDriveAutorun]: OK {Absent}
Result [HKCU…\Policies!NoDriveTypeAutorun]: OK {Present}
Result [HKLM…\Policies!NoDrives]: OK {Absent}
Result [HKLM…\Policies!NoDriveAutorun]: OK {Absent}
Result [HKLM…\Policies!NoDriveTypeAutorun]: OK {Absent}
Result [Driver level policies]: OK {
HKLM…\Services\cdrom!Autorun (Present)
HKLM…\Services\cdrom\Parameters!Autorun (Absent)
HKLM\System\CCS\Enum…!AlwaysEnable (Absent)
HKLM\System\CCS\Enum…!AlwaysDisable (Absent) }
Test [Drive Notification] - Instance [H]:
Result [Legacy Notification]: Problems
Result [AutoPlay V2 Notification]: Problems {
Service (Silent)
Shell (Deaf) }
>> Repair << [Legacy AutoPlay Event]
Step: No steps to take.
Result: This AutoPlay setting cannot be fixed. Either the device is malfunctioning, or the wizard cannot determine the problem.
>> Repair << [Autoplay V2 Event]
>> Required action: The wizard found problems but cannot fix them -> None
@ jasiekb
CD jest czyste, więc nie ma co czyścić. Płyta była używana może ze 4 razy wcześniej.
